Thread: 2013A8L suspension Fault
  1. 2013A8L suspension Fault
    Aug 2019
    NorthWest
    i am coming to my wits end with this.... a brief history, coming back from ukraine suspension light comes on... take car in for diagnostics and get told a broken wire but pump is not producing enough pressure. replace pump and now i can see full pressure at the pump but nothing in the system... car is now out of mot. took it to Audi for further diagnostic and now they are saying it is maybe the suspension ecu 3.5K may fix it i located a used ECU which i assume goes in the boot behind the seats. could someone advise what needs to be done once this is fitted... how do i get the car to communicate with the new module?
  2. Re: 2013A8L suspension Fault
    131 Post(s)
    1973 Post(s)
    The problem I have seen is corrosion damage to the valve block wiring but you will have seen this when fitting the compressor.
  1. Question A6 Allroad - Air Suspension fault
    By martinfrench in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 14-08-2020, 04:33 PM
  2. RS6 air suspension fault
    By Hausi in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 17-04-2019, 08:15 AM
  3. Audi Q7 air suspension fault
    By lee1970 in forum VCDS - Help Requests
    Last Post: 03-11-2018, 07:21 PM
  4. Q7 air suspension fault code
    By h2bnd in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 31-12-2015, 05:40 PM
  5. Self Levelling Suspension Fault - Locked Suspension Yelow Warning on Dash
    By ceilidhalfie in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 04-12-2014, 05:01 PM
