Thread: Just bought an A3. Advice welcome
Results 1 to 10 of 11
  1. Just bought an A3. Advice welcome
    Mar 2018
    London
    Hi everyone.
    I just bought an A3 Spotback 1.6 2006 (8PA AA4 version from the sticker) in very good shape and would appreciate your wide advice on tricks, extra maintenance and anything else you can think of.
    I will do a full service next week, so my first question:
    I've always preferred Quantum oil to the recommended Castrol. What do you think?
    Quantum platinum 10W40? The manual only states VW 503 00 or VW 504 00.
    Second question if I may:
    Before I go on the hunt, where's the fuel filter on this car?
    And finally: I looked at the toothed belt and it seems too easy to replace than any other Audi I owned before.
    Is it really easy or there's a surprise waiting when replacing belt, pulleys, tensioner and water pump?
    Thank you in advance for your assistance.
  2. Re: Just bought an A3. Advice welcome
    Mar 2018
    London
    Forgot to mention that the timing belt cover is missing.
    I tried online but can't find it.
    Scrap yard?
  3. Re: Just bought an A3. Advice welcome
    134 Post(s)
    2013 Post(s)
    £28.27 and available from and VAG group dealer or TPS under part number 06B 109 123 H, assuming it is a BSE, BSF or BGU engine or you can get a used one for about £8 less… some fleaBay sellers don’t half extract the urine
  4. Re: Just bought an A3. Advice welcome
    Mar 2018
    London
    Hi, thanks for that.
    Had a better look at the engine yesterday and the cover is there.
    I got confused with another A3 I looked at.
    I must've seen a dozen A3 for sale last week, a very stressful experience, especially when cars are described as "immaculate conditions" and then you're presented a scrap.
    I looked at a few 2011/2013 models and I had to question how they would expect to sell them.
    Ripped seats, scratches and dents everywhere, bold tyres, engine leaking from everywhere, brake pads down to the bone and one of them was missing a third gear, it wouldn't engage.
    FFS!
    How do they pass the mot???
  5. Re: Just bought an A3. Advice welcome
    134 Post(s)
    2013 Post(s)
    Quote Originally Posted by Jimmy2007 View Post
    In the trade it is known as “dial a MOT” which covers various ways a fraudulent MOT can be obtained, it isn’t difficult or expensive.
  6. Re: Just bought an A3. Advice welcome
    Mar 2018
    London
    Hi everyone, so I started working on the A3 and found a couple of minor things that I can't figure out.
    The rear subwoofer, hidden in the boot, is crackling.
    I cleaned the connection and there's no clear sign of damage to the speaker, in fact it looks like new.
    Is it a matter of just disconnect it and forget about it or can it be fixed?
    Also, the 2 speakers on the rear left door are totally dead.
    Again, all connections are perfect and the cables passing from the pillar to the door are in perfect conditions.
    Cables cut somewhere else?
  7. Re: Just bought an A3. Advice welcome
    134 Post(s)
    2013 Post(s)
    Could be water in the rear electrics, does the rear wiper work, probably not!
  8. Re: Just bought an A3. Advice welcome
    Mar 2018
    London
    Yes, everything works perfectly.
    There's no sign of water ingress anywhere, the all area looks brand new, having being covered by the trim since new.
    By the look of the 2 screws and the clips, nobody ever took that panel off.
  9. Re: Just bought an A3. Advice welcome
    134 Post(s)
    2013 Post(s)
    What I have seen is the wiper motor washer fluid coupling leaking into the tailgate, this collects as there are no drains and then when the tailgate is opened, the accumulated fluid pours down the side frames into the C pillars and down into the side panels where the heavily salt based screen wash (formulated to “save the planet”) causes corrosion to the electrics in the so called “coupling stations”… tinder for cars.
  10. Re: Just bought an A3. Advice welcome
    Mar 2018
    London
    Ok, will double check that agai n, because I had this leak from rear washer on my passat and the boot was filling up with water, so pretty evident.
    If that is the case, do I replace the tubes going to the rear washer?
  1. Bought an A4 1.8T - Any tips/advice :-)
    By Skezza in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 01-09-2016, 10:15 AM
  2. newbie just bought A3 T fsi dsg 2006....advice please
    By jondsg in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 27-12-2012, 05:03 PM
  3. Just bought an N plate A4 and need advice!
    By kentman99 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 13-02-2010, 04:39 PM
  4. Just bought this 2.8 30v any advice?
    By 2.830v in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 01-10-2009, 09:12 PM
  5. Bought A4 2.0t Quattro SE ...... any advice
    By adskin80 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 09-06-2009, 08:29 PM
