Good afternoon guys,
I’m having a multitude of problems on my 2010 V6T S5 that’s on 134XXX miles, currently on my dash I have a steering wheel light, traction control light, ABS light and on the multifunction I’m getting the message “sports differential problem”
I’ve connected up my scanner, cleared down any previous faults, took it for another drive and found the following faults present on the car (See pictures attached)
I don’t believe it to be an ABS sensor/ring fault as I used my scanner to do live data and it appeared to all be reading wheel speeds fine, leading me to believe it to be an electrical issue, seeing as the car doesn’t loose traction nor does the steering feel heavy or bad!
This issue is baffling me so if there are any common things that are known to go on these cars please do let me know; any help is appreciated!IMG_0653.jpg
