Thread: Coolant leak
  1. Coolant leak
    Oct 2020
    Spilsby, UK
    Definite slow coolant loss 2019 40TDI 48k miles. No visible signs of an actual leak. Checked oil filler cap, normal. Is this a common issue? Been advised not to put any of the propietory radiator sealant liquids in. Car still under extended warranty, would this be covered please. Any help appreciated
  2. Re: Coolant leak
    131 Post(s)
    1974 Post(s)
    NO sealant, disastrous. I have just rebuilt my friends Octavia engine as he put Steel Seal in there to fight a failed head gasket, I had to fit a new head due to it being blocked and acid dip the block to get the **** out. Thankfully the rad and matrix seem to have flushed clear; all the hoses and housings were encrusted by it. I don’t know of a common failure that late.
  3. Re: Coolant leak
    Oct 2020
    Spilsby, UK
    Confirmed water pump, being replaced under warranty
  4. Re: Coolant leak
    Aug 2007
    Hook Hampshire
    21 Post(s)
    My water pump went at 158k miles
    Audi A7 3.0TDi 2011 160k miles, engine code CLAB 204bhp 2WD
  5. Re: Coolant leak
    Feb 2023
    Florida
    Bump
  1. Coolant leak - Culprit is the Coolant inlet valve seal
    By inchshort in forum Q7 - 4M Forum - 2016 -
    Last Post: 06-01-2024, 08:48 PM
  2. 1.9TDI (BKC) Fuel Pump Leak & Coolant Leak.
    By DannyBoyGolf in forum Golf MK5 - 2004 - 2009
    Last Post: 16-07-2018, 10:51 PM
  3. Question Fuel leak? coolant leak?
    By J4G3D in forum Golf MK5 - 2004 - 2009
    Last Post: 30-11-2016, 08:34 PM
  4. Question Coolant leak from rear flange: Sourcing the coolant pipe?
    By defever in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-09-2015, 11:36 AM
  5. Please Help Coolant Leak From Coolant\Water pump Housing
    By Chappio in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-04-2009, 03:30 PM
