Thread: P0101 MAF Implausible Signal - 000257
Results 1 to 10 of 12
  1. P0101 MAF Implausible Signal - 000257
    Oct 2012
    Ireland
    Code:
    Tuesday,15,August,2023,19:28:59:41611
    VCDS Version: 23.3.1.0 (x64)
    Data version: 20230421 DS346.2
    Ross-Tech: Home
    Mileage: 332430km-206562mi   Repair Order: 15thAug23
    Chassis Type: 1K-VW35 (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 56 76
    Mileage: 332430km-206562miles
    01-Engine -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: Malfunction 0010
    37-Navigation -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: Malfunction 0010
    52-Door Elect, Pass. -- Status: Malfunction 0010
    56-Radio -- Status: OK 0000
    76-Park Assist -- Status: OK 0000
    Address 01: Engine        Labels: 03G-906-016-BKD.clb
       Part No SW: 03G 906 021 PP    HW: 03G 906 021 AN
       Component: R4 2,0L EDC  000SG  4661
       Revision: --H08---    Serial number: VWX7Z0H23N48PV
       Coding: 0000072
       Shop #: WSC 00450 210 62666
       VCID: 7CF78F313F49EC7397-8028
       VINID: 9E69EAAAA05BA889C22010C018AABB9A00
    1 Fault Found:
    000257 - Mass Air Flow Sensor (G70)
                   P0101 - 000 - Implausible Signal
                 Freeze Frame:
                        Fault Status: 01110000
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 255
                        Mileage: 332161 km
                        Time Indication: 0
                        Date: 2000.00.00
                        Time: 06:32:46
                 Freeze Frame:
                        RPM: 1638 /min
                        Speed: 86.0 km/h
                        Temperature: 15.3°C
                        Absolute Pres.: 1050.6 mbar
                        Mass Flow: 31.29 g/s
                        (no units): 0.78
                        Temperature: 84.6°C
    Readiness: 1 1 0 0 0
    Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.clb
       Part No SW: 1K0 907 379 AC    HW: 1K0 907 379 AC
       Component: ESP FRONT MK60      0101
       Revision: 00H11001
       Coding: 0023170
       Shop #: WSC 01279 785 00200
       VCID: 73E5A40D1217A30BC6-8026
    No fault code found.
    Address 08: Auto HVAC        Labels: 1K0-820-047.lbl
       Part No SW: 1K0 820 047 HN    HW: 1K0 820 047 HN
       Component: Climatic PQ35   142 1111
       Revision: 00142031    Serial number: 00000000000000
       Shop #: WSC 00000 000 00000
       VCID: 77FD901D066FCF2BFA-8022
    Address 09: Cent. Elect.        Labels:. 3C0-937-049-30-H.lbl
       Part No SW: 3C0 937 049 AJ    HW: 3C0 937 049 AJ
       Component: Bordnetz-SG     H54 2202
       Revision: 00H54000    Serial number: 00000008088724
       Coding: E5898F2700041500471400001400000000087F075C000100000000000000
       Shop #: WSC 12345 785 00200
       VCID: 71E9AE05680B911B34-8024
       Subsystem 1 - Part No: 1K2 955 119 E  Labels: 1KX-955-119.CLB
       Component: Wischer 260208 021  0501
       Coding: 00038805
       Shop #: WSC 12345
       Subsystem 2 - Part No: 1K0 955 559 AF  Labels: 1K0-955-559-AF.CLB
       Component: RLS     120308 046  0204
       Coding: 02306085
       Shop #: WSC 12345
    1 Fault Found:
    01496 - Bulb for Fog-Lamps; Left (L22)
                010 - Open or Short to Plus - Intermittent
                 Freeze Frame:
                        Fault Status: 00101010
                        Fault Priority: 4
                        Fault Frequency: 1
                        Reset counter: 80
                        Mileage: 331127 km
                        Time Indication: 0
                        Date: 2005.09.13
                        Time: 31:63:63
                 Freeze Frame:
                            ON
                        Voltage: 14.20 V
                            ON
                            ON
