Thread: Exhaust Gas Temperature Sensor 3 - Passat B6
  1. Exhaust Gas Temperature Sensor 3 - Passat B6
    Mar 2023
    Oxford/UK
    Hi all,
    I'm having the following error in vcds on my Passat b6 Estate 2.0 TDI 170 BMR:
    Code:
    1 Fault Found:
    005213 - Exhaust Gas Temperature Sensor 3
                   P145D - 006 - Short to Plus
                 Freeze Frame:
                        Fault Status: 11100001
                        Fault Priority: 1
                        Fault Frequency: 4
                        Reset counter: 40
                        Mileage: 0 km
                        Time Indication: 0
                 Freeze Frame:
                        RPM: 0 /min
                        Torque: 0.0 Nm
                        Speed: 0.0 km/h
                        Temperature: 39.0°C
                        Text:  176    C
                        Text:  164    C
                        Text: 1000    C
                        Raw, Form. N/A: 000 000 000
    Readiness: N/A
    Is the sensor the one I marked?
    Thanks.
    LE: For some reason couldn't post a reply.
    So the faulty sensor it's actually the number 4 shown in the picture above.
    The temp on the sensor was 300° even with the engine off.
    Replaced it and no errors, the temperature shown was 12° and start rising after starting the engine.
  2. Re: Exhaust Gas Temperature Sensor 3 - Passat B6
    2013 Post(s)
    They have, as you know, three sensors, 1, 3 and 4... Sensor 1 is in the exhaust manifold turbo outlet, 3 is on top of the DPF and 4 is after the DPF.
  3. Re: Exhaust Gas Temperature Sensor 3 - Passat B6
    Mar 2023
    Oxford/UK
    So sensor 3 is the one that's in an angle with brown connection if I'm not mistaken.
  4. Re: Exhaust Gas Temperature Sensor 3 - Passat B6
    Mar 2023
    Oxford/UK
    The sensor after dpf is kinda stuck at 300 degrees with engine stopped or with it running. I've noticed it jumps to 1000 degrees at the start and after it stays steady at 300.
    Also took the sensor out the error still there, and the temp still at the 300 with the sensor out. Also checked the sensor and it seems to be broken, has no resistance when heating with a heat gun. Took the one before dpf and it reads fine...
    What bothers me is why I'm still getting the error with the sensor out...? It will clear with a new sensor?
    Also I can't find any oem number on the sensor must've been changed by the previous owner.
  5. Re: Exhaust Gas Temperature Sensor 3 - Passat B6
    Mar 2025
    BiH
    Quote Originally Posted by alexduni View Post
    Hi all,
    Code:
    1 Fault Found:
                 Freeze Frame:
                        Fault Priority: 1
                        Fault Frequency: 4
                        Reset counter: 40
                        Mileage: 0 km
                        Time Indication: 0
                 Freeze Frame:
                        RPM: 0 /min
                        Torque: 0.0 Nm
                        Speed: 0.0 km/h
                        Temperature: 39.0°C
                        Text:  176    C
                        Text:  164    C
                        Text: 1000    C
    Readiness: N/A
    Thanks.
    Hellou
    I think I have same problem, 2.0 TDI BMP engine code. Could you tell me procedure of replacing a sensor, did you need to take off DPF, is it accessible from top of the engine or maybe from below?
  1. Exhaust Gas Temperature Sensor, Bank 1 sensor 1.
    By petrolhead63 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 07-01-2020, 04:51 PM
  2. P242C Exhaust Gas Temperature Sensor B1 S3
    By billa79 in forum Passat - B7 Forum - 2011 - 2015
    Last Post: 05-05-2019, 09:13 PM
  3. Question Exhaust Gas Temperature Sensor Bank 1 Sensor 1 fault -> more noise?
    By tomas_v in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 22-02-2018, 12:32 AM
  4. EML on. Which exhaust gas temperature sensor ? Please Help
    By Radders567 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 17-09-2012, 04:34 PM
  5. Exhaust Gas Temperature Sensor fault
    By looney in forum VCDS - Help Requests
    Last Post: 20-06-2012, 09:03 PM
