Thread: Injector values
Results 1 to 8 of 8
  1. Injector values
    May 2023
    GB
    Hi all just got my vcds, wondering if anyone knows if these readings are ok for my 1.6 TDI as I'm still learning
    Many thanks
    Sent from my M2007J20CG using Tapatalk
  2. Re: Injector values
    131 Post(s)
    1973 Post(s)
    CAYC engine? I was trying to study these values this morning on one with a misfire and in measuring blocks there is a better display (can't emer the number but it's in the list) for studying the corrections, all the other valves showed equal as yours but corrections showed number 1 injector fighting number 3 to keep the idle stable. I solved the problem with a smooth idling compensation function but that is only available in the dealer system ODIS on most ECU software versions.
    1 1 0
  3. Re: Injector values
    May 2023
    GB
    Lovely job pal, thanks. Yes cayc 75bhp. I'll try the measuring blocks this evening anyone know the correct value avg?
  4. Re: Injector values
    131 Post(s)
    1973 Post(s)
    CAYA = 75ps
    CAYB = 90ps
    CAYC = 105ps
    Don't worry about the specifics, worry about the discrepancies from each other
  5. Re: Injector values
    May 2023
    GB
    Oops caya
  6. Re: Injector values
    May 2023
    GB
    I've noticed all my injector codes are incorrect, so I've checked the resistance and all are spot on. Then started changing the codes but now harder to start and a lot of pinging when hot. Here's the codes and current stored codes. Is it the underlined 6 digit's.
    Many thanks.
  7. Re: Injector values
    131 Post(s)
    1973 Post(s)
    I was sure I answered this? Anyway, either someone has been experimenting with different values to solve poor injectors or just stuffed in a set of used one. The only sure way to deal with a poor running CAY is to fit and code four new genuine or VDO injectors BUT only if you know the same is free of swarf.
  8. Re: Injector values
    May 2023
    GB
    Yes mate you have. Thanks,
    Just a quick one.
    So I've corrected two of them, should I attempt to code them all correctly and see?
    As I have a 2hr trip later
  1. Question BKP engine, Injector and injector wiring harness.
    By TedVW in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 23-05-2020, 01:45 PM
  2. 2007 A6 2.0TDI Injector VCDS values
    By steve.b83 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 04-02-2020, 11:00 PM
  3. Please Help Touran 2.0 TDI faulty injector wiring loom and now possible injector fault
    By bigdaddysi in forum Touran - Sharan - Caravelle
    Last Post: 28-10-2013, 07:13 PM
  4. Impact sensor resistance values?sensor resistance values
    By tosher777 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-08-2010, 05:31 PM
  5. Used Car Values
    By blacksline in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 29-09-2009, 12:21 PM