                            OFF
                            OFF
                            OFF
    Address 15: Airbags        Labels: 1K0-909-605.lbl
       Part No SW: 1K0 909 605 T    HW: 1K0 909 605 T
       Component: 38 AIRBAG VW8   020 2300
       Revision: 05020000    Serial number: 0038PD1UHYFH
       Coding: 0013112
       Shop #: WSC 01269 785 00200
       VCID: 3D71423564D3257BE0-8068
       Subsystem 1 - Serial number: 6332MSME2A2114775
       Subsystem 2 - Serial number: 6342MSME2A2114563
       Subsystem 3 - Serial number: 6352QSME536D1859R
       Subsystem 4 - Serial number: 6362QSME53392F71N
    Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
       Part No SW: 1K0 953 549 BN    HW: 1K0 953 549 BN
       Component: J0527           752 0100
       Coding: 0000012
       VCID: 7F0D783D2E5FF76BB2-802A
    4 Faults Found:
    00576 - Terminal 15
    00883 - Ignition Switch (D) Terminal S
    00884 - Ignition Switch (D) Terminal X
    01744 - Ignition Switch Terminal P (D)
    Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
       Part No SW: 1K0 920 964 B    HW: 1K0 920 964 B
       Component: KOMBIINSTRUMENT VDD 1212
       Revision: V0002000    Serial number: VWX7Z0H23N48PV
       Coding: 0005403
       Shop #: WSC 00000 011 205300
       VCID: 2C577F718FA9BCF347-8078
    Address 19: CAN Gateway        Labels:. 1K0-907-530-V3.clb
       Part No SW: 1K0 907 530 L    HW: 1K0 907 951
       Component: J533  Gateway   H07 0052
       Revision:   H07 01    Serial number: 290208F2001431
       Coding: E9801F0E4002020001
       Shop #: WSC 44673 233 19254
       VCID: 306F6B01A381D8137B-8064
    Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
       Component: IMMO            VDD 1212
    Address 37: Navigation (J794)       Labels:| 1K0-035-27x-37.clb
       Part No SW: 3C8 035 279 M    HW: 3C8 035 279 M
       Component: RNS315-EU   H70 0407
       Serial number: VWZAZ2N0350421
       Coding: 0400040104000F0000019002
       Shop #: WSC 00015 115 00000
       ASAM Dataset: EV_RNS315EUV2UDS 001705
       ROD: EV_RNS315EUV2UDS.rod
       VCID: 35615A1594E3FD3B28-8060
       Data carrier:
       Subsystem 1 - Part No: 3AA 919 866
       Component: EUR_W_V4  0050
    2 Faults Found:
    1048629 - Aux IN Socket
              B1104 13 [009] - Open Circuit
              Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Status: 00000001
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 28
                        Mileage: 331495 km
                        Date: 2000.00.00
                        Time: 20:18:45
    1048636 - Digital Radio Antenna
              B1103 13 [009] - Open Circuit
                 Freeze Frame:
                        Fault Priority: 5
                        Fault Frequency: 1
                        Reset counter: 70
                        Mileage: 257558 km
                        Date: 2000.00.00
                        Time: 11:22:28
    Address 42: Door Elect, Driver        Labels:. 1K0-959-701-MAX3.clb
       Part No SW: 1K0 959 701 N    HW: 1K0 959 701 N
       Component: Tuer-SG         006 1208
       Coding: 0000564
       VCID: 3979562570FB195BCC-806C
    1 Fault Found:
    00109 - Left Mirror Turn Signal Lamp (L131)
    Address 44: Steering Assist        Labels: 1Kx-909-144-G2V3.clb
       Part No: 1K2 909 144 M
       Component: EPS_ZFLS Kl.069 H08 1901
       Shop #: WSC 00000 028 00001
       VCID: 36635D1941E5F62321-8062
    Address 46: Central Conv.        Labels:. 1K0-959-433-MIN.clb
       Part No: 1K0 959 433 AJ
       Component:    KSG              0401
       Coding: 00C802085B2D840548DAC69010CC
       VCID: 78FF93210B71C053F3-802C
       Subsystem 1 - Part No: 1K0 951 605 D
       Component: LIN BACKUP HORN H08 9001
       Subsystem 2 - Part No: 1K0 951 178 A
       Component: Neigungssensor  003 0203
