Thread: Fabia II Steering Rack Play - Repairable?
  1. Fabia II Steering Rack Play - Repairable?
    Jan 2008
    Cornwall
    The next issue on my radar to sort out is the play on the left side of my steering rack. It was an MOT pickup for a couple of years running, but I have yet to address it since I bought the car this year.
    I can see no spares available for repair of the rack, but if the play is not getting any worse, seemingly, then it would seem likely that something isn't tight enough, as opposed to wear.
    Does anyone have any pointers to address the issue? It doesn't seem particularly efficient if the whole rack needs to be replaced, especially as the subframe needs to be dropped to do so.
    To clarify, it is the nearside that appears to be the problem and can be felt at the wheel and through the steering, if turned side to side.
    Solved:
    LH track rod end was very worn. Replaced and steering play has disappeared.
  2. Re: Fabia II Steering Rack Play - Repairable?
    135 Post(s)
    2038 Post(s)
    If it is just the left that could be the racks inner support bushing which isn't easy to obtain or the track rod inner joint which is easy to buy and replace.
  3. Re: Fabia II Steering Rack Play - Repairable?
    Jan 2008
    Cornwall
    As per usual, I'll just have to bite the bullet and have a look, but I like to have spares to hand when taking things apart and committing.
  4. Re: Fabia II Steering Rack Play - Repairable?
    135 Post(s)
    2038 Post(s)
    Yes, we like to have what we think we will need at hand, I am just about to start a full front to back mechanical rebuild on a 95 Audi S2 Avant and I spent hours working through the parts system and workshop manuals listing everything I could think of and then spent months gathering all the parts together from Germany but still I reckon I have only hit 95% of what I need so for the rear end alone we have booked two weeks with it dead on one of the lifts.
  5. Re: Fabia II Steering Rack Play - Repairable?
    Jan 2008
    Cornwall
    Solved:
    I have still to replace the drop links and this should quieten down the front end knocks a fair bit.
  6. Re: Fabia II Steering Rack Play - Repairable?
    Jan 2008
    Cornwall
    Drop links now replaced and the front end is as quiet as a mouse...
  1. MOT adivsory - play in steering rack inner joint?
    By Bear77 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 26-05-2017, 09:58 AM
  2. Play in steering rack
    By Peter_HMR in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-08-2012, 07:41 PM
  3. Please Help 6N1 Polo leak in power steering pipe from pump to steering rack
    By crauch6 in forum Polo - Derby - Lupo - Fox
    Last Post: 18-02-2012, 08:36 AM
  4. LT 28 steering rack play
    By rsitup in forum The Commercial Range
    Last Post: 08-05-2009, 08:44 PM
  5. Please Help 2000 2.5TDI T4 Steering rack end play
    By Anthony Bigwood in forum The Commercial Range
    Last Post: 29-11-2008, 12:09 AM
