Thread: Adblue fault ??
Results 1 to 9 of 9
  1. Adblue fault ??
    Feb 2019
    MIDDLESBROUGH UK
    28 Post(s)
    Hi guys,
    just drove to Scotland and back without any problems, but this afternoon on a 5 mile trip my check engine light came on without any error message?
    hooked up my VCDS and found only one fault:-
    P204B 00 [237] reductant pressure circuit implausible signal.
    Strangely I have had no AdBlue warnings on the dash and no fault showing in AC Reductant control module?
    I can see that the pressure is -500hpa, but is that likely to be the pressure sensor or the pump not working or a blockage somewhere like the injector. or hopefully a bad connection.
    Has any body any experience with this problem ( Crasher ? ) and can shed some light before I delve in?
    I thought I would have had the " No restart in 650Mls " message but no.logpart a .txtlogpart b .txt
    I think I've uploaded the log file but I had to do it in two parts a it seems it was too big as one?
    Doo! tried again copy and paste.
  2. Re: Adblue fault ??
    Feb 2019
    MIDDLESBROUGH UK
    28 Post(s)
    Code:
    Saturday,09,September,2023,18:13:07:52854
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
    VCDS Version: 23.3.1.0 (x64)  HEX-V2 CB: 0.4631.4
    Data version: 20230421 DS346.2
    Ross-Tech: Home
    VIN: WAUZZZ4M5GD022610   License Plate:
    Mileage: 57476km-35713mi   Repair Order:
    Chassis Type: 4M-AU73 (4M2)
    Scan: 01 02 03 06 08 09 0E 13 15 16 17 19 28 29 2B 36 39 3C 42 44
              46 47 50 52 57 5F 65 69 6C 6D 74 81 82 84 8B A5 AC BB BC CA
              CB CF D6 D7
    VIN: WAUZZZ4M5GD022610   Mileage: 57476km-35713miles
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: OK 0000
    06-Seat Mem. Pass -- Status: OK 0000
    0E-Media Player 1 -- Status: OK 0000
    13-Auto Dist. Reg -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    28-HVAC, Rear -- Status: OK 0000
    29-Left Light -- Status: OK 0000
    2B-Steer. Col. Lock -- Status: OK 0000
    36-Seat Mem. Drvr -- Status: OK 0000
    39-Right Light -- Status: OK 0000
    3C-Lane Change -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    50-Seat Adj. 3rd row -- Status: OK 0000
    57-TV Tuner -- Status: OK 0000
    5F-Information Electr. -- Status: OK 0000
    65-Tire Pressure -- Status: OK 0000
    69-Trailer -- Status: OK 0000
    6C-Back-up Cam. -- Status: OK 0000
    6D-Trunk Elect. -- Status: OK 0000
    74-Chassis Control -- Status: OK 0000
    81-Gear Shift -- Status: OK 0000
    82-Head Up Display -- Status: OK 0000
    84-Night Vision -- Status: OK 0000
    8B-Adaptive Cruise 2 -- Status: OK 0000
    A5-Frt Sens. Drv. Assist -- Status: Malfunction 0010
    AC-Reductant Control -- Status: OK 0000
    BB-Door Rear Drv -- Status: OK 0000
    BC-Door Rear Pass -- Status: OK 0000
    CA-Sunroof -- Status: OK 0000
    CB-Rear Axle Steering -- Status: OK 0000
    CF-Lane Chge Asst 2 -- Status: OK 0000
    D6-Light Ctrl Left 2 -- Status: OK 0000
    D7-Light Ctrl Right 2 -- Status: OK 0000
    Address 01: Engine (J623-CRTC)       Labels: Redir Fail!
       Part No SW: 4M0 907 401     HW: 059 907 309 B
       Component: 3.0TDI EDC17  H45 0009
       Revision: 91H45---    CVN: 5D7B42084F8B6DFB92F1EF3C
       Coding: 2A2A4032057E050335380000000000000000000000000000
       Shop #: WSC 53049 004 1048576
       ASAM Dataset: EV_ECM30TDI0114M0907401 001013
       ROD: EV_ECM30TDI0114M0907401.rod
       VCID: 669446BB88EB2A5A957-8032
       VINID: 9D196AAAA11D15750008218100A9DFD84C
    1 Fault Found:
    11393 - Reductant Pressure Sensor Circuit
              P204B 00 [237] - Implausible Signal
              MIL ON - Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Status: 00000001
                        Fault Priority: 2
                        Fault Frequency: 1
                        Mileage: 57451 km
                        Date: 2023.09.05
                        Time: 15:42:06
                        Engine RPM: 729.00 /min
                        Normed load value: 97.3 %
                        Vehicle speed: 0 km/h
                        Coolant temperature: 54 °C
                        Intake air temperature: 23 °C
                        Ambient air pressure: 1010 mbar
                        Voltage terminal 30: 14.220 V
                        Unlearning counter according OBD: 40
                        Outside temperature: 21.5 °C
                        Pressure sensor for reducing agent: measured pressure: -500 hPa
                        Pump for reducing agent: speed: 0.0 /min
                        Sensor for reducing agent tank temperature: temperature: 20.0 °C
                        Reducing agent pump: activation: 0.00 %
                        Sensor for reducing agent fill level: fill level height: 219 mm
                        Sensor 2 for temp. reducing agent: act. value: 19.0 °C
    Readiness: 1 1 0 0 0
    Address 02: Auto Trans (J217)       Labels:| 0BK-927-156.clb
       Part No SW: 4M0 927 158 J    HW: 0D5 927 156 H
       Component: 0D5  30TDIRdW H03 1008
       Revision: --H03---    CVN: 642B4C69
       Coding: 100000
       Shop #: WSC 31414 790 00001
       ASAM Dataset: EV_TCMALX52011 002010
       ROD: EV_TCMALX52011_AU49.rod
       VCID: 3B22C7CFA3E947B21A9-806E
    No fault code found.
