Thread: CAHA engine 2.0 tdi have oil pump 77mm key issue??
Results 1 to 10 of 16
  1. CAHA engine 2.0 tdi have oil pump 77mm key issue??
    Nov 2019
    essex
    On the lookout for a daily to put miles on for commuting.
    Have learned that several years worth of 2.0tdi models are affected with oil pump balancer shaft issue, 77mm hex key one.
    Want to avoid buying any of these so have my eye on a 2010 Seat Exeo with a CAHA lump in it.
    Can anyone tell me if the CAHA had the revised 100mm part in the oil pump or is this model affected too?
    Does anyone know what engine code models have the revised pump?
    thanks
  2. Re: CAHA engine 2.0 tdi have oil pump 77mm key issue??
    135 Post(s)
    2042 Post(s)
    VIN specific, what is the VIN of the target car?
  3. Re: CAHA engine 2.0 tdi have oil pump 77mm key issue??
    Jul 2023
    Italia
    Good evening, i have to buy an a4 b8 quattro 2.0 170 mi vin is:
    Wauzzz8k9aa101375
    It have an oil pump bad or not?
    Tank you
  4. Re: CAHA engine 2.0 tdi have oil pump 77mm key issue??
    135 Post(s)
    2042 Post(s)
    100mm
  5. Re: CAHA engine 2.0 tdi have oil pump 77mm key issue??
    Jul 2023
    Italia
    100mm
    Thank You
  6. Re: CAHA engine 2.0 tdi have oil pump 77mm key issue??
    Aug 2024
    halesowen
    oh gawd (& apologies for the thread hi-jack) i thought i was safe with my 2010 2.0 TDI CAHA as thought 2009 was the cut off & was using vehicle reg in eBay to check if i was 77 or 100mm (it says 100)
    so can i check my vin too pls? WAUZZZ8K8AA103442
  7. Re: CAHA engine 2.0 tdi have oil pump 77mm key issue??
    135 Post(s)
    2042 Post(s)
    100mm, changed 19.10.2009 and yours was built 11.12.2009
  8. Re: CAHA engine 2.0 tdi have oil pump 77mm key issue??
    Aug 2024
    halesowen
    phew! & thanks Crasher
  9. Re: CAHA engine 2.0 tdi have oil pump 77mm key issue??
    Jun 2025
    Caramulo, Portugal
    Hello, im about to get a Passat B6 2.0tdi, please could you help me see wich hex is installed on it? the vin is WVWZZZ3CZ9E036131.
    Thanks in advance!
  10. Re: CAHA engine 2.0 tdi have oil pump 77mm key issue??
    135 Post(s)
    2042 Post(s)
    Built 14-08-2008 with the 77mm hex shaft, the 100mm shaft came in 30-11-2009.
  1. Audi A4 B8 2011 CAHA engine cranks but doesnt start?
    By hussnainh8 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 16-10-2025, 09:27 PM
  2. Question P261A – Coolant Pump 2 issue (pump failure), need advice.
    By jkeeeng in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 07-02-2017, 10:28 PM
  3. Question Intake manifold flap fault b8 2.0tdi 2010 CAHA ENGINE
    By alfasport in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 15-03-2016, 03:14 PM
  4. Please Help Audi A6 C6 2.0 tdi 170 ps CAHA gearbox mounting
    By Sambor11 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 26-11-2015, 08:36 PM
  5. 2.0 TDi Oil Pump Failure Issue - Engine Codes
    By seanxb in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 12-02-2013, 12:00 AM
