Thread: Outer CV boot replacement
  1. Outer CV boot replacement
    just wondering, can the outer CV boot on the C7 2.0 tdi be done by popping out the rear control arm in the same way as the older C5.
    A question on the replacement boot too, the boot kit I got is a Febi one and the boot isn't like any previous CV boot I've seen, it seems almost plastic rather than rubber, does that sound normal for these boots ?
    2016 A6 2.0 TDI S-Line
    1969 Triumph Spitfire (In pieces )
  2. Re: Outer CV boot replacement
    Jul 2008
    Lisburn
    16 Post(s)
    I got my C6 shafts out without having to touch the suspension. I removed the heat shield on the box, and with the wheel on full lock the shaft had enough room to come out - just.
    I had an issue where a previous owner had replaced the shaft with a newer one, so i was in and out there too often until i figured it out. Had it down to about 20 minutes to pull the shaft.
    Stewart
    2012 Q5 2.0D quattro S line Plus
    1986 coupe quattro (kv)
    1972 mini 1400 100BHP A series
    2016 F-Pace Portfolio X761 2.0D 180HP
    1 1 0
  1. Please Help 4motion front CV outer boot replacement
    By kesselrun in forum Golf MK4 - 1999 - 2004
    Last Post: 14-05-2014, 08:50 PM
  2. Drive shaft boot replacement ( outer l/h )
    By dannyboy201062 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 25-10-2012, 06:47 PM
  3. Best way to change outer CV boot
    By shabazmo in forum Golf MK4 - 1999 - 2004
    Last Post: 22-01-2012, 10:54 PM
  4. Outer cv boot replacement
    By Jonny_doe in forum Passat - B5 Forum - 1997 -2005
    Last Post: 31-01-2010, 04:25 PM
  5. outer CV boot / gaiter replacement
    By MissSpentYouth in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 17-01-2008, 11:41 PM
