Thread: Brake Pads for 2015 BiTDI 320p
Results 1 to 10 of 19
  1. Brake Pads for 2015 BiTDI 320p
    Apr 2014
    London, UK
    12 Post(s)
    I need to get the brake pads replaced but struggling to find which ones I need to order. I read there was a code somewhere but don't have a service book or see any labels on the spare wheel.
    When I put the car registration in on various sites, I get multiple options so have no idea which ones. Also, not sure if I need ones with sensors or not.
    I know my car has some sort of sensor because the Brake Pad light is currently on.
    /Edit: I found a list of codes near the spare wheel and after entering them on http://prsearch.planetvag.com these two entries seem like the relevant ones:
    PRCode: 1LL = Disc brakes front
    PRCode: 2EA = Disc brakes rear
    Still not sure if I need pads with senors or not though.
  2. Brake Pads for 2015 BiTDI 320p
    Oct 2018
    London
    29 Post(s)
    U have a brake pad wear sensor on front and rear left side of ur car.
    Your cars front front disc size are 356mm and rear (off the top of my head) are 320mm. All A7s have the same size rears from what I remember
    I installed EBC slotted disc and EBC redstuff pads all round really happy with them.
    then brought genuine sensors.
  3. Re: Brake Pads for 2015 BiTDI 320p
    Apr 2014
    London, UK
    12 Post(s)
    I don't believe I need to replace discs so just looking for new pads. Sounds like I need ones with sensors.
  4. Re: Brake Pads for 2015 BiTDI 320p
    2016 Post(s)
    What is the VIN? With modern brakes, only replacing the pads is a very bad idea and something we refuse to do due to comeback complaints such as dull response and squealing.
  5. Re: Brake Pads for 2015 BiTDI 320p
    Oct 2018
    London
    29 Post(s)
    Quote Originally Posted by hshah View Post
    Buy the pads u want and the sensors can be added. They don’t come built into the pad. There will be a 1 front and 1 rear
  6. Re: Brake Pads for 2015 BiTDI 320p
    Apr 2014
    London, UK
    12 Post(s)
    Quote Originally Posted by crasher View Post
    what is the vin? With modern brakes, only replacing the pads is a very bad idea and something we refuse to do due to comeback complaints such as dull response and squealing.
    wauzzz4g4gn075321
  7. Re: Brake Pads for 2015 BiTDI 320p
    Apr 2014
    London, UK
    12 Post(s)
    Quote Originally Posted by Bishop187 View Post
    It's the sensor stuff which I found confusing. When searching for pads, the options were:
    - inc wear warning contact
    - prepared for wear indicator, exc wear warning contact
    - not prepared for wear indicator
    Does the existing sensor need to be replaced too? Which of the above would I need to get?
  8. Brake Pads for 2015 BiTDI 320p
    Oct 2018
    London
    29 Post(s)
    Do you have a brake warning light on ur dash? If you do them at least one of the two sensors have been triggered
    U may only need to replace one, depending on which one has been triggered
    Buy pads that come with sensors or that are prepared for sensors. That way u can buy sensors and fit them too
  9. Re: Brake Pads for 2015 BiTDI 320p
    Apr 2014
    London, UK
    12 Post(s)
    Yep, the light has been on for a few weeks now. I got the pads checked and both fronts and rears need replacing.
    Right, I think you've answered what I was confused about. I need either inc wear contact ones or prepared ones but would have to buy sensors for the latter.
    In terms of the pads themselves, do I just need to make sure the fronts are 1LL and rears 2EA?
  10. Re: Brake Pads for 2015 BiTDI 320p
    Oct 2018
    London
    29 Post(s)
    Where are you buying them from. Most decent websites with just let you put ur reg number in and then shows u all the compatible pads or just make sure the fronts work with 356mm and rears 320mm
  1. 2015 euro A6 3.0 biTdi EGR valve location
    By javyb in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 20-11-2023, 01:25 PM
  2. Question 2015 BiTDI Oil Change
    By hshah in forum A7 - S7
    Last Post: 18-06-2021, 07:01 PM
  3. Brake pads & discs for 64 BiTDi
    By wizbongre in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 28-02-2020, 10:48 AM
  4. Changing brake pads - Bitdi
    By Justinos in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 04-06-2019, 05:12 PM
  5. Question A6 BiTDI (2015) - First Service
    By hshah in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 11-04-2017, 11:49 AM
