Thread: Audi A4 C6 does a new battery need to be programmed/coded?
  1. Audi A4 C6 does a new battery need to be programmed/coded?
    Jun 2023
    location
    Does a new battery needs to be reprogrammed or coded into the ECU on audi a6 c6? (2.4l petrol). Thank you
  2. Re: Audi A4 C6 does a new battery need to be programmed/coded?
    Dec 2009
    Hi, I only just bought my C6 a couple of weeks ago and when going through things realised the car was programmed for a 92Ah AGM battery whereas it had a 110Ah wet Yuasa fitted.
    I just updated the part number to match the wet 110Ah batteries and changed the brand and incremented the serial by 1.
    I did read that just incrementing the serial by 1 should be enough to let the car battery management know a new battery is fitted.
    Not sure exactly what it changes, my car is in the garage for a turbo refurb currently so hoping it will sort the low voltage messages I sometimes got at startup - the car had been stood prior to me buying so worst case if it doesn't recover I'll need to fit a new battery at some point.
    You can do it via VCDS, Carista etc.
  3. Re: Audi A4 C6 does a new battery need to be programmed/coded?
    Jul 2008
    Lisburn
    16 Post(s)
    some do some dont, depends on the BCM fitted. My 07 c6 couldn't be programmed but i have heard of 05/06 c6s that were.
    you cab get away with it if you swap like for like - but if like aido you should really get it done as the car would have been charging a lesser battery so it makes sense you were getting the low voltage message
    Stewart
    2012 Q5 2.0D quattro S line Plus
    1986 coupe quattro (kv)
    1972 mini 1400 100BHP A series
    2016 F-Pace Portfolio X761 2.0D 180HP
  1. Can a used key be re-programmed for my car ?
    By jammie in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 01-12-2014, 05:05 PM
  2. Audi A4 Avant 2009 needs OEM kit coded
    By DaddyTayto in forum VCDS - Help Requests
    Last Post: 20-05-2014, 01:34 AM
  3. New Key Programmed?
    By Puresilk in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 04-07-2011, 02:31 PM
  4. Question Are audi desiel pumps coded?
    By RichardB in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 01-12-2008, 03:14 PM
  5. AUdi fob programmed to VW
    By Maz in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-10-2007, 10:37 PM
