Thread: Golf Mk6 CAYD 1.6 TDi Bluemotion Oil Pressure Light flashing
Results 11 to 20 of 22
  1. Re: Golf Mk6 CAYD 1.6 TDi Bluemotion Oil Pressure Light flashing
    #11
    Aug 2009
    london england
    Quote Originally Posted by mickeybo View Post
    Ask yourself the 64 dollar question whats the first fall off point in the oil pressure system
    I did, many times.
    Well, at least the EGR valve was cleaned.
    The coolant system was flushed.
    The oil pressure sensor and harness replaced.
    Whilst waiting for the sumps silicon gasket to go off, took the time to re-seat the parking sensors...took the bumper off to remove a dead and bleached bumblebee inside one of the headlights and noticed two parking sensor fittings were broken.
    The oil cooler replaced (I think this was the cause all along and maybe damaged the oil pump).
    New oil pump fitted.
    Still waiting to put it all back together but will delay a bit to watch Six Nations.
  2. Re: Golf Mk6 CAYD 1.6 TDi Bluemotion Oil Pressure Light flashing
    #12
    Aug 2009
    london england
    We would use a Febi cooler
    Thanks.
  3. Re: Golf Mk6 CAYD 1.6 TDi Bluemotion Oil Pressure Light flashing
    #13
    Mar 2010
    Derry ireland
    67 Post(s)
    This problem should have been checked out at the first oil pressure fall off position
  4. Re: Golf Mk6 CAYD 1.6 TDi Bluemotion Oil Pressure Light flashing
    #14
    Aug 2009
    london england
    I took it to a local garage to sort the oil leak and give it a service.
    When I went to pick it up, the mechanic said there's good news and bad news...good news was the oil leak had been found and fixed, bad news being the had to fix the wiring harness for the oil sensor and when they did, the red warning light started "flickering".
    I hate getting good and bad news!
    The garage couldn't fit me in to find the problem for a couple of weeks but kindly took the car home for me...
    Decided to do it myself even though I didn't have a clue as to what I was doing.
    Got to give it a go though
  5. Re: Golf Mk6 CAYD 1.6 TDi Bluemotion Oil Pressure Light flashing
    #15
    135 Post(s)
    2028 Post(s)
    Warning light flickering? They flash at a predetermined frequency but they don’t flicker like in the distant past.
  6. Re: Golf Mk6 CAYD 1.6 TDi Bluemotion Oil Pressure Light flashing
    #16
    Aug 2009
    london england
    Well, it comes on for a few seconds, maybe 5, then goes out for about 20 seconds, then repeats. No sounds.
    Put it all back together with new "everything"...same.
    However, when the car is warmed up, at about 70 degrees coolant, 60 degrees oil, the oil light stops repeating...until I press the accelerator and it comes back on again. Goes out if I let it idle.
    Going to take the oil pressure switch out after rugby and check again the actual oil pressure.
    Tried doing it with ross tech but car is using UDS protocol so will head over to the Ross Tech forum to find out how to do it.
    I wonder?...I wonder?...maybe the software on the car is out of date?
    Maybe the injector o-rings on the rocker cover need replacing? I do get the occassional whiff of diesel...
    Straw is being grasped at the moments.
  7. Re: Golf Mk6 CAYD 1.6 TDi Bluemotion Oil Pressure Light flashing
    #17
    Aug 2009
    london england
    Well, great win by Ireland. After a poor performance by England yesterday, I might change to being Irish as all my grandparents were Irish....on second thoughts, nah, I'm still hopelessly English.
    Anyway, car now giving 7286 Turbocharger Boost control P2563 Implauible signal.
    Will check vacuum and N75 tomorrow...bugger
    Readiness: 0 0 0 0 0
    Sunday,12,March,2023,18:02:23:05470
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
    VCDS Version: 23.3.0.0 HEX-V2 CB: 0.4631.4
    Data version: 20230228 DS346.1
    www.Ross-Tech.com
    VIN: WVWZZZ1KZBW328017 License Plate:
    Address 01: Engine Labels: 03L-906-023-CAY.clb
    Control Module Part Number: 03L 997 557 T HW: 03L 907 425 C
    Component and/or Version: R4 1.6l TDI H43 9982
    Software Coding: 08114014032501080000
    Work Shop Code: WSC 01357 011 00200
    ASAM Dataset: EV_ECM16TDI02103L997557T 003003 (VW36)
    ROD: EV_ECM16TDI02103L997557T.rod
    VCID: I think I should not show this ID
    1 Fault Found:
    7286 - Turbocharger Boost Control Position Sensor Circuit
    P2563 00 [101] - Implausible Signal
    Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 141225 km
    Date: 2040.14.24
    Time: 16:53:16
    Engine RPM: 780.50 /min
    Normed load value: 27.8 %
    Vehicle speed: 0 km/h
    Coolant temperature: 31 °C
    Intake air temperature: 13 °C
    Ambient air pressure: 980 mbar
    Voltage terminal 30: 14.569 V
    Unlearning counter according OBD: 40
    Charge air pressure actuator: acknowledgment-ANG_BPA[0]: 40.021 %
    Charge Pressure Actuator: activation-ANG_SP_BPA[0]: 85.001 %
    High press turbocharger actuator: activation-CTL_LIM_BPA[0]: 84.998 %
    High press turbocharger actuator: actual uncond volt value-V_BPA[0]: 1.870 V
    Turbocharger boost control: offset open-V_BPA_BOL[0]: 0.498 V
    Turbocharger boost control: offset closed-V_BPA_TOL[0]: 3.477 V
    High press turbocharger actuator: status-LF_STATE_BPA_DISP[0]: 76
  8. Re: Golf Mk6 CAYD 1.6 TDi Bluemotion Oil Pressure Light flashing
    #18
    135 Post(s)
    2028 Post(s)
    I would suspect the turbo actuator diaphragm is split.
  9. Re: Golf Mk6 CAYD 1.6 TDi Bluemotion Oil Pressure Light flashing
    #19
    Aug 2009
    london england
    Ok, just done the mechanical oil pressure test.
    Results are for a cold engine.
    Idle 1.5 bar
    2000rpm 1.75 bar
    Took vacuum tube off actuator and drew the air out. It kept the pressure on my tongue for a while and when i let it go could hear something moving.
    Going to warm up the car now to get more oil pressure tests.
    Thanks for replying C
    So, 15 minutes later...
    Idle 0.6 bar
    2000rpm 1.5 bar
    Noticed also the pressure sensor is not OEM.
    Will order one and stop this faffing about.
  10. Re: Golf Mk6 CAYD 1.6 TDi Bluemotion Oil Pressure Light flashing
    #20
    135 Post(s)
    2028 Post(s)
    That is only just good enough, the switch you need is 036 919 081 D which closes at 0.3>0.6Bar
  1. Replies: 1
    Last Post: 05-02-2019, 06:51 PM
  2. Please Help Fuel Pressure Problem - Flashing coil light
    By Beut834 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 20-02-2017, 07:08 PM
  3. Replies: 2
    Last Post: 09-10-2016, 09:04 AM
  4. Question Randomly Flashing Tyre Pressure Monitor System light on dash
    By scam3r in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 29-08-2016, 12:59 PM
  5. help...2010 passat bluemotion glow plug light flashing amber...
    By st dave in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 07-03-2014, 11:57 AM
