Thread: ABS Brakes, Steering Assist Fault Codes
  1. Question ABS Brakes, Steering Assist Fault Codes
    Aug 2023
    Sutton Coldfield
    Hi all,
    I have an ABS warning light showing on my Audi a3 8p every time I start the engine. I scanned the car with VCDS and received quite a few faults, but I am unsure where to start. Any insight would be great. Thanks
    Code:
    Chassis Type: 8P-AU35 (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 61
    VIN: _______________   Mileage: 313800km-194986miles
    01-Engine -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    42-Door Elect, Driver -- Status: Malfunction 0010
    44-Steering Assist -- Status: Malfunction 0010
    56-Radio -- Status: OK 0000
    61-Battery Regul. -- Status: OK 0000
    Address 01: Engine (J623-CAYC)       Labels:. 03L-906-023-CAY.clb
       Part No SW: 03L 906 023 M    HW: 03L 906 023 L
       Component: R4 1.6l TDI   H23 9979
       Revision: --H23---    Serial number: AUX7Z0J0FNB094 CVN: 4F2DF892
       Coding: 00114014030501080000
       Shop #: WSC 06314 000 00000
       ASAM Dataset: EV_ECM16TDI02103L906023M 003017
       ROD: EV_ECM16TDI02103L997557R.rod
       VCID: 306FA5C76B235A137B-8064
       VINID: 9D196AAAA2202114410451880CB2D8C130
    No fault code found.
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes (J104)       Labels:. 1K0-907-379-60EC1F.clb
       Part No SW: 1K0 907 379 AJ    HW: 1K0 907 379 AJ
       Component: ESP MK60EC1   H30 0107
       Revision: 00H30001
       Coding: 13422012092300FFC81104EC901C0091380800
       VCID: 7AFB47EFF5DF504385-802E
    1 Fault Found:
    00290 - ABS Wheel Speed Sensor; Rear Left (G46)
                003 - Mechanical Failure - Intermittent
                 Freeze Frame:
                        Fault Status: 00100011
                        Fault Priority: 1
                        Fault Frequency: 91
                        Reset counter: 80
                        Mileage: 312619 km
                        Time Indication: 0
                        Date: 2023.07.04
                        Time: 16:06:36
                 Freeze Frame:
                        Count: 0
                        Count: 0
                        Count: 12800
                        Count: 69
                        Count: 50970
                        Count: 2
                        Count: 255
                        Count: 0
    Address 08: Auto HVAC        Labels: 8P0-820-047.clb
       Part No SW: 8P0 820 047 D    HW: 8P0 820 047 D
       Component: J255  Klima Man H08 0060
       Revision: 00H08004    Serial number: 00000000000000
       Shop #: WSC 00000 000 00000
       VCID: 3169A0C3A829531B74-8064
    Address 09: Cent. Elect. (J519)       Labels:. 8P0-907-063.clb
       Part No SW: 8P0 907 063 A    HW: 8P0 907 063 A
       Component: BCM PQ35  M   105 0575
       Revision: 00105 AK
       Coding: 0E000A2FB005F000207041E00000014C431A23AA004DC122E4008F800041
       VCID: 326BAFCF6D2F68030D-8066
       Subsystem 1 - Part No SW: 8P2 955 119 F    HW: 8P2 955 119 F  Labels: 1KX-955-119.CLB
       Component: Wischer AU350  H10 0040
       Coding: 00DD13
       Subsystem 2 - Part No: 8P0 951 177
       Component: Innenraumuebe  H04 0020
       Subsystem 3 - Part No: 1K0 951 605 C
       Component: LIN BACKUP HO  H05 1501
       Subsystem 4 - Part No: 1K0 907 719 C
       Component: Neigungssenso  005 0003
    3 Faults Found:
    00984 - Left Tail Light (M4)
                010 - Open or Short to Plus - Intermittent
                 Freeze Frame:
                        Fault Status: 00101010
                        Fault Priority: 2
                        Fault Frequency: 8
                        Reset counter: 118
                        Mileage: 312842 km
                        Time Indication: 0
                        Date: 2023.07.10
                        Time: 21:01:53
                 Freeze Frame:
                            Term 15 On
                        Voltage: 14.05 V
                            ON
                            ON
                            Term 50 On
                            OFF
