Thread: Allroad TDI Engine Fault light and Limp-home mode
  1. Allroad TDI Engine Fault light and Limp-home mode
    Ardfern
    8 Post(s)
    My A4 Allroad 2.0tdi 2015 was running well with only obvious fault being the parking sensors not working, about which fault I am not immediately concerned. I changed my oil and filter filling up with what I reckoned to be the right quantity of new longlife oil. I also changed the air filter.
    The car ran well for about 60 mls then the oil warning lamp illuminated. I stopped and topped up.
    That all may be co-incidental. The car ran well for another 200 mls over a couple of days then, yesterday after a gentle 25ml journey and a stop, when I restarted after an hour, the amber 'coil' warning light appeared and also the engine management light and the car displayed reduced power which I guessed to be 'limp home mode'.
    I drove gently home and today have scanned with vcds. I show the scan below.
    Are these error codes suggestive of sooted up particulate filter or failed sensor or what?
    I have not yet tried clearing the faults.
    Code:
    Friday,17,February,2023,11:09:43:60719
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
    VCDS Version: 22.10.0.1 (x64)
    Data version: 20221026 DS344.0
    Ross-Tech: Home
    VIN: WAUZZZ8K8GA001180   License Plate: SB15PDK
    Mileage: 162990km-101277mi   Repair Order: 17022023
    Chassis Type: 8K-AU48 (8R0)
    Scan: 01 03 05 08 09 15 16 17 19 42 44 46 52 53 56 5F 62 69 6D 72
              AC
    VIN: WAUZZZ8K8GA001180   Mileage: 162990km-101277miles
    05-Acc/Start Auth. -- Status: OK 0000
    08-Auto HVAC -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    53-Parking Brake -- Status: Malfunction 0010
    56-Radio -- Status: OK 0000
    5F-Information Electr. -- Status: Malfunction 0010
    69-Trailer -- Status: Not registered 0001
    6D-Trunk Elect. -- Status: OK 0000
    AC-Reductant Control -- Status: OK 0000
    Address 01: Engine (J623-CNHA)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 021 BK    HW: 04L 907 309
       Component: R4 2,0L EDC   H23 8251
       Revision: 85H23---    CVN: E32E1D8F60B4FDC638D3FF82
       Coding: 32194012242601080000
       Shop #: WSC 06208 000 00000
       ASAM Dataset: EV_ECM20TDI01104L906021BK 002009
       ROD: EV_ECM20TDI01104L906021BK_002.rod
       VCID: 6FE6DF7DB67023F56B-803A
       VINID: 9D196AAAA21B2174400010480060E0DD8A
    3 Faults Found:
    4698 - Function Restriction due to Faults in Other Modules
              U1113 00 [039] - -
              Not Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Status: 00000001
                        Fault Priority: 6
                        Fault Frequency: 1
                        Mileage: 162991 km
                        Date: 2023.02.17
                        Time: 11:05:45
                        Engine RPM: 0.00 /min
                        Normed load value: 0.0 %
                        Vehicle speed: 0 km/h
                        Coolant temperature: 7 °C
                        Intake air temperature: 8 °C
                        Ambient air pressure: 1000 mbar
                        Voltage terminal 30: 12.000 V
                        Unlearning counter according OBD: 40
                        Cruise Control System (CCS): switch position-Bits 0-7: 129
                        Cruise Control System (CCS): status-Bits 0-7: 40
                        Cruise control switch-off: irreversible-Bits 0-7: 255
                        Cruise control switch-off: reversible-Bits 0-7: 255
                        Cruise Control System: specified speed: 0.00 km/h
                        Engine control module reset status-Bits 0-7: 0
                        Cruise control switch-off: irreversible w. brake intervention-Bits 0-7: 0
    19226 - Particulate Trap Bank 1
              P2002 00 [096] - Efficiency Below Threshold
              Intermittent - Not Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Mileage: 162348 km
                        Date: 2023.02.11
