Thread: Crankshaft Position Sensor replacement on 2006 2.0tdi A3 with DSG
  1. Crankshaft Position Sensor replacement on 2006 2.0tdi A3 with DSG
    Aug 2023
    Newry
    Hi all,
    Symptoms:
    - car randomly goes in to limp mode and occasionally cuts out when driving.
    - juddery when starting in the morning
    Diagnostics read that it's the crankshaft position sensor and I've bene quoted £950 to repair as the DSG gearbox apparently needs removed to change it. Is this true?
  2. Re: Crankshaft Position Sensor replacement on 2006 2.0tdi A3 with DSG
    134 Post(s)
    2022 Post(s)
    It is unusual for the crank SPEED sensor called a G28 (the cam sensor is for position, the G40) to come up as a code. These are evil to get at as the oil filter housing and lots of parts have to come off and then a long ball ended hex key used at an angle to remove the sensor, the last on on a Golf 5 2L PDTDI took me two days but I am old and slow. If the sensor hex cap head strips out, as can happen, that is box out and can even mean a new rear oil seal which requires a special jig to install and the sump has to come off.
  1. 1.6 petrol ALZ (B5.5) crankshaft position sensor location?
    By kevinb6 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-11-2022, 06:43 PM
  2. Replies: 4
    Last Post: 10-07-2018, 03:58 PM
  3. Replies: 1
    Last Post: 03-11-2012, 02:41 PM
  4. where is crankshaft position sensor?
    By lpg boy in forum Passat - B5 Forum - 1997 -2005
    Last Post: 15-09-2010, 05:53 PM
  5. crankshaft position sensor location
    By collym3 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 19-04-2010, 01:32 PM
