Thread: Live ignition feed from cabin fuse box - Audi A4 B6 Cabrio - Which fuse to piggy back?
  1. Live ignition feed from cabin fuse box - Audi A4 B6 Cabrio - Which fuse to piggy back?
    Sep 2007
    Hi all,
    I am about to swap my broken Audi Sat Nav Plus double din unit for Pioneer Carplay unit.
    The suppliers of the installation kit say I may need to provide a new power feed controlled by ignition on.
    I read an installation guide on another forum & it suggested using fuse position 19 in dash end panel box.
    He showed how to use a piggy back fuse holder & lead to tap this fuse slot.
    Looked easy but, in my car, position 19 is empty & has no supply cable.
    Can anyone suggest a suitable fuse position to tap by referencing the photos below?
    Thanks in advance.BF630D5F-0973-4C14-BAF5-E3132453A957.jpg9FDA804E-2730-4C7A-9BC3-DDC0AB1A79C0.jpg7A3DD9BA-B58A-4C0D-BF2A-EA3057ED5B0D.jpg4125E596-53EE-41DC-88C4-A2F7E9F240ED.jpg
  2. Re: Live ignition feed from cabin fuse box - Audi A4 B6 Cabrio - Which fuse to piggy back?
    134 Post(s)
    2019 Post(s)
    What is the VIN? From memory it doesn't have a proper what is called "Line 15" signal so to provide the standard Pioneer functionality you would require a CAN BUS adapter which provides various outputs such as reverse, ignition on, lights on etc.
  3. Re: Live ignition feed from cabin fuse box - Audi A4 B6 Cabrio - Which fuse to piggy back?
    Sep 2007
    Hi Crasher, Thanks for reply, Vin is WAUZZZ8H34K010668 October 2003 registration.
  4. Re: Live ignition feed from cabin fuse box - Audi A4 B6 Cabrio - Which fuse to piggy back?
    134 Post(s)
    2019 Post(s)
    Yes you are going to need a CAN BUS adapter to connect to the orange/lilac CAN BUS high and orange/brown CAN BUS low, the adapter will then provide you with very low level signal only voltages such as Line 15 for the Pioneer standard yellow ignition on.
  1. Fuse feed for dashcam - Car never powers down on some fuses?
    By chinnyhill10 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 07-01-2019, 01:17 PM
  2. Switched feed- which fuse box
    By Sparky_143 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 01-09-2013, 07:48 PM
  3. Fuse box or live feed, anyone tried taking the analogue clock out ?
    By sj_4x4 in forum Passat - B7 Forum - 2011 - 2015
    Last Post: 19-09-2011, 05:01 PM
  4. Getting 12v feed from fuse box with multimeter.
    By snoop2048 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 03-04-2010, 01:16 PM
  5. Radio Ignition live fuse
    By owend in forum Golf MK4 - 1999 - 2004
    Last Post: 24-08-2008, 10:16 AM