                        Time: 12:42:20
                        Engine RPM: 1983.50 /min
                        Normed load value: 28.2 %
                        Vehicle speed: 97 km/h
                        Coolant temperature: 87 °C
                        Intake air temperature: 57 °C
                        Ambient air pressure: 1010 mbar
                        Voltage terminal 30: 12.960 V
                        Unlearning counter according OBD: 35
                        Exhaust mass flow of low-pressure EGR: calculated: 3.025
                        Differential pressure ratio: low-pressure EGR: 23.4 kg/h
                        Exh.recircul. 2: differential pres.sensor 1 bank 1: adap. value: 32.4 hPa
                        Exhaust recirculat.2: different.press.sens.1 bank 1: raw value: 32.4 hPa
                        Exh.recircul.valve 1 bank 1: pos.feedback - Actual value: 76.53 %
                        Exhaust recirc.valve 2 bank 1: posit.feedback - Actual value: 38.84 %
                        Exh. gas recirc. 2: diff. press. sensor 1 bank 1: dyn. value: 33.8 hPa
    5170 - Manifold Pressure / Boost Sensor (G31)
              P0237 00 [175] - Signal too Low
              MIL ON - Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Mileage: 162946 km
                        Date: 2023.02.16
                        Time: 11:39:33
                        Coolant temperature: 71 °C
                        Intake air temperature: 65 °C
                        Voltage terminal 30: 12.460 V
                        Charge air cooler inlet: pressure sensor 1 bank 1: raw value: 368.8 hPa
                        Engine status: COENG_STANDBY
                        Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 0
    Readiness: 1 1 0 0 0
    Address 03: ABS Brakes (J104)       Labels:. 8K0-907-379-V2.clb
       Part No SW: 8K9 907 379 P    HW: 8K9 907 379 P
       Component: ESP8 quattro  H09 0020
       Revision: --------    Serial number: --------------
       Coding: 12DDCC01
       Shop #: WSC 06335 000 00000
       VCID: 4FA67FFD1E3003F54B-801A
    2 Faults Found:
    02214 - Tire Pressure Warning
                000 - - - Intermittent
                 Freeze Frame:
                        Fault Status: 00100000
                        Fault Priority: 1
                        Fault Frequency: 1
                        Reset counter: 101
                        Mileage: 160855 km
                        Time Indication: 0
                        Date: 2023.01.21
                        Time: 13:10:07
                 Freeze Frame:
                        Hex Value: 0x4000
                        Hex Value: 0x4006
                        Hex Value: 0x1221
                        Hex Value: 0x1FB8
                        Hex Value: 0x0000
    01314 - Engine Control Module
                013 - Check DTC Memory
                 Freeze Frame:
                        Fault Status: 01101101
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 75
                        Mileage: 162991 km
                        Time Indication: 0
                        Date: 2023.02.17
                        Time: 11:05:45
                 Freeze Frame:
                        Hex Value: 0x0000
                        Hex Value: 0x07A2
                        Hex Value: 0x000B
                        Hex Value: 0x4695
                        Hex Value: 0x0000
    Address 05: Acc/Start Auth. (J393)       Labels:. 8K0-907-064-05.clb
       Part No SW: 8K0 907 064 KG    HW: 8K0 907 064 KG
       Component: BCM2 2.0      H15 0711
       Revision: 00002001
       Coding: 03B24040000000000000
       VCID: 7F060F3DEE105375FB-802A
       Subsystem 1 - Part No SW: 8K0 959 754 H    HW: 8K0 959 754 H
       Component: FBSAUDIB8 IDG  H71 0083
       Serial number: 3715000028702009
       Subsystem 2 - Part No SW: 8K0 905 852 E    HW: 8K0 905 852 E
       Component: J764 ELV MLB  H40 0046
       Serial number: 3215000094400004
    No fault code found.
