Thread: Amarok vacuum pump gasket
  1. Unhappy Amarok vacuum pump gasket
    Jan 2019
    Have the head off my Rok again, this time EGR cooler gone again after 4 years and now the head is scrap. When I rebuilt the engine 4 years ago, every bolt etc was renewed and I replaced the vacuum pump gasket with the same type that was fitted oem from the two that were supplied in the elring head set. After a short run I had a fairly big leak which turned out to be from the vac pump to head gasket. I replaced with a VW item as per parts # which was the same pattern as the Oem obviously. What found was that the gasket passes over a screw drilling on the pump body effectively preventing a seal. I had to bodge with rtv to get a seal (it still wept). I wondered if there is another explanation why the gasket isnt routed to avoid the screw hole?? I've got to put it back together again and I'd like to do it properly if its possible? ROK VAC GASKET.JPGROK VAC PUMP.JPG
    VAG 20v powered Elise S2 500hp, Amarok 2.0 180 tdi 4motion
  2. Re: Amarok vacuum pump gasket
    2013 Post(s)
    Use a new AMC head casting, Elring gasket set and Pierburg pump.
  1. 2.0 tdi vacuum pump?
    By petrolhead63 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 16-05-2019, 02:08 PM
  2. Please Help Vacuum Pump 8L0 862 257 G
    By Wilson Santos in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 01-08-2015, 09:08 AM
  3. vacuum pump
    By abby1 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 31-12-2014, 02:29 PM
  4. Question Vacuum Pump?
    By geordiestig in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 12-01-2014, 07:21 PM
  5. Vacuum pump (tandem pump)
    By audi_130bhp in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 15-11-2007, 12:44 PM
