Thread: 2010 fabia electric window problem
  1. 2010 fabia electric window problem
    Aug 2020
    Anglesey
    Got a 2010 Skoda fabia 1.4 tdi.
    Electric front window, manual rear)
    Today while driving home after having my mot, I just pulled into a shop carpark & the passenger side electric window wound down & dropped* all the way down without my pressing the button. I parked up & the button on the drivers side door card wouldn't work the passenger window at all. Reached over & used the passenger side button & that just worked as bit intermittent
    Switched ignition off then on & the passenger door card button worked for me to get the glass up.
    Driving on the way home it seemed intermittent & a press of the button on the drivers side door card sometimes operated the glass & other times seems to have a delayed action (could hear the motor randomly acting a few seconds later)
    Any pointers to look at? Was thinking it could be the drivers side window switch (cheapest option to change) or perhaps a broken or intermittent wire break in the bellows between a pillar & door? (Does this affect skodas like it does the mk5 golf?)
    I haven't scanned it yet. Not sure if vcds would show the problem?
    Thanks!
    Mike
  2. Re: 2010 fabia electric window problem
    135 Post(s)
    2038 Post(s)
    The wiring from the A pillar to door is just power, earth, speakers, two digital CAN BUS lines, a digital LIN BUS wire to the rear door controller and illumination feed if fitted. The (in)convenience unit behind the glovebox receives a CAN BUS signal from the drivers door controller (i.e. the motor) and sends this to the passengers door controller.. I would start with a code read.
  1. Electric window issues on 2010 Polo (6R) - broken regulator?
    By 10POLO in forum Polo - Derby - Lupo - Fox
    Last Post: 21-09-2017, 05:58 PM
  2. Please Help Electric window problem
    By moodyman in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 24-10-2013, 05:51 PM
  3. Electric window problem
    By TFSIer in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 30-10-2010, 09:11 PM
  4. Electric window problem
    By shuntered in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 03-10-2010, 11:25 PM
  5. mk3 electric window problem
    By Albear1 in forum Golf MK3 - 1993 - 1999
    Last Post: 04-01-2008, 09:18 PM