    Address 03: ABS Brakes (J104)       Labels: 4M0-907-379-PRE-V1.clb
       Part No SW: 4M0 907 379 K    HW: 4M0 907 379 K
       Component: ESP9 Premium  H08 0521
       Dataset Number: 4M0909504G  0029 CVN: 5BF8C31D
       Coding: 249830B230A40A98D6A45892187D16AEE6A6DA240C0C506B1A18687567655B
       Shop #: WSC 61854 001 48576
       ASAM Dataset: EV_ESP9BOSCHAU736 011006
       ROD: EV_ESP9BOSCHAU736_AU73.rod
       VCID: 3FDAB3DFB7F15B92361-806A
    Address 06: Seat Mem. Pass (J521)       Labels:* None
       Part No SW: 4M0 959 760 E    HW: 4M0 959 760 E
       Component: MEM-BFS       008 0014
       Serial number: 00000164487450 Dataset Number: 4M0909866B  0013
       Coding: 00383B000001B2410000210101010000110000313100000000000000000000
       ASAM Dataset: EV_SCMPasseSideCONTIAU736 006007
       ROD: EV_SCMPasseSideCONTIAU736_AU49.rod
       VCID: 3A2CC2CBACD37EBA01F-806E
    Address 08: Auto HVAC (E87)       Labels:* None
       Part No SW: 4M0 820 043 AD    HW: 4M0 820 043 AD
       Component: Klima Zone 4  H52 0083
       Coding: 6618083C5549451102620180800000000000000000000000000000000000
       ASAM Dataset: EV_AirCondiFrontBHTCAU736 001013
       ROD: EV_AirCondiFrontBHTCAU736.rod
       VCID: 678A4BBF8FE13352AE1-8032
       Fresh air blower control module (front):
       Subsystem 1 - Part No SW: 4M2 820 021     HW: 4M2 820 021
       Component: J216 FLuftV  H05 0001
       Serial number: 00000000000000594096
       Humidity sensor: exterior:
       Subsystem 2 - Part No SW: 4H0 907 658 A    HW: 4H0 907 658 A
       Component: AQ_Hum_Sensor  H01 0003
       Serial number: 7C1945C7000000000001
    Address 09: Cent. Elect. (J519)       Labels:* Redir Fail!
