Thread: Long time starting
  1. Long time starting
    Aug 2010
    kigsbridge, devon
    Hi all, apologies if this has been covered already. 2008 V6 tdi
    I had a couple injector seals gone and venting through the releif ports.
    Bought the genuine copper washers and o rings and replaced it all this weekend. It was a lovely straight forward job. It turns out cyl 1 & 6 were pretty much non existant where all the others were like new.
    Upon finishing the job, I cranked it over until it came to life. I did not follow any bleeding procedure.
    Once running (30-40 seconds of cranking) it fired up and sounded perfect.
    Unfortunately now for some reason it cranks over for much longer than ever before before firing up, probably 5-8 seconds. I was convinced it was air in the system but after a long drive today she's still doing it.
    I did a quick scan with VCDS and got:
    Address 01: Engine
    005699 - Please check DTC Memory of Electric Load Controller
    P1643 - 000 - - Intermittent
    Address 09: Cent. Elect.
    02254 - Interface to Generator
    As i type this i'm thinking I should go and monitor rail pressure.
    Any suggestions would be appreciated.
    Thank you
    You don't know how it works until you take it apart!
  2. Re: Long time starting
    2007 Post(s)
    The pump won't have run dry if you didn't change the fuel filter.
  1. Hello, long time owner, first time poster
    By linkman72 in forum New Member Introductions
    Last Post: 03-05-2021, 01:03 PM
  2. Question Long time no start suddenly starting
    By MeDriving in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 06-10-2020, 11:52 AM
  3. Long time reader, 1st time poster
    By KyleEgan in forum New Member Introductions
    Last Post: 25-08-2020, 10:30 PM
  4. long time member - first time poster!
    By m33ufo in forum New Member Introductions
    Last Post: 29-06-2017, 04:39 PM
  5. Long time VW, first time Audi owner
    By NatHolloway in forum New Member Introductions
    Last Post: 30-12-2015, 10:14 AM
