Thread: Issue with gearstick going straight into reverse rather than 1st
Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
  1. Re: Issue with gearstick going straight into reverse rather than 1st
    #11
    114 Post(s)
    1872 Post(s)
    Front discs 347X30MM 5/112 M14, 4F0 615 301 G
    Front pads, new number 8E0 698 151 AA, old number 8E0 698 151 G
    Fuel gauge sender, right 4F0 919 673 C
    https://youtu.be/w8r2xnITnqA?si=Hy9T6jEbWD5ih-Oy
  2. Re: Issue with gearstick going straight into reverse rather than 1st
    #12
    Jul 2008
    Lisburn
    15 Post(s)
    oh fuel gauge sender - have you updated the wiring in the tank?
    there a TSB for it.
    Stewart
    1986 coupe quattro (kv)
  3. Re: Issue with gearstick going straight into reverse rather than 1st
    #13
    Jun 2024
    Stockton-on-Tees
    Quote Originally Posted by producedapples View Post
    Hey all, i have just bought a manual 3.0 v6 tdi, and upon selecting first, it goes into reverse. There is no need to press gear stick down to select reverse, so coming up to junctions and stopping at lights is a bit hairy with cars behind. 1st is there, it just isnt "separated" from reverse. Any pointers at all please?
    Hi, did you sort this issue as I have the same. Which parts did you need to change?
  4. Re: Issue with gearstick going straight into reverse rather than 1st
    #14
    Mar 2014
    Nottingham. UK
    You need the updated selector mechanism 4F0 711 055 J which is £339 from Audi.
    Would this be the same part number for the 2.0 TDI Manual? WAUZZZ4F3BN026160.
    Mine is randomly not going into 1st, it won't push up. The only remedy I've found is to wiggle the gear stick and push up until it engages.
    (2011 A6 2.0 TDI S-LINE 170Ps CAHA)
  5. Re: Issue with gearstick going straight into reverse rather than 1st
    #15
    114 Post(s)
    1872 Post(s)
    4F0 711 055 H, still £339
  1. How to: Battery Replacement (Strange issue straight after though!)
    By Akash in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 06-01-2014, 11:19 PM
  2. Mirror dip on reverse issue?
    By Wuffles in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 11-02-2013, 10:37 PM
  3. Reverse light 'issue'....
    By neilswheels in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 08-10-2010, 05:44 PM
  4. Gearstick issue
    By bryand in forum Golf MK4 - 1999 - 2004
    Last Post: 11-12-2007, 06:10 PM
  5. Gearstick issue on Golf
    By bryand in forum Archive posts
    Last Post: 05-12-2007, 09:20 PM
