Hiya i think this in the right place
Hay here's my question Guys ....here's the short one ... I got a free quick VCDS test done today but i have no idea what the results (I'm a novice) are so any help please?
The longer one....
i have a problem with my beloved 2005 B5.5 1.9tdi 130bhp Passat that started 2 days ago. (i think) The turbo is not working properly, i choose to drive in low rpm otherwise the turbo kicks in and then it jolts a little bit as it works then doesn't then works then doesn't reasonably rapidly in quick succession.
I have spent hours reading up on here and looking at videos on youtube and i think i now have JUST enough knowledge to know it could be one of many things lol! such as.....
split pipes, Fuel filter(?), Fuel pipe blockage, blocked Turbo vane actuator, EGR blocked with Crud in general, Reverse lights fuse (reverse lights do work tho!),
Bad MAP sensor (i removed and sprayed it with Halfords Electrical contact cleaner)
A Bad MAF sensor (I didn't have a 5 star Torx security bit, so removed the complete unit it is screwed onto from the top of the air filter box cover and sprayed as best i could, probably done nothing tho as i couldn't get close enough, i have ordered a correct torx bit)
or basically the turbo on its last legs
The orange coil light does not flash to suggest a fault code has been logged!
My questions are - does the picture show what has been tested.
- do the readings show something is not correct or above or below what it should be, basically what are the results showing?
- is there some specific test the guy could have done to find a fault as im not sure how extensive the test he did was
-can you tell by the picture what he tested for? was it just the MAP sensor?
-Last question what the bloody hells wrong? i love my Passat LOL im hoping the results show its just a bad MAF or MAP?
The very kind lad said he is not to up on the VCDS system so i should go to the garage down the road to ask them what they think of the results shown in the picture....
Turns out they don't use VCDS they use a snap-on test system? so he didn't look at the picture i wanted to show him and has booked it in for him to test it himself (£66 to plug in and test it)
like i said i have read up for a few hours and watched videos to try and give me more info before i post this as i am a newbie to this so please be kind lol
ive tried to include as much info as i could in the hope some of your knowledgeable guys can give me some help and advice please
cheers Ben
