Thread: p0087 & Rough Idle
Results 1 to 10 of 18
  1. Lightbulb p0087 & Rough Idle
    May 2023
    Durham, UK
    Hi all,
    Hoping someone could shed some ideas on the current state of my 2012 2.0 TDI Q5.
    • Issue began with limp mode and p0087, fuel filter and glow plugs were replaced.
    • No change. HPFP was checked for particles, looked immaculate.
    • High pressure rail sensor and valve replaced. HPFP regulator replaced. Same issue.
    • Garage replaced injectors seals/washers.
    • Now there is a rough idle which disappears when ""[*IDE02703*] Reset learned values quant. meter. unit and press. contr. valve"" is activated, p0087 remains
    Could the HPFP have died without showing particles? Are the injectors dead?
    Any help is appreciated,
    Nic
  2. Re: p0087 & Rough Idle
    Jul 2008
    Lisburn
    16 Post(s)
    approach seems to be a bit hap hazzard - surely the first thing to do would be to read the live data and test the pressure?
    If your HPFP went it wouldn't run at all..
    Stewart
    1986 coupe quattro (kv)
  3. Re: p0087 & Rough Idle
    Mar 2010
    Derry ireland
    63 Post(s)
    can you post up your reg no or engine code
  4. Re: p0087 & Rough Idle
    May 2023
    Durham, UK
    Should have been more specific regarding the diagnostics, my apologies.
    The car runs and moves, however any acceleration gives the common code saying the pressure isn't high enough.
    The fuel pressure reg error only very occasionally shows.
    Sorry about the text dump, was not sure how to upload it seperatley.
    Address 01: Engine (J623-CGLB) Labels:. 03L-906-018-CGL.clb
    Part No SW: 03L 906 018 ML HW: 03L 906 018 DN
    Component: R4 2.0l TDI H24 9977
    Revision: 45H24---
    Coding: 2A194012040703080000
    Shop #: WSC 27671 001 1048576
    ASAM Dataset: EV_ECM20TDI01103L906018ML 003004
    ROD: EV_ECM20TDI01103L906018DG.rod
    VCID: 000F35079B030A8602-8054
    3 Faults Found:
    5211 - Fuel Rail/System Pressure
    P0087 00 [167] - Too Low
    MIL ON - Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 156800 km
    Date: 2023.05.10
    Time: 13:53:52
    Engine speed: 2086.50 /min
    Normed load value: 68.2 %
    Vehicle speed: 2 km/h
    Coolant temperature: 30 °C
    Intake air temperature: 16 °C
    Ambient air pressure: 970 mbar
    Voltage terminal 30: 14.660 V
    Unlearning counter according OBD: 80
    Fuel temperature: 18.1 °C
    Mean injection quantity: 29.47 mg/stroke
    Rail pressure regulation: status-Bits 0-7: 5
    Fuel high pressure: actual value: 700800 hPa
    High fuel pressure: specified value: 1.3128e+006 hPa
    Pressure control valve adaptation factor: 1.0000
    Fuel level: 10.00 l
    5212 - Fuel Rail/System Pressure
    P0087 00 [039] - Too Low
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 156800 km
    Date: 2023.05.10
    Time: 13:53:53
    Engine speed: 2053.50 /min
    Normed load value: 97.6 %
    Vehicle speed: 5 km/h
    Voltage terminal 30: 14.600 V
    Mean injection quantity: 22.75 mg/stroke
    Fuel high pressure: actual value: 713000 hPa
    High fuel pressure: specified value: 1.2411e+006 hPa
    Fuel level: 10.00 l
    5175 - Fuel Pressure Regulation
    P1065 00 [036] - Regulation Discrepancy
    Intermittent - Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 156800 km
    Date: 2023.04.21
    Time: 17:40:43
    Engine speed: 2490.50 /min
    Normed load value: 32.2 %
    Vehicle speed: 0 km/h
    Coolant temperature: 10 °C
    Intake air temperature: 9 °C
    Ambient air pressure: 980 mbar
    Voltage terminal 30: 13.400 V
    Unlearning counter according OBD: 40
    Engine status: COENG_RUNNING
    Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 3
  5. Re: p0087 & Rough Idle
    May 2023
    Durham, UK
    J623-CGLB
    I have also uploaded a chunk of the scan.
    Cheers,
    Nic
  6. Re: p0087 & Rough Idle
    Jul 2008
    Lisburn
    16 Post(s)
    anyone look at the pump in the tank? run an output test on it to make sure the HPFP is getting fuel to pressurise?
    Stewart
  7. Re: p0087 & Rough Idle
    131 Post(s)
    1976 Post(s)
    After changing the fuel filter, was the system bled using the intank lift pump for at least 30 seconds before attempting to start the engine?
  8. Re: p0087 & Rough Idle
    May 2023
    Durham, UK
    Yes it was primed after fuel filter installation. Apologies for the delay in response.
  9. Re: p0087 & Rough Idle
    May 2023
    Durham, UK
    I have just today ran an output test and achieved 2,800ml over 60 seconds (online suggests 3000ml/minute) so I assume this is good enough in regards to room for error. I then added some fuel to the tank to get the car over a 1/4 full as I had heard people encountering p0067 under a quarter of a tank. Still no change and code is immediately thrown upon pulling away.
  10. Re: p0087 & Rough Idle
    131 Post(s)
    1976 Post(s)
    Looks to me like you need a new HPFP.
  1. Very rough idle B5.5, 1.9 tdi, AWX
    By Metallurgix in forum Passat - B5 Forum - 1997 -2005
    Last Post: 11-04-2018, 09:35 PM
  2. 06 Audi A6 2.0 TDI Rough Idle / Jumpy Idle
    By nizzex in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 24-11-2015, 07:53 PM
  3. Rough Idle
    By tosh123 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 19-03-2013, 03:52 PM
  4. Please Help Very Rough Idle
    By kasper1287 in forum Golf MK4 - 1999 - 2004
    Last Post: 06-03-2010, 05:34 PM
  5. Question A4 2.6 rough idle/rough at high rpm
    By teccyjim in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 13-09-2008, 07:22 PM