    Address 08: Auto HVAC (J255)       Labels:. 8Kx-820-043-3Z.clb
       Part No SW: 8K2 820 043 BB    HW: 8K2 820 043 BB
       Component: KLIMA 3 ZONEN H04 0123
       Revision: D1000000    Serial number: 01270520151960
       Coding: 342400A080
       VCID: 6AD0CE698592C6DD3C-803E
    1 Fault Found:
    00457 - Central Electronics Control Module / BCM (J519)
                013 - Check DTC Memory - Intermittent
                 Freeze Frame:
                        Fault Status: 00101101
                        Fault Priority: 6
                        Fault Frequency: 24
                        Reset counter: 115
                        Mileage: 159200 km
                        Time Indication: 0
                        Date: 2023.01.09
                        Time: 11:21:47
    Address 09: Cent. Elect. (J519)       Labels:. 8K0-907-063.clb
       Part No SW: 8K0 907 063 DH    HW: 8K0 907 063 DH
       Component: BCM1 1.0      H16 0103
       Revision: 08016001    Serial number: 00001081814601
       Coding: 260080108034AFE00481408300001D0D009D870827090201000008004400030100000024000000
       Shop #: WSC 06335 123 12345
       VCID: 78F4E421CB3E644DBA-802C
       Subsystem 1 - Part No SW: 8K2 955 119 A    HW: 8T2 955 119   Labels: 1KX-955-119.CLB
       Component: WWS 130515  H06 0080
       Serial number: SWF15055135619
       Coding: 00FD11
       Subsystem 2 - Part No SW: 8U0 955 559 C    HW: 8U0 955 559 B  Labels: 8U0-955-559.CLB
       Component: G397_RLFS  H06 0004
       Serial number: 20318678
       Coding: 02005D
       Subsystem 3 - Part No SW: 8K0 941 531 AS    HW: 8K0 941 531 AS
       Component: E1 - LDS  H03 0031
       Serial number: 00000000000805150479
       Subsystem 4 - Part No SW: 4H0 907 658     HW: 4H0 907 658
       Component: AQ_Hum_Sensor  H03 0003
       Serial number: 67B8CBA7000000000001
    2 Faults Found:
    01629 - Sensor for Parking-Aid; Front Left (G255)
                009 - Open or Short to Ground
                 Freeze Frame:
                        Fault Status: 01101001
                        Fault Priority: 3
                        Fault Frequency: 1
                        Reset counter: 49
                        Mileage: 159100 km
                        Time Indication: 0
                        Date: 2023.01.09
                        Time: 09:41:25
    03608 - Humidity Sensor in Fresh Air Intake Duct
                014 - Defective - Intermittent
                 Freeze Frame:
                        Fault Status: 00101110
                        Fault Priority: 3
                        Fault Frequency: 24
                        Reset counter: 115
                        Mileage: 159200 km
                        Time Indication: 0
                        Date: 2023.01.09
                        Time: 11:21:51
    Address 15: Airbags (J234)       Labels:| 8K0-959-655.clb
       Part No SW: 8K0 959 655 N    HW: 8K0 959 655 N
       Component: AirbagVW-AU10 H48 0610
       Serial number: 003KFDC7NBBT
       Coding: 30534435363030303030554A3052384B3053
       ASAM Dataset: EV_AirbaECUVWAUDI010 003010
       ROD: EV_AirbaECUVWAUDI010_003_AU48.rod
       VCID: 489454E1F35ED4CD0A-801C
       Crash sensor for side airbag: driver side:
       Serial number: 6334MSME51590F0BJ
       Front Passenger's Side Airbag Crash Sensor:
       Serial number: 6344MSME514D633CL
       Rear Side Airbag Crash Sensor (on driver's side):
       Serial number: 6352QSME234D3F7E
       Passenger side rear thorax airbag crash sensor:
       Serial number: 6362QSME13540F5AL
       Crash sensor for front airbag: driver side:
       Serial number: 63732SME6F4C5744D
       Crash sensor for front airbag: front passenger side:
       Serial number: 63832SME6F4C5742C
    Address 16: Steering wheel (J527)       Labels:. 8K0-953-568.clb
       Part No SW: 8K0 953 568 Q    HW: 8K0 953 568 Q
       Component: Lenks.Modul   H03 0003
       Revision: C0062331    Serial number: 90862ODN0002S
       Coding: 000017
       VCID: 489454E1FB5ED4CD0A-801C
       Component: E221 - MFL  H03 0004
    Address 17: Instruments (J285)       Labels:. 8T0-920-xxx-17.clb
       Part No SW: 8K0 920 983 G    HW: 8K0 920 983 G
       Component: KOMBIINSTR.   H35 0567
       Revision: 00100000    Serial number: 61+71ZN5G
       Coding: 33A5290203012600010000
       VCID: 39722125B0B4BD4585-806C
    Address 19: CAN Gateway (J533)       Labels:. 8T0-907-468.clb
       Part No SW: 8R0 907 468 N    HW: 8R0 907 468 C
       Component: GW-BEM 4CAN-M H11 0060
       Revision: 1Y080030    Serial number: 3041Y155190A63
       Coding: 80CF07FF00