       Part No SW: 8W0 907 063 G    HW: 8W0 907 063 G
       Component: BCM1 MLBevo   H12 0215
       Dataset Number: 4M0909514L  0040
       Coding: 07501943C12B00CD010D57195B3F1CF913033D019000000000000000E20016810A4502AB32B70A
       ASAM Dataset: EV_BCM1BOSCHAU736 014003
       ROD: EV_BCM1BOSCHAU736_014.rod
       Wiper motor control module:
       Subsystem 1 - Part No SW: 4M2 955 119 A    HW: 4H1 955 119 C  Labels: 1KX-955-119.CLB
       Component: WWS536 150611  042 0792
       Serial number:         150629070055
       Coding: 1BC7F7
       Rain/Light Recognition Sensor:
       Subsystem 2 - Part No SW: 8U0 955 559 C    HW: 8U0 955 559 B  Labels: 8U0-955-559.CLB
       Component: G397_RLFS  H06 0004
       Serial number: 20592083
       Coding: 0200FF
       Light switch:
       Subsystem 3 - Part No SW: 4M0 941 531 R    HW: 4M0 941 531 R
       Component: E1 - LDS  H05 0007
       Serial number: 17 07 2015  00051117
       Garage door opener control module:
       Subsystem 4 - Part No SW: 4M0 907 410     HW: 4M0 907 410
       Component: EHL2 V8  H05 0050
       Serial number: 0000009600331Z02Q802
       Coding: 310000
       Garage door opener control head:
       Subsystem 5 - Part No SW: 4M0 959 719     HW: 4M0 959 719
       Component: GTO BF  H05 0010
       Serial number: 20140923175439 00048
       Automatic dimming interior mirror:
       Subsystem 6 - Part No SW: 4M0 857 511 A    HW: 4M0 857 511 A
       Component: Y7_Innenspieg  H08 0002
       Serial number: GX1CE125081511520079
       Coding: 230000
       Interior Light Module:
       Subsystem 7 - Part No SW: 4M0 947 135 AB    HW: 4M0 947 135
       Component: J528-Dachele  H13 0080
       Serial number: Q00037553
       Adjustable Steering Column Control Module:
       Subsystem 8 - Part No SW: 4M0 907 705 A    HW: 4M0 907 705 A
       Component: J866-EVLS-SG  H03 0060
       Serial number: WA121241000014242957
       Coding: 020100
       Control head for driving and comfort functions:
       Subsystem 9 - Part No SW: 4M0 925 301 B    HW: 4M0 925 301 B
       Component: SL-Q7NF/AU736  H09 0006
       Serial number: 00000000000000013890
    Address 0E: Media Player 1 (R161)       Labels: None
       Part No SW: 4M1 035 108 A    HW: 4M1 035 108
       Component: DVD Changer   H30 0100
       ASAM Dataset: EV_DVDCALPI 001010
       ROD: EV_DVDCALPI.rod
       VCID: 24101CB33E57184A4B3-8070
    Address 13: Auto Dist. Reg (J428)       Labels:* Redir Fail!
       Part No SW: 4M0 907 561 C    HW: 4M0 907 561
       Component: LRR4          H08 0160
       Dataset Number: 4M0909863J  0022
       Coding: 3477FFFB78FFEC08949880A4
       ASAM Dataset: EV_ACCBOSCHAU736 001016
       ROD: EV_ACCBOSCHAU736.rod
       VCID: 3038E0E37AAFB4EABFB-8064
    Address 15: Airbags (J234)       Labels:| 80A-959-655.clb
       Part No SW: 4M0 959 655     HW: 4M0 959 655
       Component: Airbag10.44   H50 0084
       Serial number: 003L1000RKTF Dataset Number: 4M0909602K  0002
       Coding: AACCF0D80C80000098F650F3C08C00000000
       ASAM Dataset: EV_AirbaAU10BPAAU736 005012
       ROD: EV_AirbaAU10BPAAU736_005.rod
       VCID: 78A818C3D25FACAA37B-802C
       Left seat belt tensioner:
       Subsystem 1 - Part No SW: 4M0 980 945     HW: 4M0 980 945
       Component: BeltPretRevFL  205 2033
       Serial number: 4M0857705D0259P00311
       Coding: 88001B
       Right seat belt tensioner:
       Subsystem 2 - Part No SW: 4M0 980 946     HW: 4M0 980 946
       Component: BeltPretRevFR  205 2033
       Serial number: 4M0857706D0253P00464
       Coding: 88001B
       Crash sensor for side airbag: driver side:
       Subsystem 3 - Part No SW: -----------    HW: 442 061 609 15
       Component: SideSensor_Df  1E2 0887
       Serial number: 3577Y00AD1A537D2D53C
       Coding: 2D2D2D
       Front Passenger's Side Airbag Crash Sensor:
       Subsystem 4 - Part No SW: -----------    HW: 442 061 609 15
       Component: SideSensor_Pf  1E2 0887
       Serial number: 3587Y00991A537E314F9
       Coding: 2D2D2D
       Rear Side Airbag Crash Sensor (on driver's side):
       Subsystem 5 - Part No SW: -----------    HW: 442 0B0 708 15
