Thread: Various lights on dash
Results 1 to 10 of 10
  1. Various lights on dash
    Mar 2023
    Oldham, England
    Just wondering if anyone could tell me what is most likely at fault here. I have lights on the dash for ABS/TPMS/Parking brake
    The ABS module seems to stand out but I'm not sure.
    Thanks in advance!
    Code:
    Coding: 36A100B824 (hex)
    Fault codes:
    00276 ABS Outlet Valve - Left Rear (N136)
    00386 Minus exit audio channel for language/telephone
    Rear heater & A/C
    Part #: 4G0919158D
    Component: KLIMA FOND
    Software version: 0062
    ASAM/ODX identifier: EV_ClimaContrUnitRearUDS
    Coding: 02 (hex)
    Fault codes:
    00075 Safety device for plug socket 2 (S185)
    Parking/steering assist
    Part #: 4H0919475M
    Component: PARKHILFE PLA
    Software version: 0025
    ASAM/ODX identifier: EV_EPHVA2CAU57X0000
    Coding: B81306 (hex)
    Fault codes:
    13637412 Manufacturer-specific code
    13637413 Manufacturer-specific code
    13637417 Manufacturer-specific code
    Central electronics
    Part #: 4H0907063BF
    Component: BCM1 2.0
    Software version: 0100
    ASAM/ODX identifier: [none]
    Coding: 0200A01150B49FE0C1810083A0001908CF9DC3082F080101000008402100 (hex)
    Fault codes:
    01320 Control Module for Climatronic (J255)
    Body/convenience system
    Part #: 4H0907064BP
    Component: BCM2 2.0
    Software version: 0330
    Coding: 011F0E2200B9048183200884080100000000000000000000000000000000 (hex)
    Fault codes:
    02616 Unlocking fuel tank cap
    02615 Locking fuel tank cap
    00230 Transmission Park Selector Switch (F305)
    Driver's door
    Part #: 4G8959793E
    Component: TSG FA
    Software version: 0212
    Coding: 011F16215E01628002080012 (hex)
    [No fault codes]
    Front passenger's door
    Part #: 4G8959792E
    Component: TSG BF
    Coding: 011F16215E01628002080002 (hex)
    [No fault codes]
    Rear left door
    Part #: 4G8959795E
    Component: TSG HL
    Coding: 010F14214001628002080002 (hex)
    [No fault codes]
    Rear right door
    Part #: 4G8959795E
    Component: TSG HR
    [No fault codes]
    Driver's seat
    Part #: 4G8959760
    Component: MEM-FS
    Software version: 0154
    Coding: 00781B0000006001000001010101102030303232203232 (hex)
    Fault codes:
    Ignition authorization
    Part #: 4H0907064BP
    Component: BCM2 2.0
    Coding: 05B82F06000000000000 (hex)
    Fault codes:
    02823 Requirements for Locking the Steering Column Lock not met
    Lane-change system
    Part #: 4G0907566D
    Component: J769 SWA Master
    Software version: [none]
    Coding: 1101 (decimal)
    [No fault codes]
    Back-up camera
    Part #: 4H0907428
    Component: TopView
    Software version: 0090
    ASAM/ODX identifier: EV_CamerSysteTopViewAUDI
    Coding: 0200000001000100000102000000 (hex)
    Fault codes:
    9616921 Manufacturer-specific code
    9616922 Manufacturer-specific code
    Sensor electronics
    Part #: 4G0907637B
    Component: SARA 6D
    Software version: 0004
    ASAM/ODX identifier: EV_SARA
    Coding: [none]
    [No fault codes]
    Onboard Camera
    Part #: 4G0907217
    Component: DPC-SG
    Software version: 0036
    ASAM/ODX identifier: EV_OnBoardCamerDPC
    Coding: 64060000 (hex)
    [No fault codes]
    Seatbelt pretension (front left)
    Part #: 4H0980945B
    Component: RGS-VL
    Software version: 0080
    ASAM/ODX identifier: EV_RGS_L
    Coding: 0006E008031F0300070308004244CA010000 (hex)
    [No fault codes]
    Seatbelt pretension (front right)
    Part #: 4H0980946B
    Component: RGS-VR
    ASAM/ODX identifier: EV_RGS_R
    [No fault codes]
  2. Re: Various lights on dash
    2009 Post(s)
    Clear the codes, test drive, rescan and post. The fuel door problem is common right across the VAG range.
  3. Re: Various lights on dash
    Mar 2023
    Oldham, England
    These codes have been present a few times, I try to clear them and then come back immediately and stay on during and after any drive.
    Fuel door i'm not bothered about!
  4. Re: Various lights on dash
    Apr 2009
    Surrey
    183 Post(s)
    What's the state of the battery? Random warning lights is often a sign of a battery that is starting to be past its best, even if it starts the car fine and shows no outward signs of failing
  5. Re: Various lights on dash
    2009 Post(s)
    Quote Originally Posted by Mike_se20 View Post
    You will do when it sticks, you are out of juice and the emergency release cable snaps...
    You need a proper code read such as VCDS
  6. Re: Various lights on dash
    Apr 2009
    Surrey
    183 Post(s)
    Based on my own experience, the pull cord is useless when the flap sticks as it is the release plunger that jams not the lock. The only option is to force the filler flap open (Audi Assist insisted I sign a waiver that it might damage the car!) and then get the plunger assembly replaces. Ans of course you are only aware there is a problem when you need to fuel the car
  7. Re: Various lights on dash
    Mar 2023
    Oldham, England
    I fitted a brand new battery last week, also coded it in properly. Was hopeful it was this that was causing it as the voltage was low and the battery had seen better days, sadly the faults remain
  8. Re: Various lights on dash
    Mar 2023
    Oldham, England
    True, it's been a bit iffy since I had the car 2 years ago, just takes a couple of locks and unlocks and then it opens. For now.....!
    Yes I was thinking I might need VCDS. i don't have it unfortunately so I might need to find someone who does or bite the bullet and take it in :-/
  9. Re: Various lights on dash
    Jul 2016
    Chestfield kent
    81 Post(s)
    Filler flap… Get it sorted one way or another, because It WILL let you down when you least need it. Speaking from experience…
  10. Re: Various lights on dash
    2009 Post(s)
    The number of times we report this fault on a service and customers ignore it then all hell breaks loose when they are stuck "you never warned me"... ohh yes we did, check your invoice and code report!
  1. Dash like traffic lights then everything goes off on dash whist driving
    By azumore in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 11-04-2022, 02:38 PM
  2. Question Dash Lights
    By Bwithers in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 08-11-2013, 02:41 PM
  3. dash lights intermitant and interior lights staying on for ages
    By mystic.bertie in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 04-02-2011, 06:27 PM
  4. Dash lights
    By Bilbobaggins in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-12-2007, 12:32 PM
  5. Dash Lights
    By chris.fulton in forum Golf MK4 - 1999 - 2004
    Last Post: 08-11-2007, 04:05 PM
