Thread: RCD300 aerial question
  1. RCD300 aerial question
    Jun 2023
    Worcester, UK
    After reading loads of articles on here and elsewhere, I was just wondering if anyone has any ideas on this problem that probably should remain in the last century
    I have an original RCD300 in a 2009 ex British Gas Caddy van. FM reception is poor (on stations I know are easy to get here). Aerials are in the windscreen. It appears to have been changed so am thinking damage to the aerial/amp/wiring when that was done.
    This was my 'simple' fix! ... I have used the hole from one of the British gas roof aerials (they removed them but left the base fitments) to install a standard AM/FM aerial. I ran that to the radio and converted the DIN to the required Fakra connector using an adapter. But it doesn't seem to improve reception. Have checked it is grounded correctly. Tried it in both Fakra inputs, but always worse reception than the windscreen aerials.
    As I know we have strong reception around here I was wondering if the Diversity system in the RCD300 will only operate if the aerials are powered/active (as the window ones are).
    I.e. is it basically ignoring my passive aerial?
    On the hidden menu it shows both windscreen aerials as 'On', and when I swap for roof aerial then shows that input as 'Off' (assuming that means the power feed, but may mean the whole aerial input to Diversity system?)
    I don't want to spend on new headunit etc, as it is an old van and will need changing soon enough. I thought the above was an easy option, but seems not. Any helpful thoughts would be welcome, as it is doing my head in!
    Thanks in advance,
    Tom
  2. Re: RCD300 aerial question
    133 Post(s)
    1987 Post(s)
    You need to have a diagnostic read or the head unit to see what it perceives as the problem and the measuring block data will show the status. The antenna feed is by Fakra connectors so anything you fit will need suitable connectors.
  3. Re: RCD300 aerial question
    Jun 2023
    Worcester, UK
    Thanks Crasher, appreciate the help.
  1. Please Help anyone with a MK4 Ibiza- aerial question
    By kodkod.84 in forum Ibiza - Cordoba
    Last Post: 26-03-2016, 01:28 AM
  2. Replies: 9
    Last Post: 20-02-2014, 01:26 PM
  3. Please Help Aerial Choice Question - amplified or not
    By patomlin76 in forum In Car Entertainment
    Last Post: 31-10-2011, 01:44 PM
  4. RCD300 in MK4
    By Conor in forum Golf MK4 - 1999 - 2004
    Last Post: 06-04-2011, 08:11 PM
  5. Another aerial question
    By Phutters in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 03-04-2011, 11:04 AM