       Component: SideSensor_Dr  1C7 0148
       Serial number: 3517700AD1BF9E24E27$
       Coding: 2D2D2D
       Passenger side rear thorax airbag crash sensor:
       Subsystem 6 - Part No SW: -----------    HW: 442 0B0 708 15
       Component: SideSensor_Pr  1C7 0148
       Serial number: 3527700B91BF9E0553EZ
       Coding: 2D2D2D
       Crash sensor for front airbag: driver side:
       Subsystem 7 - Part No SW: -----------    HW: 442 0C2 708 15
       Component: FrontSensor_D  1C5 014A
       Serial number: 3557500C11C3DEC2E27W
       Coding: 2D2D2D
       Crash sensor for front airbag: front passenger side:
       Subsystem 8 - Part No SW: -----------    HW: 442 0C0 508 15
       Component: FrontSensor_P  1C5 014A
       Serial number: 3567500AD1C3DEC1C2D3
       Coding: 2D2D2D
       Center pedestrian protection crash sensor:
       Subsystem 9 - Part No SW: -----------    HW: 442 0C1 108 15
       Component: PedP_Sensor_C  1C5 014A
       Serial number: 2307500C71C2E314F068
       Coding: 2D2D2D
       Driver's side crash data pedestrian protection 2:
       Subsystem 10 - Part No SW: -----------    HW: 442 422 608 15
       Component: PedPSensor_D2  21E 0887
       Serial number: I0M8U00A91989854113H
       Coding: 2D2D2D
       Passenger's side crash data pedestrian protection 2:
       Subsystem 11 - Part No SW: -----------    HW: 442 422 608 15
       Component: PedPSensor_P2  21E 0887
       Serial number: I0N8U00A91989854A17V
       Coding: 2D2D2D
       Central crash sensor X/Y:
       Subsystem 12 - Part No SW: -----------    HW: 410 201 308 15
       Component: CentrSensorXY  1C8 0108
       Serial number: I0O7800BD1BCC0E4309I
       Coding: 2D2D2D
    Address 16: Steering wheel (J527)       Labels: 4M0-907-129.clb
       Part No SW: 4M0 907 129 HL    HW: 4M0 907 129 HL
       Component: Lenks.Modul   H11 0008
       ASAM Dataset: EV_SMLSKLOAU736 006008
       ROD: EV_SMLSKLOAU736_006.rod
       VCID: 015E75278185ED62005-8054
    Address 17: Instruments (J285)       Labels:* Redir Fail!-SRI2
       Part No SW: 4M0 920 790 A    HW: 4M0 920 790 A
       Component: FBenRDW       H12 0280
       Coding: 248D01F07C980E0001A3E9643000600000000000
       ASAM Dataset: EV_DashBoardAU736 001020
       ROD: EV_DashBoardAU736_AU73.rod
       VCID: 2D06F9976D9DD90294D-8078
    Address 19: CAN Gateway (J533)       Labels:* None
       Part No SW: 4M2 907 468 A    HW: 4M2 907 468 A
       Component: Gateway       H13 4079
       Revision: 3C030052    Serial number: 5243C022615809 Dataset Number: 4M0909515H  0057
       Coding: 0301000100808F407F07000000590032DC9200071C0000000100000000000000
       Shop #: WSC 47352 001 1048576
       GVL: 01583C0C88040200C0FCC8000102C800110C2000000000000000000000000000
       ASAM Dataset: EV_GatewCONTIAU736 002040
       ROD: EV_GatewCONTIAU736_002_AU73.rod
       VCID: 3634D6FB98CB9ADAE57-8062
       Multifunction steering wheel control module:
       Subsystem 1 - Part No SW: 4M0 951 523     HW: 4M0 951 523
       Component: J453 MFL  H06 0002
       Serial number: 20150831013800 00082
       Battery Monitoring Control Module:
       Subsystem 2 - Part No SW: 8S0 915 181     HW: 8S0 915 181
       Component: J367-BDMHella  H10 9052
       Serial number: 8378177803
    Address 28: HVAC, Rear (E265)       Labels:* None
       Part No SW: 4M0 919 158 D    HW: 4M0 919 158 D
       Component: Klima Zone 2  H52 0080
       Coding: 000000000000040100820080000000000000000000000000000000000000
       ASAM Dataset: EV_AirCondiFondBHTCAU736 001013
       ROD: EV_AirCondiFondBHTCAU736.rod
    Address 29: Left Light (J1018)       Labels: 4M0-907-397.clb
       Part No SW: 4M0 907 397 B    HW: 4M0 907 397 B
       Component: LCM_MLBevoH05 0011
       ASAM Dataset: EV_LCMLeftHELLAAU736 001006
       ROD: EV_LCMLeftHELLAAU736_VW48.rod
    Address 2B: Steer. Col. Lock (J764)       Labels:| 1EA-905-861.clb
       Part No SW: 3Q0 905 861 A    HW: 3Q0 905 861 A
       Component: ELV-MLBevo    H05 0032
       Serial number: 15000056338006
       Coding: 8800000000000000
       ASAM Dataset: EV_ELVMarquMQBB 001007
       ROD: EV_ELVMarquMQBB_VW37.rod
