Thread: Spanner symbol on next to trip display
Results 1 to 10 of 10
  1. Spanner symbol on next to trip display
    Jun 2014
    newport, s wales
    How do I turn the spanner off
    I’ve tried quite a few you tubes
    And none of them are successful
    My central display differs from a lot of them.
    Can someone point me at the correct routine please?
  2. Re: Spanner symbol on next to trip display
    133 Post(s)
    1986 Post(s)
    It means the car needs maintenance
  3. Re: Spanner symbol on next to trip display
    Jun 2014
    newport, s wales
    I’m aware of that Crasher.
    I’ve done oil, filters etc
    So how do I reset it to start the service interval again?
  4. Re: Spanner symbol on next to trip display
    Jul 2008
    Lisburn
    16 Post(s)
    you have done an engine service and reset that - As crasher has said the car needs maintenance and then you need to reset that.
    Stewart
    2012 Q5 2.0D quattro S line Plus
    1986 coupe quattro (kv)
    1972 mini 1400 100BHP A series
    2016 F-Pace Portfolio X761 2.0D 180HP
  5. Re: Spanner symbol on next to trip display
    Jun 2014
    newport, s wales
    I’ve done service on the engine.
    What other maintenance is required to allow me to turn the spanner off?
  6. Re: Spanner symbol on next to trip display
    Jul 2008
    Lisburn
    16 Post(s)
    everything else on your car,
    brakes
    suspsion
    tyres
    so on and so forth
    its mainly an inspection reminder but there will be things needing done like brake fluid every 2 years for example. it will be in your service book.
    Stewart
  7. Re: Spanner symbol on next to trip display
    Jun 2014
    newport, s wales
    I agree with needs to be done
    However I have done it.
    New front coil springs tick
    New rear discs and callipers brakes system bled tick
    Oil and filters changed tick
    It’s all done
    All I want to do is reset the spanner and service reminders.
  8. Re: Spanner symbol on next to trip display
    133 Post(s)
    1986 Post(s)
    You need a diagnostic system such as VCDS and a full scan of the car is part of the inspection procedure, some cars allow the oil change reset in the MMI display but I only have an 8V S3 here so can't check. Which year?
  9. Re: Spanner symbol on next to trip display
    Apr 2014
    SW London / Surrey
    10 Post(s)
    169 Post(s)
    Does your code scanner not have an SRI reset option?
    When you say videos is that things like pushing dashboard clock buttons while turning key? The latter work for me when I can't be bothered to get VCDS out - but often take a couple of tries to get the timing right.
  10. Re: Spanner symbol on next to trip display
    Jun 2014
    newport, s wales
    Crasher. Car is 2008
    VAG-Abound
    I’ll check SRI FUNCTION on Autel
    If it’s there if I not noticed it before
    Videos various ….,yes ignition on and press buttons etc.
    Central displays different to mine
  1. Question Undocumented red symbol in driver display window
    By BigRedSwitch in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 19-02-2017, 01:05 PM
  2. Spanner symbol
    By Texmilb in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 04-02-2017, 01:06 PM
  3. Send text (and symbol?) to MFD+ display
    By LA9SHA in forum Touran - Sharan - Caravelle
    Last Post: 29-03-2014, 12:24 PM
  4. Question Spanner symbol showing suddenly
    By mjcon in forum Polo - Derby - Lupo - Fox
    Last Post: 24-12-2010, 11:35 AM
  5. Tool/ spanner icon flashing on display?!?
    By MK5 in forum Golf MK5 - 2004 - 2009
    Last Post: 15-09-2008, 07:16 PM