       VCID: 4A906EE9E55226DD1C-801E
       Subsystem 1 - Part No SW: 8T0 915 181     HW: 8T0 915 181
       Component: J367-BDMHella  H03 8041
       Serial number: 6023256603
       Subsystem 2 - Part No SW: 8K0 959 663     HW: 8K0 959 663
       Component: J532_DCDCStab  H17 0042
       Serial number: 15146003133011200181
    1 Fault Found:
                000 - -
                 Freeze Frame:
                        Fault Status: 01100000
                        Fault Priority: 1
                        Fault Frequency: 1
                        Reset counter: 48
                        Mileage: 159090 km
                        Time Indication: 0
                        Date: 2023.01.06
                        Time: 12:09:11
                 Freeze Frame:
                        Bin. Bits:    10111
                        Voltage: 12.40 V
                        Count: 6
    Address 42: Door Elect, Driver (J386)       Labels:. 8K0-959-793.clb
       Part No SW: 8K0 959 793 S    HW: 8K0 959 793 Q
       Component: TSG FA        H02 0510
       Revision:             Serial number: 0000150483826
       Coding: 011002204001410001
       VCID: 50A47C81030E1C0D52-8004
    Address 44: Steering Assist (J500)       Labels:| 8K0-909-144.clb
       Part No SW: 8K0 909 144 P    HW: 8K0 909 144 B
       Component: RCEPS         H43 0510
       Revision: 00001000    Serial number: 0026757791
       Coding: 100000010001
       Shop #: WSC 06334 000 00000
       ASAM Dataset: EV_RCEPSAU48X 008018
       ROD: EV_RCEPSAU48X_008.rod
       VCID: 3E783239A19A9A7DB0-806A
    Address 46: Central Conv. (J393)       Labels:. 8K0-907-064-46.clb
       Revision: 00002001    Serial number: 0369490309
       Coding: 013B0622A0B930408320023680000047
       Subsystem 1 - Part No: 8K0 951 177
       Component: DWA-Sensor  H02 0040
       Subsystem 2 - Part No: 1K0 951 605 C
       Component: LIN BACKUP HO  H05 1501
    Address 52: Door Elect, Pass. (J387)       Labels:. 8K0-959-792.clb
       Part No SW: 8K0 959 792 S    HW: 8K0 959 792 Q
       Component: TSG BF        H02 0510
       Revision:             Serial number: 0000150502363
    Address 53: Parking Brake (----)       Labels: 8K0-907-801-V2.clb
       Part No SW: 8K0 907 801 N    HW: 8K0 907 801 J
       Component: EPB-4         H02 0005
       Revision: --------    Serial number: 20000000630775
       ASAM Dataset: EV_ParkiBrake 001028
       ROD: EV_ParkiBrake_AU48.rod
       VCID: 3A703E29BDB2B65D8C-806E
    1 Fault Found:
    464384 - Function Restriction due to Faults in Other Modules
              U1113 00 [009] - -
              [New feature! Extended UDS fault detail is only supported by current gen. interfaces]
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 75
                        Mileage: 162991 km
                        Date: 2023.02.17
                        Time: 11:05:45
                        Voltage terminal 30: 12.0 V
                        Internal Fault ID: 188
                        Network management state: normal
                        Function light in parking brake button: On
                        Red operating lamp: On
                        Red warning lamp: OFF
                        Green operating lamp: OFF
                        Yellow warning lamp: OFF
                        Terminal 15 status: On
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
                        ACC requested apply: not active
                        Auto Adjust: not active
                        General Inspection Function: not active
                        Internal Parking Brake state: static
                        Status of parking brake button: Not operated
                        Status ParkingBrake left: applied
                        Status ParkingBrake right: applied
    Address 56: Radio (R)       Labels:. 4F0-035-0xx-56.clb
       Part No SW: 4G0 035 061 S    HW: 4G0 035 061
       Component: Radio U DAB   H60 0154
       Revision: AB001007    Serial number: 109E00F8038828
       Coding: 010103020100000001
       VCID: 2D5A057574FC11E519-8078
    Address 5F: Information Electr. (J794)       Labels:. 4E0-035-6xx-5F.clb
       Part No SW: 8R2 035 666 L    HW: 8R2 035 666 H
       Component: H-BN-EU       H49 1036
       Revision: --------    Serial number: 515FZ0FB013435
       Coding: 100101050006A1ED0780AB5E00000403E40000020000000000
       VCID: 428046C9DD62FE9DD4-8016
       Subsystem 1 - Part No: 8R0 060 884 KB
       Component: EUR 2022/2023  3501
       Subsystem 2 - Part No SW: 8R0 919 604 A    HW: 8R0 919 604 A
       Component: DU7 High  H42 0104