       VCID: 323CEAEB74A386FAC9F-8066
    Address 36: Seat Mem. Drvr (J136)       Labels:* None
       Component: MEM-FS        008 0014
       Serial number: 00000164486492 Dataset Number: 4M0909856B  0013
       ASAM Dataset: EV_SCMDriveSideCONTIAU736 006007
       ROD: EV_SCMDriveSideCONTIAU736_AU49.rod
    Address 39: Right Light (J1023)       Labels: 4M0-907-397.clb
       ASAM Dataset: EV_LCMRightHELLAAU736 001006
    Address 3C: Lane Change (J769)       Labels:* None
       Part No SW: 4M0 907 566     HW: 4M0 907 566
       Component: MRR1Rear      H13 0161
       Revision: --------    Dataset Number: 4M0909535J  0009
       Coding: 5EE002
       ASAM Dataset: EV_RearRadarS1BoschAU736 001015
       ROD: EV_RearRadarS1BoschAU736.rod
       VCID: 72BC2AEBB423C6FA09F-8026
    Address 42: Door Elect, Driver (J386)       Labels:* None
       Part No SW: 4M0 959 793 G    HW: 4M0 959 793 C
       Component: TSG FS        009 0052
       Serial number: 0000164613750  Dataset Number: 4M0909872F  0027
       Coding: 005D9A005E010082000930B2
       ASAM Dataset: EV_DCU2DriveSideMAXHCONT 001005
       ROD: EV_DCU2DriveSideMAXHCONT_AU49.rod
       VCID: 42DCBA2BC403367A59F-8016
    Address 44: Steering Assist (J500)       Labels:* None
       Part No SW: 4M0 909 144 G    HW: 4M0 909 144 B
       Component: EPS_MLBEVO1BS H19 0004
       Serial number: 0000174998 Dataset Number: 4M0909852G  0018
       Coding: B0150101000101
       ASAM Dataset: EV_EPSVWBSAU736 008020
       ROD: EV_EPSVWBSAU736_008.rod
       VCID: 3332EFEF8BB98FF2C29-8066
    Address 46: Central Conv. (J393)       Labels:* None
       Part No SW: 8W0 907 064 AD    HW: 8W0 907 064 D
       Component: BCM2 MLBevo   015 0307
       Dataset Number: 4M0909501D  0053
       Coding: 01351E006F1100406389A0006E00580203004004006F03502F0400000504803F001F0001000000
       ASAM Dataset: EV_BCM2HellaAU736 010010
       ROD: EV_BCM2HellaAU736_010_AU49.rod
       VCID: 7EA40EDBF07B929A7D7-802A
       Anti-theft alarm system sensor:
       Subsystem 1 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
       Component: Sensor, DWA  005 0316
       Serial number: 000000000ZY1518200E5
       Alarm horn:
       Subsystem 2 - Part No SW: 5Q0 951 605     HW: 5Q0 951 605
       Component: Sirene, DWA  004 0311
       Serial number: 00000000000063509008
       Heated Windshield Control Module:
       Subsystem 3 - Part No SW: 4M0 907 133     HW: 4M0 907 133
       Component: J505-FSH  H03 0050
       Serial number: 00000000000000004139
       Rear lid opener control module:
       Subsystem 4 - Part No SW: 3AA 962 243 F    HW: 3AA 962 243 F
       Component: GEB.F.Heckoef  H16 0816
       Serial number: 94044087
    Address 47: Sound System (J525)       Labels:* None
       Part No SW: 4M0 035 466 A    HW: 4M1 035 466
       Component: 8RF           H10 0586
       Serial number: 2530144536 Dataset Number: 4M0909510C  0009
       Coding: 0135060A00A2AAAAAAAAAA010000
       ASAM Dataset: EV_AMPMst24C1Gen2BAO 001002
       ROD: EV_AMPMst24C1Gen2BAO_AU73.rod
       VCID: 2A0CF28B5C73CE3A71F-807E
    Address 50: Seat Adj. 3rd row (J857)       Labels:* None
       Part No SW: 4M0 959 760 G    HW: 4M0 959 760 G
       Component: MEM-SR3       008 0014
       Serial number: 00000166075768 Dataset Number: 4M0909467B  0014
       Coding: FF201020F1000000000F000000000900000021210900000000000000440000
       ASAM Dataset: EV_SCM3rdRowCONTIAU736 005007
       ROD: EV_SCM3rdRowCONTIAU736_AU73.rod
       VCID: 3C20C4D3A6E7408A133-8068
    Address 52: Door Elect, Pass. (J387)       Labels:* None
       Part No SW: 4M0 959 792 D    HW: 4M0 959 792 C
       Component: TSG BFS       009 0038
       Serial number: 0000165636429  Dataset Number: 4M0909873E  0022
       Coding: 005D9A005E010082000930B0
       ASAM Dataset: EV_DCU2PasseSideMAXHCONT 001005
       ROD: EV_DCU2PasseSideMAXHCONT_AU49.rod
       VCID: 3E24CEDBB0FB529A3D7-806A
    Address 57: TV Tuner (R78)       Labels:* None
       Part No SW: 8V0 919 191 D    HW: 8V0 919 191 B
       Component: DVB-DTV       H09 2260
       Coding: 0104030000000100000000
