A7 Rear Side Airbag Short to Ground –
03-06-2023,07:17 PM
I currently have the Airbag light illuminated on the dashboard of my Audi A7. Running VCDS shows me the following fault message (which is a hard fault that will not clear):-
Address 15: Airbags (J234) Labels:* 4H0-959-655.clb
Part No SW: 4H0 959 655 C HW: 4H0 959 655 C
Component: Airbag10.43 H40 0040
Revision: -------- Serial number: 003JG005BF8Y Dataset Number: 4G8909602E 0002
Coding: 30314530323130303134554A305234473853
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_AirbaAU10BPAAU64X 001014
ROD: EV_AirbaAU10BPAAU64X_VW51.rod
VCID: B63ECFEFB8C5CA5A657-80E2
Crash sensor for side airbag: driver side:
Serial number: 3575HRB405P0TGJE29D$
Front Passenger's Side Airbag Crash Sensor:
Serial number: 3585HRB404P0T3R8AO2/
Rear Side Airbag Crash Sensor (on driver's side):
Serial number: 3515JRB405N0OSD4IPRR
Passenger side rear thorax airbag crash sensor:
Serial number: 3525JRB405T0OSD4N90$
Crash sensor for front airbag: driver side:
Serial number: 3554VRB40630P4N09GAE
Crash sensor for front airbag: front passenger side:
Serial number: 3564VRB40630P4N0COEU
1 Fault Found:
9441297 - Rear; passenger's side; side-airbag igniter
B1010 11 [137] - Short to Ground
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 163836 km
Date: 2023.04.12
Time: 09:12:05
I am very familiar with working on airbag systems and fully understand all of the precautions and procedures in the Audi workshop manual for working on this system. What I would like advice on is the exact location within the car of the airbag that is causing this fault. I initially thought it was the rear side airbag which should be fitted in the side panel next to the rear bench seat, but having removed this panel on both sides, there is no airbag fitted in this location. I unplugged the front passenger seat airbag and ran the diagnostics again. I can now see that the front passenger airbag has changed to open circuit as I would expect, but the rear side airbag still shows short circuit, so it is definitely not the side airbag in the passenger seat. Any ideas would be much appreciated.......
Regards,
Mike
A7 3.0 TDI 245 Quatro SE. Daytona Grey. Comfort Seats (Heated + Ventilated), MMI Plus, HUD, Speed Limit Display, Lane Assist, Phone Prep High, Folding Heated Mirrors, Night Vision, Adaptive Cruise, Adaptive Lights, Parking Advanced, Four Zone Climate, Ambient Lighting.