       Serial number: A130E$0F3364698
       Subsystem 3 - Part No SW: 8T0 919 611 K    HW: 8T0 919 611 B
       Component: E0380 Bedient  H02 0030
       Serial number: 00000002250432
       Subsystem 4 - Part No: 8R0 060 961 G
       Component: CD-Database  6208
    2 Faults Found:
    03276 - Please Check Software Version Management
                000 - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 49
                        Mileage: 159442 km
                        Time Indication: 0
                        Date: 2023.01.11
                        Time: 15:07:25
                 Freeze Frame:
                        Text: DUA130,Front,M,0,0,6
    03677 - Missing Security/Release Code
                000 - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 49
                        Mileage: 159442 km
                        Time Indication: 0
                        Date: 2023.01.11
                        Time: 16:34:50
                 Freeze Frame:
                        Voltage: 12.60 V
    Address 62: Door, Rear Left (J388)       Labels:. 8K0-959-795.clb
       Part No SW: 8K0 959 795 G    HW: 8K0 959 795 D
       Component: TSG HL        H01 0510
       Revision:             Serial number: 0000151492826
       Coding: 010002204001210001
       VCID: 46885AD9F14AC2BDF8-8012
    Address 69: Trailer (J345)       Labels:. 8K0-907-383.clb
       Part No SW: 8K0 907 383 E    HW: 8K0 907 383 E
       Component: ConWys Trailer H09 0100
       Revision: 1A001001    Serial number: 00000161077413
       Coding: 0100000000000000
       Shop #: WSC 00007 223 57222
       VCID: 36682A1981AA523D68-8062
    Address 6D: Trunk Elect. (J605)       Labels: 8K9-827-851.clb
       Part No SW: 8K9 827 851 C    HW: 8K9 827 851 C
       Component: J605  Master  H53 0330
       Revision: --------    Serial number: 8K9827851C
       VCID: 3E783239A99A9A7DB0-806A
       Subsystem 1 - Part No SW: 8K9 827 852 C    HW: 8K9 827 852 C
       Component: J756  Slave  H53 0330
       Serial number: 8K9827852C
    Address 72: Door, Rear Right (J389)       Labels:. 8K0-959-795.clb
       Component: TSG HR        H01 0510
       Revision:             Serial number: 0000151492876
    Address AC: Reductant Control (J880)       Labels: 4G0-907-355.clb
       Part No SW: 4H0 907 355 D    HW: 4G0 907 355 B
       Component: SCR-Stg-G2    H10 0012
       Revision: 00000000    Serial number: 151300765
       ASAM Dataset: EV_RDCMA00100 008040
       ROD: EV_RDCMA00100.rod
       VCID: 2D5A05757CFC11E519-8078
    End-------------------------(Elapsed Time: 03:56)--------------------------
    A4 B8 143 Tdi S Line Saloon 2008 (Gone)
    Lotus Elan SE 1991
    A4 B8 170 Tdi Quattro Technik Avant 2011
    A4 B8.5 143 Tdi S Line Black Edition Saloon 2013(gone)
    A4 B8.5 Allroad Sport Nav 2.0 tdi quattro 2015
  2. Re: Allroad TDI Engine Fault light and Limp-home mode
    132 Post(s)
    1979 Post(s)
    A common fault with these engines is the reductant injector dribbling and this causes a buildup of urea crystals in the SCR unit which becomes blocked. We take the injector off and use an endoscope to check for white crystal buildup.
  3. Re: Allroad TDI Engine Fault light and Limp-home mode
    Ardfern
    8 Post(s)
    Thanks Crasher. Sadly, my investigation will be delayed till I return from a long road trip to Austria and back for which I shall have to use my partner's 2010 A4 tdi which has about 220k miles on the clock now. It is pre adblue so this is a problem which will not hold us up in that car.
    Lotus Elan SE 1991
  4. Re: Allroad TDI Engine Fault light and Limp-home mode
    Ardfern
    8 Post(s)
    In case anyone was interested, this was resolved with a replacement turbo boost sensor.
    Lotus Elan SE 1991
  5. Re: Allroad TDI Engine Fault light and Limp-home mode
    132 Post(s)
    1979 Post(s)
    A new MAP sensor would give the ECU different DPF statistics
  1. ESP/ABS/TPMS/AC/EPB fault limp mode engine hick-ups
    By johnro79 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 16-05-2022, 04:11 PM
  2. Emission control system light on and car in limp home mode
    By jkl123 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 31-07-2012, 12:04 AM
  3. fault code and limp home mode
    By kstead in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 06-09-2010, 07:54 PM
  4. 2.0 FSI ESP Light on AND Limp Home mode.....
    By Super76 in forum Golf MK5 - 2004 - 2009
    Last Post: 20-07-2010, 09:40 PM
  5. Engine Management Light and Limp Home Mode
    By gianni67 in forum Beetle 2000-
    Last Post: 30-04-2009, 08:51 AM