       Subsystem 3 - Part No: 1K0 951 178 A
       Component: Innenraumueberw.003 0203
    Address 52: Door Elect, Pass.        Labels:. 1K0-959-702-MAX3.clb
       Part No SW: 1K0 959 702 N    HW: 1K0 959 702 N
       Coding: 0000820
       VCID: 3A7B492975FD1243C5-806E
    2 Faults Found:
    00097 - Front Passengers Central Locking (Safe) Motor (V162)
    00929 - Locking Module for Central Locking; Front Passenger Side (F221)
                008 - Implausible Signal
    Address 76: Park Assist        Labels: 1K0-919-283.lbl
       Part No: 1K0 919 283 A
       Component: 22 Einparkhilfe     0101
       VCID: 2D517275B4B3B5FB50-8078
    End-------------------------(Elapsed Time: 01:46)--------------------------
    Address 01: DTCs cleared
    I have a fault as seen on my VCDS log, relating to the MAF sensor. I have had faulty wiring at the boost sensor which I repaired but still have the MAF error. It doesn't go into limp mode when the EML is displayed. I replaced the MAF too and same problem still here.
    I have a cycle where I get the EML on after about 100 miles after I clear the fault code.
    Can anyone tell me what volts I should have on the wires to my MAF sensor and what wires they are?
    Which wire is the ground, etc...
    I think I need to check for a 12v, 5v and an earth, what's the other wire do?
    With VCDS can I check what value the MAF is reading and what should it be reading, can anyone tell me?
    Is implausible signal an electrical issue with the wiring or is this terminology also used to describe if the amount of air measured by the MAF is too little or too high? Or in the latter, where the amount of air is measured to be too low / high would it state something like Too low / Too high air pressure, etc?
  2. Re: P0101 MAF Implausible Signal - 000257
    Oct 2012
    Ireland
    My MAF is a 5pin connector but only has 4 wires.
    Would someone be able to tell me, is the MAF on a bkd 2L of the frequency type or varying type. If I put my multimeter on the signal wire should it's volts go up and down as I rev the car and let the revs off?
    I'll try dig out it's wiring diagram now on ELSAWIN.
    I found the wiring diagram for the MAF sensor to the ECU, as in pic below, from Elsawin. It gives me the 4 wire colours and the pins they go to on the ECU and Maf connector. G70 is the MAF in the below pic.
    However, it doesn't tell me what each individual wire actually does / is, can anyone here tell me?
  3. Re: P0101 MAF Implausible Signal - 000257
    131 Post(s)
    1976 Post(s)
    Pin 2 is the power feed from the dash side fuse SC8 current track 95 on page 8 goes to curent track 23 on page 3, this is for a May 2006 onwards BKD.
  4. Re: P0101 MAF Implausible Signal - 000257
    Oct 2012
    Ireland
    Thanks Crasher. Could you tell me should the voltage on the signal wire fluctuate as I rev the car?
    Also, is there a value I can compare and check against the Maf reading in VCDS to see ifs giving a realistic or in spec value?
  5. Re: P0101 MAF Implausible Signal - 000257
    Oct 2012
    Ireland
    I'm still having this issue.
    1 Fault Found:
    I checked the wiring values at the pins of the Maf, here's their results. It's a 5pin Maf but only 4 wires actually used:
    1 = No wire
    2 = 14v
    3 = Earth
    4=5v
    5= Earth
    When I rev the car the pin4 5V doesn't fluctuate in value, it just stays at 4.99/5v. Is this behaving correctly or should it's voltage decrease / increase from 0-5v range?
    When I disconnect the MAF with the car running at idle what should happen? And also when driving with MAF disconnected what should happen?
    Is there anything else I can check? Maybe something in VCDS to help highlight a problem?
  6. Re: P0101 MAF Implausible Signal - 000257
    131 Post(s)
    1976 Post(s)
    Where did the new Air mAss Meter come from?
