Thread: Ea288 2.0tdi crlb dpf system non adblue
Results 1 to 10 of 44
  1. Question Ea288 2.0tdi crlb dpf system non adblue
    Dec 2019
    Hello, noticed today a bit of excesive dpf regens.
    Done a trip one way on motorway 70 miles, half way i stopped to services and regen was on, i get close to destination 65miles or so from initial start and everything was ok regen not on at a trafic light; 3-5 miles later regen was on with usual side efects elevated idle on stand still and start stop disabled /not available. Waited for it to do its stuff and finish regen, start and stop will kick in once done. Anyway did not think much of it... not first time after a long drive it decides to regen just before wanting to stop keeping pinpointed 20-25 minutes to the car to finish regen.
    2hours later i left ... 1 hour later 45 miles is doing regen again...
    After regen idle differential presure is 9-10 mbar on high revs3000rpm is 55mbar each time, ash load is 75g out of 80g limit. No faults no lights or pending intermitent faults. Egr dif presure is 11mbar...
    Not sure if this is a dpf issue reaching the end if life span or is something else causing it.
    Currently clocking just above 206000 miles. Oil consumption is about 700ml/9000miles using 0w30 vag 507 longlife. Drivestyle is moderate and mostly motorway.
    Anyone, any direction i should look into, is worth taking dpf of take it to a dpf wash boot, checking injectors turbo?! Not really know wher to start before it turns worse.
  2. Re: Ea288 2.0tdi crlb dpf system non adblue
    Jan 2013
    Wessex. and Southern France
    114 Post(s)
    Only my opinion of course but at that mileage I would thing it's way past useful service life for the dpf. As I say, just my opinion and someone will be along in a tic to say I'm wrong. So, there's that.
  3. Re: Ea288 2.0tdi crlb dpf system non adblue
    2009 Post(s)
    I agree, the DPF is effectively full of ash, DPF Clean Team can bring it back to life.
  4. Re: Ea288 2.0tdi crlb dpf system non adblue
    Dec 2019
    I was planning a dpf clean anyway end of summer only a bit woried could/might be something else as did not manifest this way till this weekend. I need to start some phone calls by the looks...
  5. Re: Ea288 2.0tdi crlb dpf system non adblue
    Dec 2019
    what would be the part number for the dpf assambly? 04L 131 602 px or mx? for tmbbh7np5h7516762
  6. Re: Ea288 2.0tdi crlb dpf system non adblue
    2009 Post(s)
    Was 04L 131 669 KX now 04L 131 648 SX, just send the entire assembly to DPF Clean Team in Hinckley, they won't let you down
  7. Re: Ea288 2.0tdi crlb dpf system non adblue
    Apr 2012
    Crawley UK
    Hi all. Same issues, im getting intermittent p0402 code now. Regen every 70 miles city. Strange thing is i have vag dpf app and mine always goes up steady but then jumps 11-12g soot to a regen. So i can be 70 odd miles at 11g soot and then on a regen a mile later saying 24g of soot?
    Anyone got any ideas on prices to get egr and dpf cleaned if they do removal and install?
  8. Re: Ea288 2.0tdi crlb dpf system non adblue
    2009 Post(s)
    16786 (P0402) - EGR System - Excessive Flow
    What is the VIN?
  1. Please Help Adblue system fault No restart in 650 miles
    By Neik5 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 22-01-2024, 11:43 PM
  2. EGR Cooler Issue - Should I Bypass AdBlue System ?
    By clubman22 in forum Audi A4 - B9 Forum - 2015 -
    Last Post: 01-02-2023, 11:38 AM
  3. Question Another AdBlue system fault...
    By artheb in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 19-03-2021, 08:42 AM
  4. Q7 adblue system fault, no restart after x kms
    By Kiwimellonman in forum Q7 - 4M Forum - 2016 -
    Last Post: 02-02-2021, 04:48 PM
  5. Adblue System Fault - No Restart 1000km
    By Silane in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 09-08-2020, 04:16 PM