       ASAM Dataset: EV_TVMELC 001036
       ROD: EV_TVMELC_VW37.rod
       VCID: 40D8B023CA0F246A4FB-8014
    Address 5F: Information Electr. (J794)       Labels:* 4M0-035-MIB-HGH2.clb
       Part No SW: 4M1 035 035 C    HW: 4M1 035 035
       Component: MU-P-LND-EU   035 1329
       Serial number: A641B0KB037229 Dataset Number: 4M0909545Q  0049
       Coding: 013706010000000013111102000A00332F001BE701700100BE
       ASAM Dataset: EV_MUHig6C3Gen2HBAS 001115
       ROD: EV_MUHig6C3Gen2HBAS_AU49.rod
       VCID: 251601B7356DE1425CD-8070
       Data carrier:
       Subsystem 1 - Part No SW: V03 959 802 TP    HW: -----------
       Component: ECE 2022/2023  --- 0197
       Serial number: --------------------
       Multimedia System 1:
       Subsystem 2 - Part No SW: 4M0 919 605     HW: 4M0 919 605
       Component: AU536_DU_HIGH  H43 0008
       Serial number: AUZ8Z9FJ400TAS
       Multimedia system control head:
       Subsystem 3 - Part No SW: 4M0 919 615 D    HW: 4M0 919 615 D
       Component: ControlUnit_P  H14 0165
       Serial number: 03091500000000000262
       Compact disc data bank:
       Subsystem 4 - Part No SW: V03 959 800 EG    HW: -----------
       Component: Gracenote2  --- 1017
    Address 65: Tire Pressure (J502)       Labels: 4M0-907-273.clb
       Part No SW: 4M0 907 273     HW: 4M0 907 273
       Component: RDKHUFAU736   H03 0009
       Serial number: 00000000000705 Dataset Number: 4M0909850B  0004
       ASAM Dataset: EV_RDKHUFAU736 002006
       ROD: EV_RDKHUFAU736.rod
       VCID: 6D863997AD1D1902D4D-8038
    Address 69: Trailer (J345)       Labels:| 5Q0-907-383.clb
       Part No SW: 4M0 907 383 D    HW: 4M0 907 383 B
       Component: Anhaenger     H20 0211
       Revision: 9A001003    Serial number: 0371601494 Dataset Number: 4M0909527C  0021
       Coding: 0110000202010000
       ASAM Dataset: EV_TrailFunctGener2Hella 001008
       ROD: EV_TrailFunctGener2Hella_VW26.rod
       Bend angle sensor for trailer:
       Subsystem 1 - Part No SW: 4M0 907 811     HW: 4M0 907 811
       Component: G820 KNWINSEN  H18 0019
       Serial number: 10459
    Address 6C: Back-up Cam. (J928)       Labels:* None
       Part No SW: 4M0 907 428 B    HW: 4M0 907 428
       Component: Areaview 2    H11 0301
       Serial number: C854606JG001208 Dataset Number: 4M1909460D  0014
       Coding: 02370601BF0FA10008404480
       ASAM Dataset: EV_CamSysRVAV2CE2MLBEv 004013
       ROD: EV_CamSysRVAV2CE2MLBEv_004.rod
       VCID: 313EE5E771A5BDE2B05-8064
    Address 6D: Trunk Elect. (J605)       Labels:| 5Q0-959-107.clb
       Part No SW: 4M0 959 107     HW: 4M0 959 107
       Component: HDSG-Modul    H12 0143
       Revision: --------    Serial number: 30078249900000 Dataset Number: 4M0909541E  0020
       Coding: 00F8
       ASAM Dataset: EV_DeckLidCONTIAU736 001010
       ROD: EV_DeckLidCONTIAU736_AU37.rod
       VCID: 70B820E3BA2FF4EAFFB-8024
    Address 74: Chassis Control (J775)       Labels:* None
       Part No SW: 4M0 907 777 J    HW: 4M0 907 777 B
       Component: Fahrwerk-SG   H35 1214
       Serial number: 1505170246  Dataset Number: 4M0909576M  0044
       Coding: B8505050F8
       Shop #: WSC 47376 001 1048576
       ASAM Dataset: EV_ChassContrContiAU426 001003
       ROD: EV_ChassContrContiAU426.rod
       Air Suspension Compressor:
       Subsystem 1 - Part No SW: 4M0 907 589 B    HW: 4M0 907 589 B
       Component: V66LFKompOLV  H06 0012
       Serial number: 00000000004130022950
       Coding: 303030
    Address 81: Gear Shift (J587)       Labels: 4MX-713-041-81.clb
       Part No SW: 4M2 713 041 D    HW: 4M2 713 041 D
       Component: GSM-LL        H07 0066
       Revision: 0L0D5012    Serial number: 20150817000501
       ASAM Dataset: EV_GSMWaehlZFAU736 001013
       ROD: EV_GSMWaehlZFAU736_AU49.rod
       VCID: 270A0BBF4F61F3526E1-8072
    Address 82: Head Up Display (J898)       Labels:* None
       Part No SW: 4M0 919 617 A    HW: 4M0 919 617 A
       Component: HeadUpDisplay H26 1524
       Coding: 5F00C0
       ASAM Dataset: EV_HudNSEIKAU736 001012
       ROD: EV_HudNSEIKAU736_AU73.rod
    Address 84: Night Vision (J853)       Labels:* Redir Fail!
