Thread: Knocking noise when releasing accelerator
Results 1 to 9 of 9
  1. Knocking noise when releasing accelerator
    Jun 2018
    PL
    Hello
    What may cause a knocking noise when taking the foot off the accelerator pedal (front, right side)?
    The knocking noise is audible only when driving and releasing the accelerator - if braking still knocking but when touch the accelerator it dissapears
    Could it be an engine mount?
  2. Re: Knocking noise when releasing accelerator
    Jul 2008
    Lisburn
    16 Post(s)
    knocking under braking - auto or manual?
    if manual i would say you have warped disks and a you need to get you suspension checked. probably something like a drop link
    if auto yes that opens it up to engine mounts?
    Stewart
    2012 Q5 2.0D quattro S line Plus
    1986 coupe quattro (kv)
    1972 mini 1400 100BHP A series
    2016 F-Pace Portfolio X761 2.0D 180HP
  3. Re: Knocking noise when releasing accelerator
    131 Post(s)
    1976 Post(s)
    Bottom ball joint, common 8K failure
  4. Re: Knocking noise when releasing accelerator
    Jun 2018
    PL
    The knocking is audible only when the accelerator pedal release.
    While braking - still knocking but disappears only when touch the accelerator :/
    Auto (Tiptronic)
    The complete front suspension was replaced 3~4k km ago... It looks OK
  5. Re: Knocking noise when releasing accelerator
    Jul 2008
    Lisburn
    16 Post(s)
    check engine mounts and exhaust - get someone to se if they can see excessive movement with the bonnet open as you step on and of the accelerator and brake.
    Stewart
  6. Re: Knocking noise when releasing accelerator
    Jun 2018
    PL
    Issue solved!
    Right engine mount died
  7. Re: Knocking noise when releasing accelerator
    131 Post(s)
    1976 Post(s)
    Not a common failure
  8. Re: Knocking noise when releasing accelerator
    Jul 2008
    Lisburn
    16 Post(s)
    Happy days , was it an easy enough swap out?
    Stewart
  9. Re: Knocking noise when releasing accelerator
    Jun 2018
    PL
    I would say about 2h job
  1. sucking noise when i let off accelerator
    By nickeym1 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 05-06-2009, 09:33 PM
  2. Please Help Noise when lifting off accelerator
    By 737-800 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 06-04-2009, 03:16 PM
  3. accelerator rubbing noise, polo
    By 1043cc in forum Polo - Derby - Lupo - Fox
    Last Post: 17-04-2008, 08:39 AM
  4. Bora 1.9 TDI 130 SE Auto accelerator noise
    By Deeps in forum Bora - 1998 - 2005
    Last Post: 21-12-2007, 06:06 PM
  5. A6 1.8T rattle / clicking after releasing accelerator
    By torrox in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 04-05-2007, 04:19 PM