  7. Re: P0101 MAF Implausible Signal - 000257
    Oct 2012
    Ireland
    It came from a reputable parts supplier, NTK brand. I know everyone says only use a genuine VW one but it's in it now.
    I don't really see the point of putting another MAF in the car without testing the basics of this MAF first. No one seems to know if the 5v should fluctuate between 0-5v when the car is revved? Some MAF's behave like this, some don't from what I have researched but I don't know which behaviour our VW's or more specifically a BKD golf should show? Do you know, Crasher? There's no point putting a genuine MAF in now if I can't first determine if the 5v should fluctuate when revved.
    I don't think this is a wiring issue now, I have checked and repaired the wires and they seem to be operating properly and showing as earths and 12v + 5v as I believe they should. Just not sure if the 5v should fluctuate or not?
  8. Re: P0101 MAF Implausible Signal - 000257
    Oct 2012
    Ireland
    Ok, from reading more into this MAF testing, I see the 2 types of MAF output can be either a varying 0-5v range or the output could be a digital pulse which I will need to measure with the Hz hertz setting on my multimeter whilst revving the engine. I'll check that tomorrow with the engine ideling and being revved.
    So my 4 wires seem to be:
    - constant 12v for the MAF itself
    - earth for the Maf's 12v
    - output signal wire 5v or digital pulse
    - earth for the output signal
    Does these 4 wires that I am assuming relate to the above make sense, seem correct? 2 earths, a 12v and a 5v output wire?
    Is the 12v supply for the intake temperature part of the sensor, these VW MAF's have an inbuilt air temp sensor I think?
  9. Re: P0101 MAF Implausible Signal - 000257
    Oct 2012
    Ireland
    I tested the MAF readings this evening, it seems to be giving good values. And the grams/second g/s value at idle doubled as I doubled the revs as I believe it should.
    My engine off reading was 0.113g/s. My idle reading was 1.009lb/min or 7.55g/s and at 1800 revs or double idle approx, the reading doubled to 2.017lb/min or 15g/s. I believe if you double the revs the Maf value should double also.
    3000 Rpm read value of 5lb/min = 38g/s.
    I'll check the Hertz frequency reading with my multimeter tomorrow.
    I'm suspecting a hose leak now, I see my Intercooler turbo hose where it goes into the EGR or Anti shudder valve is loose, the tab is worn and the hose won't stay in, I've a new hose ordered but will be a week arriving. I have had this issue before this hose became loose so I don't think it's the root cause but obviously it's not helping so I'll fix that and look for more leaks, etc..
    I think these readings / values I obtained this evening are indicating a properly working MAF sensor, what do ye folk think? Anyone have the VW spec values to hand to compare with?
  10. Re: P0101 MAF Implausible Signal - 000257
    Oct 2012
    Ireland
    I replaced the intercooler hose with a new one between Egr / Asd and the intercooler hard pipe and cleared the code but the EML came back after about 100 miles as usual. So i can rule out the hose.
    I would of thought they're be loads of knowledgeable folks on this forum for helping with troubleshooting MAFs, A VW Maf is a very common failure isn't it. Or is it starting to look like a lot get changed unnecessarily.
    Is the face the EML and Maf code always comes back on around the same amount of driving time after clearing suggesting it's an electrical issue?
  1. Replies: 14
    Last Post: 07-10-2023, 12:01 PM
  2. Nox Sensor (G295) Implausible Signal P1071
    By sam8888 in forum Polo - Derby - Lupo - Fox
    Last Post: 19-07-2020, 07:17 PM
  3. Question mk4 golf 1.6 g62 implausible signal
    By sean gibson in forum Golf MK4 - 1999 - 2004
    Last Post: 04-12-2009, 10:55 AM
  4. Brake Switch (F): Implausible Signal
    By PoloMatch2001 in forum VCDS - Help Requests
    Last Post: 08-06-2009, 09:22 PM
  5. MAF Implausible Signal
    By idawson in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 19-10-2007, 02:25 PM
