Thread: No windscreen washer function!!!
  1. No windscreen washer function!!!
    Mar 2020
    Oxfordshire
    So today I was trying to operate the windscreen washer function on my passat but to no avail
    Upon diagnosis I checked the washer motor itself by connecting it straight to the battery and that works fine so it could be a faulty switch
    All fuses are okay
    Is there a relay for that system?
    Could there be a break in the wire?
    Any info would be appreciated thank you
  2. Re: No windscreen washer function!!!
    131 Post(s)
    1976 Post(s)
    You need to operate the pump relays J729 and J730 using a diagnostic system in output tests of the body control module (address 09) and see if they click, if they do, check the wiring from the BCM to the pump.
  3. Re: No windscreen washer function!!!
    Mar 2020
    Oxfordshire
    Okay mate
    I don’t have a diagnostic system but I could find the relays and check for some sort of continuity via multi meter
    Where is the bcm?
  4. Re: No windscreen washer function!!!
    Mar 2020
    Oxfordshire
    Sorry the bcm is what holds all the relays?
  5. Re: No windscreen washer function!!!
    131 Post(s)
    1976 Post(s)
    They are integral to the BCM, without a diagnostic system this is going to be extremely difficult.
  1. Question Windscreen washer jets
    By StephenM in forum Audi A3 - 8V - 2012 - 2016
    Last Post: 29-05-2016, 09:03 PM
  2. Windscreen Washer cap
    By markiwill83 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 24-11-2014, 05:22 PM
  3. Windscreen washer jets
    By invisiblekid75 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 09-02-2014, 02:23 PM
  4. Windscreen Washer Jets...
    By srisport in forum Passat - B7 Forum - 2011 - 2015
    Last Post: 23-05-2012, 03:08 AM
  5. Please Help windscreen washer bottle
    By jacohelp in forum Polo - Derby - Lupo - Fox
    Last Post: 01-02-2009, 06:04 PM
