Thread: Lost Reverse, 1st, 3rd and 5th gears!
Results 1 to 10 of 13
  1. Lost Reverse, 1st, 3rd and 5th gears!
    Oct 2018
    York
    9 Post(s)
    As header, I was driving my Golf GT Sport a little, shall we say...spiritedly, when I suddenly lost the ability to select 1st, 3rd and 5th. On pulling over, I found reverse had gone too. Limped it home, thinking it may be the gear cables, but locking the gear stick and resetting the cables didn't solve it. Have I broken something serious?
    It's a BKD-engined 2008 diesel model.
  2. Re: Lost Reverse, 1st, 3rd and 5th gears!
    131 Post(s)
    1976 Post(s)
    Initially I thought one of the DSG clutches has failed but I get the feeling it is manual?
  3. Re: Lost Reverse, 1st, 3rd and 5th gears!
    Oct 2018
    York
    9 Post(s)
    Yes, it's a manual
  4. Re: Lost Reverse, 1st, 3rd and 5th gears!
    Oct 2018
    York
    9 Post(s)
    I've done a bit of fiddling with cable length, and I can just about get 1st gear. But none of the other 'odd' gears
  5. Re: Lost Reverse, 1st, 3rd and 5th gears!
    131 Post(s)
    1976 Post(s)
    That is probably a broken gear selector, they are made of brass and can crack; when I rebuilt my 02M I replaced three of the selectors with the later steel versions, you are looking at a total box strip down.
  6. Re: Lost Reverse, 1st, 3rd and 5th gears!
    Oct 2018
    York
    9 Post(s)
    Thanks for the info Crasher, much appreciated. Looks like a replacement gearbox then; no way am I stripping this one, totally clueless about gearboxes.
  7. Re: Lost Reverse, 1st, 3rd and 5th gears!
    131 Post(s)
    1976 Post(s)
    Actually rather lovely things to work on when you have the tools, because it was my own (Octavia 1U 6 speed conversion) I could sit down in spare time and thoroughly obsess about the details; I spent more in parts than a full recon would have cost... In almost all other cases we sub the work out to a local VAG gearbox specilsist.
  8. Re: Lost Reverse, 1st, 3rd and 5th gears!
    Oct 2018
    York
    9 Post(s)
    Wow. What a pig it is, getting the gearbox out without also removing the engine. When I looked at it I thought....piece of cake. But no. Next time I'll remove both as a unit. In fact, I may yet remove the engine to put the soon-to-arrive replacement 'box on it before installing.
    The only way I could do it was to turn the gearbox anticlockwise (looking at the car from the gearbox side), before dropping the engine quite a bit, and it eventually came off. Never easy, is it?
  9. Re: Lost Reverse, 1st, 3rd and 5th gears!
    131 Post(s)
    1976 Post(s)
    We drop the subframe, pull it back and tie it out the way with a strap plus we use a proper gearbox jack AND the car up in the air on a lift. On your back, on the floor, I can't imagine the pain I would be in... it's how I used to do it 40 years ago but my old bones can't hack it anymore.
  10. Re: Lost Reverse, 1st, 3rd and 5th gears!
    Oct 2018
    York
    9 Post(s)
    Aye, that's the way to do it! I had a look at the subframe, and thought ******** to that...plus I didn't fancy going to get an alignment afterwards. Hopefully the replacement will get here tomorrow. Then I'll have a day to realise that getting a 'box out isn't even half the story ;-)
  1. Please Help Cruise control/lost gears /over rev issue
    By Rolney in forum Golf MK6 - 2009 - 2013
    Last Post: 29-06-2020, 06:12 PM
  2. Please Help Audi A7 Gearbox Malfunction - Clutch Slip + lost Uneven gears
    By 123taylor123 in forum A7 - S7
    Last Post: 02-12-2018, 09:45 AM
  3. My gearbox has lost 1 and 2 gears :(
    By mumutley in forum TT - 8N Forum - 1998 - 2006
    Last Post: 13-02-2016, 08:38 PM
  4. Lost all gears - grinding
    By 4000 in forum Golf MK4 - 1999 - 2004
    Last Post: 22-12-2013, 07:30 PM
  5. Please Help Stiff gears and no Reverse
    By Awfmaster in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 15-09-2009, 08:41 PM
