Thread: 2004 Cab Sudden Brake issue
  1. 2004 Cab Sudden Brake issue
    Dec 2013
    From - Walney Island, Cumbria, Live in: Larkhill, Wiltshire
    11 Post(s)
    Yo,
    Had a customers 2004 2.4 Cabriolet BDV engine in for a cooling hose replacement today, which meant inlet manifold etc off to reach it.
    On finishing the job, the ABS light popped up when running the car.
    P01435 - Brake Pressure Switch failure
    Measuring blocks in VCDS read 296Bar constantly.
    Am I right in thinking this is the switch that’s screwed into the side of the pump next to the coolant reservoir? The reading doesn’t change if I unplug it or press the pedal.
    Could anything I’ve touched while removing inlet etc cause this? I’m struggling to figure out why it’s suddenly appeared.
    Seems very odd but needs rectifying quickly. Reluctant to order a £130 switch if it’s likely to be something else.
    Cheers for any insight.
    Aidan
  2. Re: 2004 Cab Sudden Brake issue
    134 Post(s)
    2007 Post(s)
    8E0 907 597 £366.60 genuine, approx £130 aftermarket if you can get one. There are two sub versions of the code, basic settings or electrical fault. This is the sort of crap you have to endure working on old cars, just because something fails when you have the car in doesn't mean it is your fault. Some people think that when their car goes in for work it has some sort of blanket warranty against new faults.
  3. Re: 2004 Cab Sudden Brake issue
    Dec 2013
    11 Post(s)
    Thanks for the reply matey.
    Update.
    I’ve tried a different working switch on and it’s still present with the same fault. Fine for a few minutes then fault comes up. If you watch the pressure on live data, it’s randomly showing whatever it feels like, unless I unplug the switch in which case it shows 296Bar permanently.
    Am I right in thinking this would be the ABS unit electronics at fault and not the switch? If so, I suspect it’s beyond my capability to rectify at this point.
    From memory, replacing abs unit is quite involved.
  4. Re: 2004 Cab Sudden Brake issue
    134 Post(s)
    2007 Post(s)
    Impossible to say remotely
  5. Re: 2004 Cab Sudden Brake issue
    Dec 2013
    11 Post(s)
    Turns out it was the abs unit itself. Had it fixed by ECU Testing
    Now I’ve got these to contend with before it can go back to its owner. Joy. Haha.
  1. Question Worrying sudden engine issue
    By Tex Gore in forum A8 - S8 - V8
    Last Post: 05-09-2021, 01:20 AM
  2. 2004 A3 2.0 tdi 1st & reverse sticking and sudden clutch bite?
    By splitscreensi in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 06-06-2013, 11:23 AM
  3. Brake servo issue and possible linked boost issue
    By slipperyox in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-10-2012, 10:06 PM
  4. Please Help A4 convertible 2.5 TDIi 2004 sudden electrical problems!!
    By bayo1 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 03-05-2012, 05:53 PM
  5. Sudden, total brake failure warning
    By VitesseEF in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 29-01-2011, 12:55 PM
