Thread: Oil Leak, Top End, Back of Engine
Results 1 to 9 of 9
  1. Oil Leak, Top End, Back of Engine
    Jan 2009
    Yeovil, Somerset
    Hi All,
    When stopped in traffic with blower on I'm getting a strong burnt oil smell into the cabin, it appears oil is dripping onto the manifold and you can also see signs of smoke from under bonnet. A friend has suggested that it could be from the VVT gasket/seal. I have a new cam cover seal to replace but he said it could be worth doing this VVT one at the same time.
    Could someone shed some light on the complexity of replacing this gasket?
    Regards
    Roy
  2. Re: Oil Leak, Top End, Back of Engine
    134 Post(s)
    2009 Post(s)
    The engine is a?
  3. Re: Oil Leak, Top End, Back of Engine
    Jan 2009
    Yeovil, Somerset
    Oopps, yeah could help!! It's a 2007, 1.8T Cab, Engine code BFB.
  4. Re: Oil Leak, Top End, Back of Engine
    134 Post(s)
    2009 Post(s)
    The 90 degree pipe from the oil filter crankcase breather is prone to splitting, I had one in last week from the local Audi main dealer who could not fix it, the stench of crankcase fumes around the front of the car was so obvious I could not comprehend how they missed it.
  5. Re: Oil Leak, Top End, Back of Engine
    Jan 2009
    Yeovil, Somerset
    Thanks Crasher,
    I will take a look at that. However, I do have actual signs of oil seeping from the back of the cam cover gasket dripping onto the manifold hence the need to change it and have heard that it is also wise to change the VVT gasket and was wondering the complexity of this task or is it even a known issue?
    Cheers Chris
  6. Re: Oil Leak, Top End, Back of Engine
    134 Post(s)
    2009 Post(s)
    It is usually the VVT gasket or 1/2 round seal, we lift the VVT unit up a bit by slackening the cams, clean out and fit a new gasket and seal with a smidgin of RTV on the seal. On mine I had a second seal, trimmned off the lips and RTV'd it in front of the other one, I think it is a poorly designed part that could do with an aftermarket upgrade.
  7. Re: Oil Leak, Top End, Back of Engine
    Jan 2009
    Yeovil, Somerset
    Ok thanks, that makes sense. If I am needing to loosen off the camshaft, do I need a tool or possibly make some marks to keep everything in position?
  8. Re: Oil Leak, Top End, Back of Engine
    134 Post(s)
    2009 Post(s)
    You are supposed to compress the VVT unit but you should be able to lift it up enough the replace the parts.
  9. Re: Oil Leak, Top End, Back of Engine
    Jan 2009
    Yeovil, Somerset
    Perfect, thanks
  1. oil leak at the top back of the AWX TDI engine
    By Google44 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 09-04-2013, 10:23 PM
  2. Water/Coolant Leak at back of engine bay
    By pugville in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 10-03-2013, 05:34 PM
  3. Oil leak back of head?
    By Mike McKinstry in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-04-2012, 03:14 PM
  4. Please Help crankshaft back seal leak oil
    By golfrr in forum Touran - Sharan - Caravelle
    Last Post: 05-10-2010, 09:37 PM
  5. Please Help coolant leak back of engine
    By chapterg8 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 21-11-2008, 11:34 AM
