Thread: Brake bleeding
  1. Brake bleeding
    Aug 2021
    Newport
    Did a pair of rear calipers today on my 2004 Fabis Vrs, tried to bleed using my trusty gunson eezi bleed but couldnt get a decent flow out of the calipers.
    test drove it and a very spongy pedal.
    Eezi bleed used at 15 psi, no leaks on cap.
    Didnt have a helper to hand so was unable to try the 2 person method, may have another go tomorrow.
    Ive encountered this on an Audi A3 recently too, the Eezi bleed not working.
    Any ideas why it wont work correctly, maybe its to do with the Abs module?
    I do have Vcds if needed.
  2. Re: Brake bleeding
    2009 Post(s)
    VCDS is essential but you also need the battery on a good charger as a minimum. Added to this is a reservoir pressure bleeder but a third top up helper can deal with this. Does it have the Mk20 or Mk60 system?
  3. Re: Brake bleeding
    Aug 2021
    Newport
    I don’t know what system it is sorry, any way to find out?
    Ive read the bleed pressure needs to be 2 Bar which may explain the lack of flow, the Eezi bleed is only rated at 20 Psi.
    May be time for a better pressure bleeder.
  4. Re: Brake bleeding
    2009 Post(s)
    The ABS type comes up on the VCDS screen, the book says not to exceed 1.5 Bar and our pressure bleeder is set to 1.6 which works.
  5. Re: Brake bleeding
    Mar 2010
    Derry ireland
    67 Post(s)
    Have you ever thought on using a vac pump to bleed your system as good as any bleeder
  6. Re: Brake bleeding
    2009 Post(s)
    No, pressure bleeding is the recommended VAG method.
  7. Re: Brake bleeding
    Aug 2021
    Newport
    i got the missus on the pedal and did a manual bleed first and it seems to have worked.
    Will look into a better pressure bleeder though.
  8. Re: Brake bleeding
    Mar 2010
    Derry ireland
    67 Post(s)
    Of curse it works all the time ITs six of 1& half a dosen of the other
  1. Question Golf Mk 5 Brake Bleeding
    By bartleaj in forum Golf MK5 - 2004 - 2009
    Last Post: 22-03-2009, 03:28 PM
  2. Please Help brake bleeding
    By coyotee in forum Audi A3 - Archive Topics
    Last Post: 20-06-2008, 11:12 AM
  3. Question A6 brake bleeding.
    By lloydj2 in forum Chat - Anything with wheels
    Last Post: 12-05-2008, 10:08 PM
  4. bleeding brake's
    By d~lo in forum Golf MK3 - 1993 - 1999
    Last Post: 16-04-2008, 03:58 PM
  5. Brake bleeding
    By woodburner in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-01-2008, 08:10 PM