       Part No SW: 4M0 907 547 A    HW: 4M0 907 547
       Component: NV-ECU-Gen3   H08 0025
       Serial number: 629228400201523
       Coding: 200111
       ASAM Dataset: EV_NightVisioG3AUTOLAU736 001001
       ROD: EV_NightVisioG3AUTOLAU736_AU73.rod
       Night vision system camera:
       Subsystem 1 - Part No SW: 4G0 980 552     HW: 4G0 980 552
       Component: NV-CAM-Gen3  H03 0006
       Serial number: 623466500F1522300246
    Address 8B: Adaptive Cruise 2 (J850)       Labels: 4M0-907-541.clb
       Part No SW: 4M0 907 541 C    HW: 4M0 907 541
       Dataset Number: 4M0909885G  0020
       ASAM Dataset: EV_ACC2BOSCHAU736 001016
       ROD: EV_ACC2BOSCHAU49X_001.rod
       VCID: 2E04FE9B609BA21AAD7-807A
    Address A5: Frt Sens. Drv. Assist (R242)       Labels:* None
       Part No SW: 4M0 907 217 C    HW: 4M0 907 217 A
       Component: BVS           H12 0030
       Dataset Number: 4M0909466H  0033
       Coding: 0407030600000402034023B7CD0000B4B0F0C020F280
       ASAM Dataset: EV_BVSMLBevKOSTAAU736 002022
       ROD: EV_BVSMLBevKOSTAAU736_AU73.rod
    1 Fault Found:
    1123600 - predictive route data
              B1630 02 [008] - Signal Failure
              Intermittent - Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 147
                        Mileage: 57473 km
                        Date: 2023.09.09
                        Time: 16:38:36
                        Control Module temperature: 48 °C
                        Voltage terminal 15: 14.40 V
    Address AC: Reductant Control (J880)       Labels: 4M0-907-355.clb
       Part No SW: 4M0 907 355     HW: 4M0 907 355
       Component: SCR-Stg-G3H10 0003
       Dataset Number: 4M0909571F  0013
       ASAM Dataset: EV_RDCMINERGAU736 005009
       ROD: EV_RDCMINERGAU736_AU49.rod
       VCID: 6E843E9BA01BE21AED7-803A
    Address BB: Door Rear Drv (J388)       Labels:* None
       Part No SW: 4M0 959 795 D    HW: 4M0 959 795 C
       Component: TSG HFS       009 0038
       Serial number: 0000165644107  Dataset Number: 4M0909897E  0023
       Coding: 004D980000010082000830A0
       ASAM Dataset: EV_DCU2RearDriveMAXHCONT 001005
       ROD: EV_DCU2RearDriveMAXHCONT_VW37.rod
       VCID: 41DEB527C1052D62405-8014
    Address BC: Door Rear Pass (J389)       Labels:* None
       Component: TSG HBFS      009 0038
       Serial number: 0000165645077  Dataset Number: 4M0909896E  0023
       ASAM Dataset: EV_DCU2RearPasseMAXHCONT 001005
       ROD: EV_DCU2RearPasseMAXHCONT_VW37.rod
    Address CA: Sunroof (J245)       Labels:| 4M0-907-594.clb
       Part No SW: 4M0 907 594     HW: 4M0 907 594
       Component: SAD_STG_1     011 0003
       Dataset Number: 4M0909469E  0013
       Coding: 708000053602
       ASAM Dataset: EV_SunRoofCONTIAU736 004008
       ROD: EV_SunRoofCONTIAU736_004.rod
       VCID: 73B22FEFCB39CFF2029-8026
    Address CB: Rear Axle Steering (J1019)       Labels:* None
       Part No SW: 4M0 909 145 G    HW: 4M0 909 145 D
       Component: HAL_MLBevoH07 0607
       Revision: --------    Serial number: CCC_007_D_07_03 Dataset Number: 4M0909904H  0016
