Thread: A3 170 tdi quattro Dpf
  1. A3 170 tdi quattro Dpf
    Jul 2023
    Inverness
    Front flexi pipe has burst on my A3, I have striped the prop and exhaust but can't get the dpf unit out.
    Does anyone know the best method to remove the dpf unit ?
    Thanks for the help 👌
  2. Re: A3 170 tdi quattro Dpf
    135 Post(s)
    2026 Post(s)
    8P A3 quattro with a BMN engine?
  3. Re: A3 170 tdi quattro Dpf
    Jul 2023
    Bristol
    The DPF unit is typically located towards the front or middle section of the exhaust system. You may need to remove additional parts, such as heat shields or brackets, to access it. If your DPF unit has oxygen sensors attached, carefully detach the wiring harness and remove the sensors. These sensors are important for monitoring exhaust emissions. With all connections and sensors disconnected, you should be able to slide the DPF unit out of its position. If it's stuck due to corrosion or debris, gentle tapping with a rubber mallet may help. Avoid using excessive force to prevent damaging surrounding components.
  1. The new Audi E-tron Sportback 50 Quattro and 55 Quattro
    Last Post: 29-08-2020, 11:31 AM
  2. The new Audi E-tron Sportback 50 Quattro and 55 Quattro
  3. Question Quattro owners - 3.0 TDI Quattro - tyre scrubbing on half to full lock - any ideas?
    By Thon in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 07-03-2012, 02:20 PM
  4. Question 2.8 Audi Quattro A4 - WILL 2.6 quattro gear box and transfer box fit???
    By tedsalop in forum Chat - Anything with wheels
    Last Post: 29-06-2009, 12:15 PM
