Thread: Drivers Window Switch, Down is Up?
  1. Drivers Window Switch, Down is Up?
    Aug 2011
    Aldershot
    6 Post(s)
    So, next crazy oddity with the B7, started a few months back,
    • Passenger and rear window switches operate correctly except the drivers side
    • All windows can go up and down from the keyfob
    • Drivers door switch, only goes up, it even goes up when you push down? (I've opened the windows with the key fob) and pushed down on the door switch and it goes up?
    No VCDS errors at all. Is this likely to be the drivers switch needs replacing? or likely a sign of issues with the CCM module? Can't see any other discussion on this strange behaviour
    Paul
  2. Re: Drivers Window Switch, Down is Up?
    Apr 2014
    SW London / Surrey
    10 Post(s)
    169 Post(s)
    I thought VCDS would show state of switches in one of the convenience module measuring blocks. If so does it give hints?
  3. Re: Drivers Window Switch, Down is Up?
    132 Post(s)
    1980 Post(s)
    I have seen that but annoyingly can't remember the fix!
  4. Re: Drivers Window Switch, Down is Up?
    Jul 2008
    Lisburn
    16 Post(s)
    same - rings a bell but only a double Decker sofa comes to mind lol...
    Stewart
    1986 coupe quattro (kv)
  5. Re: Drivers Window Switch, Down is Up?
    Aug 2011
    Aldershot
    6 Post(s)
    ok, so bought a cheapo switch on Amazon for testing, plugged it in and worked fine, changed the cable back to the original audi switch (audi switch feels nicer when operaing) and the audi switch also worked. started to put the door back together, stopped working.....errr. I think there is an issue with the cable between the door control module and the window switch. Removed and reinserted into the connectors both ends, and so far, so good. So hopefully the connector was just loose (impossible I know as it was locked in at both ends) but still working at the moment. very strange.
  1. Question Drivers side window switch
    By xDarrenw in forum Golf MK5 - 2004 - 2009
    Last Post: 17-12-2017, 02:22 AM
  2. Drivers window switch
    By 5m4 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 17-10-2013, 12:34 PM
  3. Drivers Window Switch
    By richball65 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 10-08-2013, 08:21 PM
  4. Drivers Window Switch?
    By Daniel97 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 29-11-2011, 10:00 AM
  5. Drivers Window Switch - Anyone had issues??
    By RickT in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 17-12-2009, 01:01 PM
