Thread: Fault code B101904
  1. Fault code B101904
    Apr 2023
    My car has just thrown up fault code B101904 which is listed as “Rear Side Airbag Crash Sensor (on front passenger side) D”
    Does anyone know the exact position of this crash sensor on the car, I have searched the internet and there is very little info out there and what there is, is conflicting.
    The car is a 2014 Audi A6 C7 Allroad.
    Hope someone can help.
  2. Re: Fault code B101904
    132 Post(s)
    1979 Post(s)
    9443588 (B1019 )- Rear Side Airbag Crash Sensor (on front passenger's side) - Internal System Fault
    I think that would be sensor 4H0 959 643 but it is ambiguous and I can't find a Service Diagnose Code for it which is very helpful in pinpointing the part but I think it is item number "10" SDC G256 and you have to take the seat and side trim out, it is mounted into the C pillar. 11 is inside the door.
  3. Re: Fault code B101904
    Apr 2023
    Hi Crasher
    Thanks for the quick reply, I will have a go at removing the seat & trim and see if I can find the sensor.
  4. Re: Fault code B101904
    Apr 2023
    Hi Crasher
    Many thanks for your help, the Sensor was indeed item 10 on your diagram above, very easy to get to once you lift the seat base out and remove the side trim piece under the seatbelt. A second-hand sensor has solved the issue and all fault codes have been cleared.
    Once again, thanks for your help.
    Andy
    1 1 0
  1. Please Help Help - 2002 Audi A3 1.8t Quattro ARY engine code - Rough Idle - Fault code P1340 - Help
    By mumutley in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 03-05-2019, 11:10 PM
  2. Please Help Touran 2006 1.9TDi Fault Code 18000 / P1592 MAP Sensor fault?
    By frozenman77 in forum Touran - Sharan - Caravelle
    Last Post: 12-01-2016, 12:31 PM
  3. Question 3TDI (BKN code) engine schematics and fault code listing
    By 20vcqdriver in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 20-02-2012, 02:41 PM
  4. Replies: 6
    Last Post: 10-05-2011, 11:03 AM
  5. Replies: 0
    Last Post: 15-01-2008, 01:07 AM
