Thread: Low Brake Pad Warning Light
  1. Low Brake Pad Warning Light
    Nov 2019
    Bridgend, UK
    Been searching through the forums and found something similar to the issue I'm having in the A6 forum but not a definitive answer.
    Low Brake pad warning light came on and found the the outer circumference on the disc had worn a lip which worked it's way through the sensor. When I took the pad out with the sensor in, the two core wire came away in my hand. I duly changed the pads (even though there was plenty of wear left in them) but the warning light stays on. Scanned with VCDS with no apparent fault code present. I suspected a dodgy sensor on the new pad so created a shorting circuit at the plug, still the same.
    Is the signal purely closed or open? I mean there's no particular resistance value required, just a straight forward switch? If so, looks like I'm left with tracing the wires back from the socket to wherever they go to as it would seem an open circuit somewhere further back.
    Does anyone know where the terminations are so I can simply create a dummy signal at source and thereby bypassing the wiring going down to the pad? It'll save me a whole lot of time
    Thanks in advance.......JJ
  2. Re: Low Brake Pad Warning Light
    131 Post(s)
    1976 Post(s)
    Usually it is the left front harness failing internally, they are available as a repair part but are supposed to be run through to the ABS unit, most people splice them in. There are three different versions according to VIN, all are £92.38
  3. Re: Low Brake Pad Warning Light
    Nov 2019
    Bridgend, UK
    @Crasher....thanks very much. Will have a good look this weekend.
  1. Red brake warning light flashing and constant abs light
    By lee.p.wood in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 31-08-2014, 06:45 PM
  2. Question Rear Brake light warning light
    By hafu14 in forum Touran - Sharan - Caravelle
    Last Post: 27-05-2013, 12:44 PM
  3. Replaced Brake fluid (bled system). Red Brake warning light appears!
    By keemaklan in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 18-12-2010, 03:21 PM
  4. Flashing colant light and no brake warning light
    By cookie7354 in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 19-09-2008, 11:24 PM
  5. DIS Brake Fluid Warning with ABS warning light
    By radar1022 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 03-04-2007, 10:42 AM