                            ON
    00985 - Right Tail Light (M2)
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 227
                        Reset counter: 118
                        Mileage: 302093 km
                        Time Indication: 0
                        Date: 2021.05.20
                        Time: 18:39:32
                 Freeze Frame:
                            Term 15 On
                        Voltage: 14.20 V
                            ON
                            ON
                            Term 50 On
                            OFF
                            OFF
    01565 - Luggage Compartment Light (W3)
                 Freeze Frame:
                        Fault Status: 00101100
                        Fault Priority: 4
                        Fault Frequency: 1
                        Reset counter: 122
                        Mileage: 313808 km
                        Time Indication: 0
                 Freeze Frame:
                            Term 15 Off
                        Voltage: 12.60 V
                            OFF
                            ON
                            Term 50 Off
                            OFF
                            OFF
    Address 15: Airbags (J234)       Labels:* 8P0-959-655-10.clb
       Part No SW: 8P0 959 655 P    HW: 8P0 959 655 P
       Component: Airbag AU1042 H06 0160
       Revision: --------    Serial number: 003FB00514EA Dataset Number: 8P0909602M  0003
       Coding: 303142413039303030384A55305238503053
       ASAM Dataset: EV_Airba10AURB4 001001
       ROD: EV_Airba10AURB4_AU35.rod
       VCID: 4FADC63B16DD25EB02-801A
       Crash sensor for side airbag: driver side:
       Serial number: 34928RB4000054B8BAF3
       Front Passenger's Side Airbag Crash Sensor:
       Serial number: 35028RB40000535ED16L
       Rear Side Airbag Crash Sensor (on driver's side):
       Serial number: 35128RB4000054B8C15L
       Passenger side rear thorax airbag crash sensor:
       Serial number: 35228RB40000535E735I
       Crash sensor for front airbag: driver side:
       Serial number: 35547RB4000053492069
       Crash sensor for front airbag: front passenger side:
       Serial number: 35647RB40000534931FL
    Address 16: Steering wheel        Labels: 8P0-953-549.lbl
       Part No SW: 8P0 953 549 K    HW: 8P0 953 549 K
       Component: J0527           H37 0070
       Coding: 0002012
       VCID: 4683E31F31A7E4A3B1-8012
       Subsystem 1 - Part No: XXXXXXXXXXX
       Component: E0221           H02 0030
    Address 17: Instruments        Labels: 8P0-920-xxx-17-MY8.clb
       Part No SW: 8P0 920 982 J    HW: 8P0 920 982 J
       Component: KOMBIINSTR. VDO H03 0990
       Revision: D0H03005    Serial number: 2240J005015548
       Coding: 0004428
       Shop #: WSC 14557 067 57207
       VCID: 408FF5071383CA938B-8014
    1 Fault Found:
    00003 - Control Module
                014 - Defective
                 Freeze Frame:
                        Fault Status: 01101110
                        Fault Priority: 1
                        Fault Frequency: 1
                        Reset counter: 255
                        Mileage: 230500 km
                        Time Indication: 0
                        Date: 2017.03.06
                        Time: 13:57:50
    Address 19: CAN Gateway        Labels:. 1K0-907-530-V4.clb
       Part No SW: 1K0 907 530 AF    HW: 1K0 907 951
       Component: J533  Gateway   H17 0233
       Revision:   H17       Serial number: 1521J09C1803B4
       Coding: E9801F06000202040101
       VCID: 6BD572AB4A85F9CB0E-803E
    Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
       Revision: D0H03005    Serial number: AUX7Z0J0FNB094
       Shop #: WSC 54330 004 1048576
    Address 42: Door Elect, Driver        Labels: 8P0-959-801-MIN3.lbl
       Part No SW: 8P0 959 801 N    HW: 8P0 959 801 N
       Component: Tuer-SG         H04 0100
       Coding: 0131636
    1 Fault Found:
    00943 - Heated Exterior Mirror; Driver Side (Z4)
    Address 44: Steering Assist        Labels: 1K0-909-14x-GEN3.clb
       Part No: 1K0 909 144 J
