Thread: 1.9 TDI no boost at all
  1. 1.9 TDI no boost at all
    May 2023
    Italy
    Hi guys, i bought an b5.5 Fw weeks ago and It ran fine, today driving i noticed that It was running with no turbo boost at all, i can hear barely an Whistle from turbo going higher rpm but no boost, It has a very dirty EGR that its leaking oil, engine itself sounds good, no smoke at all no weirdo noises , its my turbo dead?
  2. Re: 1.9 TDI no boost at all
    111 Post(s)
    1858 Post(s)
    You need a fault code read, if there are no codes, fit a new genuine VW Air Mass Meter, if you fit aftermarket it is likely to let you down. The EGR valve leaks oil which condenses from crankcase and turbo vapour in the charge air system and then gets forced past the EGR internals, it is an irritant but not important
    https://youtu.be/w8r2xnITnqA?si=Hy9T6jEbWD5ih-Oy
  1. Please Help constant full boost!!! boost leak? MAP sensor?
    By boratdi150 in forum Bora - 1998 - 2005
    Last Post: 21-11-2017, 09:56 PM
  2. Strange boost issue (base boost sometimes)
    By fivepointnine in forum Leon
    Last Post: 10-04-2017, 11:48 AM
  3. Replies: 1
    Last Post: 06-06-2014, 09:50 AM
  4. Please Help 2003 S3 Boost Problem, little or no boost.
    By Jonaman in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 21-05-2013, 04:41 PM
  5. Please Help Stuttering on boost, knocking when passing boost?? HELP please!!
    By JimboTD5 in forum Golf MK4 - 1999 - 2004
    Last Post: 07-06-2011, 05:24 PM
