Thread: My Free VCDS today (with pic) But what does it mean? Bad Turbo?
Results 1 to 10 of 16
  1. My Free VCDS today (with pic) But what does it mean? Bad Turbo?
    Apr 2023
    Cheltenham
    Hiya i have also posted this in the VCDS page as im not sure which place is best, i hope this ok to also go in this section
    Hay here's my question Guys ....here's the short one ... I got a free quick VCDS test done today but i have no idea what the results (I'm a novice) are so any help please?
    The longer one....
    i have a problem with my beloved Passat 2005 B5.5 1.9tdi 130bhp that started 2 days ago. (i think) The turbo is not working properly, i choose to drive in low rpm otherwise the turbo kicks in and then it jolts a little bit as it works then doesn't then works then doesn't reasonably rapidly in quick succession.
    I have spent hours reading up on here and looking at videos on youtube and i think i now have JUST enough knowledge to know it could be one of many things lol! such as.....
    split pipes, Fuel filter(?), Fuel pipe blockage, blocked Turbo vane actuator, EGR blocked with Crud in general, Reverse lights fuse (reverse lights do work tho!),
    Bad MAP sensor (i removed and sprayed it with Halfords Electrical contact cleaner)
    A Bad MAF sensor (I didn't have a 5 star Torx security bit, so removed the complete unit it is screwed onto from the top of the air filter box cover and sprayed as best i could, probably done nothing tho as i couldn't get close enough, i have ordered a correct torx bit)
    or basically the turbo on its last legs
    The orange coil light does not flash to suggest a fault code has been logged!
    My questions are - does the picture show what has been tested.
    - do the readings show something is not correct or above or below what it should be, basically what are the results showing?
    - is there some specific test the guy could have done to find a fault as im not sure how extensive the test he did was
    -can you tell by the picture what he tested for? was it just the MAP sensor?
    -Last question what the bloody hells wrong? i love my Passat LOL im hoping the results show its just a bad MAF or MAP?
    The very kind lad said he is not to up on the VCDS system so i should go to the garage down the road to ask them what they think of the results shown in the picture....
    Turns out they don't use VCDS they use a snap-on test system? so he didn't look at the picture i wanted to show him and has booked it in for him to test it himself (£66 to plug in and test it)
    like i said i have read up for a few hours and watched videos to try and give me more info before i post this as i am a newbie to this so please be kind lol
    ive tried to include as much info as i could in the hope some of your knowledgeable guys can give me some help and advice please
  2. Re: My Free VCDS today (with pic) But what does it mean? Bad Turbo?
    Jul 2008
    Lisburn
    16 Post(s)
    on a quick read over i am going to say sticky EGR as the duty cycle is way down.
    Stewart
    2012 Q5 2.0D quattro S line Plus
    1986 coupe quattro (kv)
    1972 mini 1400 100BHP A series
    2016 F-Pace Portfolio X761 2.0D 180HP
  3. Re: My Free VCDS today (with pic) But what does it mean? Bad Turbo?
    134 Post(s)
    2013 Post(s)
    None of that data relates to a probaly boost issue, he needed to check the fault code memory; just because the MIL doesn't come on doesn't means a code(s) isn't stored for boost delivery problems. An EGR fault SHOULD bring on the MIL but not always.
  4. Re: My Free VCDS today (with pic) But what does it mean? Bad Turbo?
    Apr 2023
    Cheltenham
    Thanks for the reply's guys, Crasher what's an MIL ? (I Am very new to this, 'Very' being an understatement!, keen to learn tho lol)
    i have taken the EGR off and it looks pretty dirty (see the pics) so I'm going to clean it.
    i have Mr muscle oven cleaner and Halfords electrical contact cleaner (solvent) which one would you use
    and do i need to apply anything to the rubber seal end before i screw it back together?
    cheers Ben
  5. Re: My Free VCDS today (with pic) But what does it mean? Bad Turbo?
    Apr 2023
    Cheltenham
    Hay i cleaned it, not spotless but 95% is off, i have a felling thats not the issue tho as the part of the rod where the valve moves up and down was clean, thus showing it was probably still going up and down
    ive left it unassembled so tomorrow i can spray a can of turbo cleaner into the turbo!
  6. Re: My Free VCDS today (with pic) But what does it mean? Bad Turbo?
    134 Post(s)
    2013 Post(s)
    Turbo cleaning sprays are snake oil
  7. Re: My Free VCDS today (with pic) But what does it mean? Bad Turbo?
    Apr 2023
    Cheltenham
    im using mr muscle instead
  8. Re: My Free VCDS today (with pic) But what does it mean? Bad Turbo?
    134 Post(s)
    2013 Post(s)
    That is water based and causes the turbine shaft exhaust side piston ring to rust and start leaking plus the vane actuator ring rusts and sticks even more, it is useless at dissolving the carbon. If you took it apart and soaked it overnight in an ultrasonic cleaner it still won’t shift it, it has to be bead blasted off.
  9. Re: My Free VCDS today (with pic) But what does it mean? Bad Turbo?
    Apr 2023
    Cheltenham
    i cleaned it with mr muscle and it is a lot better than it was probably 90% better but not totally back to normal tho. ideally i need to take it off and clean it properly but tbh ive never done anything more than an oil and filter change on my cars before so removing and cleaning the egr and manifold + Mr M cleaning the turbo yesterday was by far the most ive ever done! i think taking the turbo off could maybe be a bit too much for me, i probably could do it if a had a ramp and nothing went wrong! anyway ive booked it in for a snap-on plug in test next week. is snap on testing any good?
  10. Re: My Free VCDS today (with pic) But what does it mean? Bad Turbo?
    134 Post(s)
    2013 Post(s)
    They are much easier to do than a transverse engine but I do think you would need to get it up on stands or ramps and I don’t like them.
    By 2005 B5.5 in forum VCDS - Help Requests
    Last Post: 13-04-2023, 11:28 PM
  2. VCDS app for apple NOW IN APP STORE (it's free)
    By Q7quattro in forum VCDS - General Questions
    Last Post: 01-10-2014, 12:37 PM
  3. got my new genuine vcds today ;-)
    By cdste in forum Scotland
    Last Post: 26-04-2014, 06:04 PM
  4. 2.5tdi turbo blown today
    By Burfy in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 19-07-2013, 08:29 PM
  5. Yesterday the turbo stopped working, Today it worked. Whats going on????
    By dubstar81 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 14-04-2013, 09:28 PM
