Thread: Difficulty getting into any gears when cold
Results 1 to 10 of 11
  1. Difficulty getting into any gears when cold
    Sep 2023
    GB
    Over the last few weeks a problem has slowly developed with my 2012 Touran. When the car is cold as in first thing in the morning the car does not want to go into gear. It's nearly like when I press the clutch pedal the clutch does not fully engage. Is the 6 speed 2ltr diesel and I know it is possible to bleed the clutch but is this the problem or does anyone know if this is a sign of bigger problems.
    When the engine and gearbox are warm the gear changes are possible, a bit clunky but nothing out of the ordinary.
    Any suggestions would be appreciated.
    Sent from my SM-S911B using Tapatalk
  2. Re: Difficulty getting into any gears when cold
    131 Post(s)
    1976 Post(s)
    Certainly start with bleeding the clutch BUT if it is the master or slave, this can actually make them fail completely... it is a gamble
  3. Re: Difficulty getting into any gears when cold
    Sep 2023
    GB
    Thanks Crasher, would it explain the fact its easier when the engine is warm?
  4. Re: Difficulty getting into any gears when cold
    131 Post(s)
    1976 Post(s)
    Possibly the concentric release bearing (incorporating the slave cylinder) responds to the heat.
  5. Re: Difficulty getting into any gears when cold
    Sep 2023
    GB
    Thanks Crasher I'm due to give the car a full service this week so will bleed the clutch then. If that doesn't fix it I'll have to dig a bit deeper.
  6. Re: Difficulty getting into any gears when cold
    Mar 2010
    Derry ireland
    63 Post(s)
    Why not at engine off jack either wheel of the ground car in gear person in car clutch depressed the wheel off the ground should turn easily by hand check it & get back
  7. Re: Difficulty getting into any gears when cold
    Sep 2023
    GB
    It has been fixed.... temporarily.
    I say temporarily as I am not convinced by the whole scenario. The other evening on my way home and after seeing a few clutch bleeding videos on YouTube I pulled the clutch pedal back to its highest point manual and pumped it a few times, all with the engine on, and it seemed to have fixed it. I have driven the car a few times since then and no issues with the clutch at cold or hot or any times.
    Today then I did bleed any way to ensure all was well and after switching the car on the pedal seemed a smidge firmer.
    We will see how it progresses over the next few days/weeks.
    Out of interest Crasher where is the slave cylinder located in case I do need to replace it in future?
  8. Re: Difficulty getting into any gears when cold
    131 Post(s)
    1976 Post(s)
    What is the VIN?
  9. Re: Difficulty getting into any gears when cold
    Sep 2023
    GB
    What is the VIN?
    Just sent you a DM
  10. Re: Difficulty getting into any gears when cold
    131 Post(s)
    1976 Post(s)
    Yours uses a concentric hydraulic release bearing inside the box so box out to change.
  1. Replies: 7
    Last Post: 02-04-2015, 03:19 PM
  2. A4 1.8 20v difficulty engaging gears. Hydraullics? Gearbox oil? Clutch?
    By ashy90 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 19-04-2013, 09:21 PM
  3. Question difficulty in selecting gears
    By sohel in forum Golf MK4 - 1999 - 2004
    Last Post: 09-08-2010, 04:37 PM
  4. Clutch replaced, but still difficulty engaging gears!
    By ventionandy in forum Chat - Anything with wheels
    Last Post: 23-06-2008, 02:07 PM
  5. Difficulty starting and rough running when engine is cold
    By brauser rexel in forum Archive posts
    Last Post: 23-10-2007, 04:50 PM