       Component: EPS_ZFLS Kl. 232    3001
       Revision: 00H17000
       Shop #: WSC 02069 000 90108
    3 Faults Found:
    16353 - Control Module - Internal Malfunction
                000 - -
                 Freeze Frame:
                        Fault Status: 01100000
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 72
                        Mileage: 215109 km
                        Time Indication: 0
                        Date: 2015.12.01
                        Time: 07:38:14
                 Freeze Frame:
                        Battery Volts: 13.6 V
                            DU
                        Temperature: 38.0\B0C
                        Error Code: 14622
                        Torque: -0.6 Nm
                        Torque: -1.696 Nm
                        RPM: 9012 /min
    16355 - Control Module - Watchdog Timer
                014 - Defective - Intermittent
                 Freeze Frame:
                        Fault Status: 00101110
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 255
                        Mileage: 215109 km
                        Time Indication: 0
                        Date: 2015.12.01
                        Time: 07:38:14
                 Freeze Frame:
                        Voltage: 13.63 V
                            ER
                        Count: 0
                        Count: 0
                        Count: 60
                        Count: 0
    01316 - ABS Control Module
                013 - Check DTC Memory - Intermittent
                 Freeze Frame:
                        Fault Status: 00101101
                        Fault Priority: 3
                        Fault Frequency: 255
                        Reset counter: 122
                        Mileage: 313796 km
                        Time Indication: 0
                        Date: 2023.07.27
                        Time: 21:38:48
                 Freeze Frame:
                        Voltage: 14.00 V
                            DU
                        Temperature: 36.0\B0C
                        RPM: 928 /min
                        Speed: 15.0 km/h
                        Speed: 15.0 km/h
                        Count: 0
    Address 52: Door Elect, Pass.        Labels:. 1K0-959-702-MIN3.clb
       Part No SW: 8P0 959 802 N    HW: 8P0 959 802 N
       Coding: 0131636
       VCID: 479DEE1B36ADFDAB4A-8012
    Address 56: Radio        Labels: 8J0-035-1xx-56.clb
       Part No SW: 8P0 035 152 E    HW: 8P0 035 152 E
       Component: R Chorus2+      H03 0280
       Revision: 00H03000    Serial number: AUZ1Z2K6127060
       Coding: 0220021
       VCID: 2D51BCB3B41137FB50-8078
    Address 61: Battery Regul. (J840)       Labels:. 1K0-907-534.clb
       Part No SW: 1K0 907 534     HW: 1K0 907 951
       Component: Batt.regelung H17 0233
       Revision: --------    Serial number: 1521J09C1803B4
       Coding: 0303085A
       VCID: 68DF0DA79B73D2D363-803C
       Subsystem 1 - Part No SW: 1K0 915 181 C    HW: 1K0 915 181 A
       Component: J367-BDM  H07 0125
       Serial number: 00000000002790876129
    End-------------------------(Elapsed Time: 02:12)--------------------------
  2. Re: ABS Brakes, Steering Assist Fault Codes
    133 Post(s)
    1987 Post(s)
    Please include the VIN, it isn't GDPR relevant data. Often this is the magnetic ring on the back of the wheel bearing, they rust and take the end of the speed sender.
  1. Question Retrofit Park (steering) assist (PR 7X5)
    By woter in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 12-05-2015, 08:21 AM
  2. Address 44: Steering Assist
    By tommy1980murf in forum VCDS - Help Requests
    Last Post: 27-05-2013, 09:42 PM
  3. Steering assist change with VAG-COM for MK5
    By Perpetuus in forum VCDS - General Questions
    Last Post: 08-03-2009, 08:44 AM
  4. changed temperature sensor not no servo assist on brakes
    By waynetdi130 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 25-02-2009, 02:32 PM
  5. Steering Assist adjustment
    By exaisle in forum VCDS - General Questions
    Last Post: 14-06-2008, 11:53 AM