       Coding: 00852C
       ASAM Dataset: EV_RearAxleSteerZFAU736 005010
       ROD: EV_RearAxleSteerZFAU736_005.rod
       VCID: 3430ECF38EB788CADB3-8060
    Address CF: Lane Chge Asst 2 (J770)       Labels: None
       Part No SW: 4M0 907 590     HW: 4M0 907 590
       Revision: --------
       Coding: 5EE002
       Shop #: WSC 00000 000 00000
       ASAM Dataset: EV_RearRadarS2BoschAU736 001015
       ROD: EV_RearRadarS2BoschAU736.rod
       VCID: 6FBA239FA711EB12E61-803A
    Address D6: Light Ctrl Left 2 (A31)       Labels: 7PP-941-592.clb
       Part No SW: 7PP 941 592 CA    HW: 7PP 941 592 C
       Component: LED1L         H09 2002
       Dataset Number: 4M0909471C  0011
       ASAM Dataset: EV_LEDModLeftMELCOAU736 001004
       ROD: EV_LEDModLeftMELCOAU736_AU73.rod
       VCID: 196E3D47091555A2E85-804C
    Address D7: Light Ctrl Right 2 (A27)       Labels: 7PP-941-592.clb
       Component: LED1R         H09 2002
       Dataset Number: 4M0909472C  0011
       ASAM Dataset: EV_LEDModRightMELCOAU736 001004
    End----------(Elapsed Time: 03:03, VBatt start/end: 12.2V/12.1V)-----------
  3. Re: Adblue fault ??
    134 Post(s)
    2007 Post(s)
    We did one of these a couple of weeks ago, it required a new updated reductant tank, ECU and filler pipe costing £1532.16 plus 15 litres of AdBlue, labour and highly important engine ECU software update number XCHGACA015. If you look at the sensor pressure reading it is -0.5 Bar, this makes the engine inject far too much reductant which fills the system with urea crystals and causes thousands of pounds damage on top of the new tank.
  4. Re: Adblue fault ??
    Feb 2019
    MIDDLESBROUGH UK
    28 Post(s)
    Hi Crasher,
    thanks for your response.
    That's what I was afraid of!
    Dis you actually find out what was wrong with the old AdBlue tank or just bin it?
    I was wondering if it was the pump or pressure sensor or a software issue.
    I know that the pump unit is not available to buy separately as it was on older cars but can it still be removed from the tank or is it sealed in?
    Grasping at straws I know but I from the old school like you.
    Don't bin it if it can be fixed.
  5. Re: Adblue fault ??
    134 Post(s)
    2007 Post(s)
    I am old school but I also have to guarantee a fix to as high a possible percentage as possible so when a large component has no spares, needs an ECU and a software update plus a TPI tells you what to do to guarantee a fix, I do it. IF I had the time to strip one down and analyse it I would but I wouldn’t get paid for it if I failed and I need to put the Vodka on the table.
  6. Re: Adblue fault ??
    Feb 2019
    MIDDLESBROUGH UK
    28 Post(s)
    I fully understand where you are coming from, You have a reputation and business to think of.
    We are very lucky to have people like you on the forum who are prepared to give up their spare time to help us mortals.
    I'm retired now (69) and time is my only free asset and lucky enough to have a reasonably equipped garage with a lift.
    If the unit is scrap then I have nothing to lose by investigating the fault.
    If the worst comes to the wors, are these the right parts I need ?
    Tank 4M0 907 878 CP £1139.40p
    Filler neck 4M0 131 963 F £111.54p
    Control unit 4M0 907 355 D £472.20p ( not sure about control unit as there is quite a difference in price from one to the other?)
    Fitting doesn't seem any problem just the programming side.
    Do you know if I can I do any of it with VCDS ? or if I need to get help will the car be drivable with the new bits fitted but not yet programmed ,
    although faults will probably be thrown up?
    Or perhaps I can get this done remotely by someone like Andy who has helped me enormously in the past.
    I have tried to find a copy of the relevant TPi you mentioned and the 1-89 parts bulletin with out success is there anything I need to know in these?
    I do appreciate your help! And will let you know how I get on.
    Best wishes.
  7. Re: Adblue fault ??
    Feb 2019
    MIDDLESBROUGH UK
    28 Post(s)
    Just pumped up hoping for a response, please.
  8. Re: Adblue fault ??
    134 Post(s)
    2007 Post(s)
    Part numbers look right (got COVID) but the Software Version Management code XCHGACA015 has to be entered in ODIS.
  9. Re: Adblue fault ??
    Feb 2019
    MIDDLESBROUGH UK
    28 Post(s)
    Thanks for that.
    Hope you get shot of that soon.
  1. Question Another AdBlue system fault...
    By artheb in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 19-03-2021, 08:42 AM
  2. Q7 adblue system fault, no restart after x kms
    By Kiwimellonman in forum Q7 - 4M Forum - 2016 -
    Last Post: 02-02-2021, 04:48 PM
  3. Adblue System Fault - No Restart 1000km
    By Silane in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 09-08-2020, 04:16 PM
  4. 2015 Allroad Adblue Fault
    By KevTrem in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 04-10-2018, 08:24 AM
  5. Adblue fault
    By PaulSpence in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 04-01-2017, 11:07 PM
