Thread: 1.6tdi Fuel Pressure Issues, Metering valve, regulator and pump seems fine
  1. 1.6tdi Fuel Pressure Issues, Metering valve, regulator and pump seems fine
    Nov 2023
    South-Africa, Pretoria
    Good day guys. First post here.
    I am completely stumped with my car.
    Its a 2010 Jetta MK5 1.6tdi (CAY Engine)
    It started acting up where it would at random not start. Cranking, but no start. This was completely random, not related to any of the following:
    Ambient Temp
    Engine Temp
    Time since last drive
    Fuel level
    My wife would phone me saying the car won't start, I get there about 30min later and it starts right up, no issue. Then weeks go by without a problem.
    I started driving the car myself, and experienced exactly the same.
    Errors included minimum fuel pressure not reached, and fuel pressure too low - P0087
    The last time it actually stumbled and died while driving.. Not starting. Then 40min later after towing the car home it starts right up again.
    I started investigating, but can't find anything definitive. The car is now at the point where it never starts anymore. Last night I put power on both the pressure regulator and the volume control valve, and after a couple of seconds the pressure went over 1000Bar. This is an indication to me that the two valves and pump are in good condition. So next up was control. +12v supply on both sensor is all good. Wires measure continuity from plug to ecu on control side. ECU also doesn't trigger any error related to the sensors.
    Any advice will be of great help!!
    Thanx
    Here is some additional info on the metering valve
    and on the regulator
  2. Re: 1.6tdi Fuel Pressure Issues, Metering valve, regulator and pump seems fine
    Feb 2020
    Bradford
    40 Post(s)
    Check flow from in tank pump. It should come on briefly with ignition
  3. Re: 1.6tdi Fuel Pressure Issues, Metering valve, regulator and pump seems fine
    2010 Post(s)
    Check the fuel filter insert for sparkle dust
  4. Re: 1.6tdi Fuel Pressure Issues, Metering valve, regulator and pump seems fine
    Nov 2023
    Hi Roverfan.
    Thanx for the reply.
    Lift pump is operating as normal
  5. Re: 1.6tdi Fuel Pressure Issues, Metering valve, regulator and pump seems fine
    Nov 2023
    Hi Crasher.
    Filter was replaced, no metallic flakes noted, I did check thoroughly for that.
    I also did ensure to prime system properly
  1. Question Audi S6 - Oil Pressure Regulator Valve
    By JohnS4 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 10-12-2021, 08:46 PM
  2. Power Loss & P2293 - Fuel Pressure Regulator Valve (N276): Mechanical Malfunction
    By betyouaint in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 15-03-2020, 06:45 PM
  3. Replies: 3
    Last Post: 05-08-2012, 04:59 PM
  4. Replies: 0
    Last Post: 16-01-2012, 09:16 PM
  5. Question 4 Bar Fuel Pressure regulator.
    By comfortablynumb in forum Golf MK4 - 1999 - 2004
    Last Post: 19-07-2009, 03:29 PM
