Thread: Steering knuckle/ hub
  1. Steering knuckle/ hub
    6 Post(s)
    I am replacing the outer cv joint an Audi 1.9 tdi 130 awx and noticed the top control arm was worn. Removing the pich bolt of death has damaged the knuckle at the end . I've rang a few breakers but a bit thin on ground, so couple of questions.
    1. My knuckle is aluminium from an 05 car can in replace with steel or better like for like?
    2. Will a knuckle from another vehicle fit , Audi A4 1.9 tdi?
    If I get really stuck I suppose I could get it repaired , it's small piece but obviously important!?20230419_170045.jpg
  2. Re: Steering knuckle/ hub
    131 Post(s)
    1975 Post(s)
    One of my lads has just spent three hours trying to release the top arm on one side a 2017 type 8W A4, still the same stupid problem! The bolt would turn but the corrosion would not let it come out. If you have cracked the ally, it must be replaced, you must not weld suspension components. We once cracked one on a type 8K which cost us £600 in parts so now we only use a 2Kw induction heater.
  3. Re: Steering knuckle/ hub
    6 Post(s)
    I feel 20230420_120000.jpgfor the lad, probaly questioning his life choices after 3 hours -they are horrible! I suppose it's just heating and tapping without being too rough! I should count myself lucky i found a knuckle off ebay for £50 delivered.
    Looks like I'll need a bottom suspension arm as the ball joint end doesn't have a clip on and I think it should so grease has probably squished out?
  4. Re: Steering knuckle/ hub
    131 Post(s)
    1975 Post(s)
    Insecure boots are an MOT failure.
  5. Re: Steering knuckle/ hub
    6 Post(s)
    I meant to ask about this... the top bolt problem.
    You have an induction heater at your place don't you, do you still get hassle even using that?
  6. Re: Steering knuckle/ hub
    131 Post(s)
    1975 Post(s)
    That was three hours with the induction heater..., five year old car.
  1. Steering knuckle (hub carrier) - aftermarket ones - any reviews?
    By Johnnych in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 16-10-2021, 03:12 PM
  2. Steering gear fault. Steering rack box knocking noise
    By cip82 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 23-08-2020, 06:46 AM
  3. Replies: 4
    Last Post: 08-03-2018, 01:41 PM
  4. Please Help ***BREAKDOWN*** Red Steering Wheel Light & 3 Beeps. No Steering/Steering Locked
    By Stuart_B in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 03-10-2013, 11:00 PM
  5. Please Help 6N1 Polo leak in power steering pipe from pump to steering rack
    By crauch6 in forum Polo - Derby - Lupo - Fox
    Last Post: 18-02-2012, 08:36 AM
