Thread: DPF Light
Results 1 to 10 of 11
  1. DPF Light
    Jun 2015
    Nuneaton, warwickshir
    7 Post(s)
    Hi All
    Just returned from a 300 odd mile trip up north over 2 days. About 20 miles from home and the dreaded DPF light came on for the first time since I have had the car (4 years but only done 18,000 miles in that time). Current mileage is 101,000 miles.
    Admittedly most of the way home was at 50MPH due to unnecessary motorway restrictions but I did get up to 70MPH on a few occasions for short periods. When I parked up there was a whirring noise from the engine for quite some time even with the engine off.
    Fortunately the car is not in limp mode but what can I do to get rid of this light?
    All advice very much appreciated.
    The car is a Q5 2015 Sline+ with 101,000 miles, 2.0TDI Triptronic.
  2. Re: DPF Light
    Jul 2008
    Lisburn
    16 Post(s)
    I dont believe that siting at 50 would restrict a regen. it does sound like it was in the process of a regen when you stopped as the fans run longer to cool things down from a higher temp.
    I know when mine is doing a regen it will sit close to 1K RPM at tick over rather than the 800 or so.
    A scan is really required to see what is going on, but with any luck it will sort itself out after a regen or 2.
    Stewart
    2012 Q5 2.0D quattro S line Plus
    1986 coupe quattro (kv)
    1972 mini 1400 100BHP A series
    2016 F-Pace Portfolio X761 2.0D 180HP
  3. Re: DPF Light
    131 Post(s)
    1974 Post(s)
    Is the DPF light still on?
  4. Re: DPF Light
    Jun 2015
    7 Post(s)
    Hi Crasher
    Yes the DPF light is still on. I just been on a short trip to the dentist and when I switched off the engine when I got there and back home the whirring was still going on and some ticking noises (light metal on metal) coming from under the centre of the car. So it sounds like its trying to do a regen.
    I did a scan the next day after returning from the long trip and this is what came up. I cleared them thinking that they were unrelated. I had seen the EGR ones many times before without triggering the DPF light. I just scanned again after the trip to the dentists and its completely clear.
    P0401
    Raw code: 0401
    ECU: Engine control unit
    Status: Pending
    OBDII: Exhaust gas recirculation (EGR) system - insufficient flow detected
    Audi: Exhaust Gas Recirculation (EGR) Flow Insufficient
    ============2==============
    3041
    Raw code: 0BE1
    ECU: 19. CAN Gateway[Archive (inactive)]
    Status: Validated and stored in non volatile memory
    Audi: Energy management active
    ============3==============
    0384
    Raw code: 0180
    Status: Pending fault present, Pending fault present during this driving cycle, Test is inhibited by other DTC, Validated and stored in non volatile memory
    Audi A1 2019; A4 2016, A5 2017, Q5 2017, A4 USA/ CAN 2016, Audi A5 USA / CAN 2016, Q5 USA/ CAN 2017; Q7 2016: B10CE00: Blower reduction due to energy management
    Audi: C101D01: Right rear ABS wheel speed sensor
    Electrical error
    Audi: B2F0600: Development code 6
    Audi: B187400: Aux. heat/ventilation
    Heater runtime exceeded
    Audi: Optical data bus
    ============4==============
    4807
    Raw code: 0012C7
    ECU: 01. Engine control unit
    Status: Test failed, Pending, Test failed since last DTC clear, Test not completed during this operation cycle
    Audi: P040100: Exhaust Gas Recirc.Flow
    Insufficient Detected
    ============5==============
    9658
    Raw code: 0025BA
    ECU: 01. Engine control unit[Archive (inactive)]
    Status: Test failed since last DTC clear, Test not completed during this operation cycle
    Audi: P204B00: Reductant Pressure Sensor Circuit Range/Performance
    ============6==============
    4807
    Raw code: 0012C7
    Status bits: 1
    Priority: 2
    Frequency: 1
    Unlearning index: 255
    Odometer: 162784 km
    Date, time: 2023.08.06 22:53:22
    ============7==============
    0955
    Raw code: 03BB
    ECU: 05. Authorization system for access and starting the engine
    Status: Pending fault present during this driving cycle, Validated and stored in non volatile memory
    Audi: Key 1
    ============8==============
    2067
    Raw code: 0813
    ECU: 5F. Electronic Information System 1[Archive (inactive)]
    Audi: C119AF7: Static AFS light
    Shut-off due to excessive temp.
    Audi: Optical Data Bus - Unauthorized Activation Request; Optical data bus illegal wake-up request
  5. Re: DPF Light
    Jun 2015
    7 Post(s)
    I also have VAG DPF Lite on my phone which is currently showing
    Soot Mass Calc = 18.14g, Regen Duration = 18 mins, Distance since last regen = 407 miles
    I probably drove it for a maximum of 18 minutes today.
    I checked this yesterday too and the Soot mass was around 26g and Regen duration was 0.
    Hope this helps
  6. Re: DPF Light
    131 Post(s)
    1974 Post(s)
    You have an AdBlue system problem, you need full VCDS.
  7. Re: DPF Light
    Jun 2015
    7 Post(s)
    Does that mean that the DPF regen is actually working correctly but due to the Adblue issue the car is misinterpreting the error?
    Can you elaborate on the Adblue problem please?
  8. Re: DPF Light
    131 Post(s)
    1974 Post(s)
    The AdBlue system can do all sorts of stupid things such as not injecting enough reductant or too much, these systems are terrible and cause huge complex issues.
  9. Re: DPF Light
    Jul 2008
    Lisburn
    16 Post(s)
    insufficient flow on the EGR - broken DPF?
    Stewart
  10. Re: DPF Light
    Jun 2015
    7 Post(s)
    Hi all
    I took the car to a friendly mechanic that I came across recently. Same guy Crasher that reset the ECU on my daughter's golf. He plugged the Q5 into his gadget (not vcds) and tried to force a regen. That failed a couple of times cos one of the temp sensors (turbocharger) was showing 0.0. So he reset the DPF by telling the car that a new dpf had been installed. That brought the temp sensor back online. He then forced a regen which revved the car at 1500 rpm for about 20 minutes. The temp reached around 600 degrees. The soot level went down to 0.12g and the car drives a little smoother. Dpf light is gone. Hope to go on long drive tomorrow so see how it behaves.
  1. Question DPF Light, Flashing Glow Plug Light & Engine Management Light on
    By Jockeyblade in forum Golf MK5 - 2004 - 2009
    Last Post: 19-02-2020, 07:34 PM
  2. R/h reverse light and rear fog light light playing up
    By Panzerdriver in forum Passat CC
    Last Post: 01-12-2017, 10:32 PM
  3. should i buy? abs light, esp light and handbrake light flashing
    By craigq in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 06-09-2011, 03:36 PM
  4. audi 53 plate esp light on abs light on handbrake light flashing
    By craigq in forum Chat - Anything with wheels
    Last Post: 03-09-2011, 08:58 PM
  5. Brake light changed diesel coil light and brake light still on
    By Manny.p in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 15-09-2010, 02:04 PM
