Thread: A6 C6 central locking and indicator faults after heavy rain
  1. A6 C6 central locking and indicator faults after heavy rain
    Mar 2023
    Dorset
    Hi all, new member here. I have a 2007 a6 c6 which suffers from electrical issues after heavy rain. Have checked plenum drain I can get to which is now clear. Electrical issues are central locking doesnt lock all doors then alarm goes off after a few mins. Indicator not flashing at any sort of pattern, long and short flashes all over the place. Also get electric handbrake malfunction warning occasionally and loose power steering for a second at same time.
    Have checked under carpets in passenger side front and all is dry including the well the electrical boxes sit in. Im guessing this is an issue with one of the electrical boxes in the plenum chamber? Anyone had the same problem?
    Ps I think my top drains were partially clogged so wander if water has run over the top of the electircal boxes in plenum chamber?
  2. Re: A6 C6 central locking and indicator faults after heavy rain
    134 Post(s)
    2007 Post(s)
    Have you checked in the boot compartments for water under each light unit, especially offside?
  3. Re: A6 C6 central locking and indicator faults after heavy rain
    Jul 2008
    Lisburn
    16 Post(s)
    after i had the plenum water issue in mine the relay fault that prevented start ups and lit the dash up like it was Christmas was intermittent !! I cant remember the relay number but it was a simple swap out under the ECU and cheaper from audi over ebay.
    if you search some of my early posts you should get it
    Stewart
    2012 Q5 2.0D quattro S line Plus
    1986 coupe quattro (kv)
    1972 mini 1400 100BHP A series
    2016 F-Pace Portfolio X761 2.0D 180HP
  4. Re: A6 C6 central locking and indicator faults after heavy rain
    Mar 2023
    Dorset
    I will look at this thanks for the tip
  5. Re: A6 C6 central locking and indicator faults after heavy rain
    Mar 2023
    Dorset
    Im getting lights on dash after car left for a few hours. I thought tht just meant battery was dead ive been jump starting it and it fires up ok touch wood
  1. Question Related faults? Which caused which? (Central Locking, Boot Lock or keys?
    By boydcage in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 06-06-2016, 12:52 PM
  2. Central Locking - No Indicator Flash
    By Tyroaudi in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-04-2010, 07:11 PM
  3. Question central locking indicator problems
    By monkeyhanger in forum Passat - B5 Forum - 1997 -2005
    Last Post: 08-04-2010, 09:54 AM
  4. Please Help Golf mk4 indicator/central locking fault
    By pricey01 in forum Golf MK4 - 1999 - 2004
    Last Post: 24-01-2010, 11:54 AM
  5. Touran central locking/water ingress faults
    By bigwull in forum Touran - Sharan - Caravelle
    Last Post: 23-12-2007, 05:59 PM
