Thread: Fabia II 1.6 TDi EGT Sensor faults
Results 1 to 10 of 13
  1. Fabia II 1.6 TDi EGT Sensor faults
    Jan 2008
    Cornwall
    ***SOLVED - See page 2***
    Hi all,
    I have a 2011 Fabia Monte Carlo with the CAYC engine and have just had a used DPF installed. The mpg is pretty bad and I'm not sure if it is regenerating or not. The engine management light came on yesterday, but has remained off so far since a reset, the scan is below.
    Does anyone have the resistance and output figures for the sensors that they wouldn't mind sharing please? I'll try to get this tested today.
    Code:
    Friday,03,February,2023,12:06:57:38737VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
    VCDS Version: http://22.10.0.1 (x64)
    Data version: 20221026 DS344.0
    http://www.Ross-Tech.com
    Mileage: 207510km-128940mi   Repair Order: Post DPF change
    Chassis Type: 5J-SK25 (6N0)
    Scan: 01 03 08 09 15 17 19 25 2E 44 56
    VIN: TMBFL25J2B3193204   Mileage: 207510km-128940miles
    15-Airbags -- Status: OK 0000
    2E-Media Player 3 -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010
    Address 01: Engine (J623-CAYC)       Labels:. 03L-906-023-CAY.clb
       Part No SW: 03L 906 023 LN    HW: 03L 906 023 LK
       Component: 1,6l R4 CR td H33 8829
       Revision: --H33---    Serial number:                CVN: 77D97D74
       Coding: 00114016000500080000
       Shop #: WSC 13765 031 00017
       ASAM Dataset: EV_ECM16TDI02103L906023LN 003004
       ROD: EV_ECM16TDI02103L906023LL.rod
       VCID: 7DFBC554EC663F65E9-8028
       VINID: 91D49670215A0920C124308010C38F91B8
    3 Faults Found:
    7397 - Particulate Filter; Differential Pressure Sensor
              P2454 00 [032] - Short to GND
              Intermittent - Not Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Status: 00000001
                        Fault Priority: 2
                        Fault Frequency: 2
                        Mileage: 207204 km
                        Date: 2023.02.03
                        Time: 10:17:47
                        Engine RPM: 0.00 /min
                        Normed load value: 0.0 %
                        Vehicle speed: 0 km/h
                        Coolant temperature: 54 ∞C
                        Intake air temperature: 17 ∞C
                        Ambient air pressure: 1020 mbar
                        Voltage terminal 30: 12.536 V
                        Unlearning counter according OBD: 38
                        Particle filter: soot mass measured-MASS_SOOT_PHY_PF: 9.02 g
                        Particle filter: soot mass calculated-MASS_SOOT_SIM_PF: 18.10 g
                        Particle filter kilometers since last regeneration_1-DIST_RGN_ENVD_H: 268 km
                        Counter for regeneration time of particulate filter-T_INT_RGN_ACT_INI_PF_ENVD_H: 0.0000 s
                        Particle filter: difference pressure-DIP_PF: 0.00 hPa
                        Service regeneration: Release conditions 3-FRF_STATE_RGN: 1
                        Sensor for temp after charge air cooler: raw value-TBA_MES: 13 ∞C
    9852 - Exhaust Gas Temperature Sensor; B1 S3
              P242B 00 [237] - Range/Performance
              MIL ON - Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Mileage: 207206 km
                        Date: 2023.02.03
                        Time: 09:04:13
                        Vehicle speed: 255 km/h
                        Coolant temperature: 6 ∞C
                        Intake air temperature: 6 ∞C
                        Voltage terminal 30: 11.633 V
                        Unlearning counter according OBD: 40
                        Exhaust gas temperature sensor 1-TEG_MES[0]: 19.98 ∞C
                        Exhaust gas temperature sensor 3-TEG_MES[1]: 999.98 ∞C
                        Exhaust gas temperature sensor 4-TEG_MES[2]: 999.98 ∞C
                        Sensor for temp after charge air cooler: raw value-TBA_MES: 9 ∞C
                        Outside temperature-Ambient temperature: 8.25 ∞C
                        Shut-off timer: last ECM after-run time-T_ES_FCT_DIAG: 0.00 s
                        Time since engine start: 0 s
    9854 - Exhaust Gas Temperature Sensor 4 Bank 1
              P246F 00 [237] - Implausible Signal
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Mileage: 207206 km
                        Date: 2023.02.03
                        Time: 09:04:13
    Readiness: 0100 0000
    Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ABS82.clb
       Part No SW: 6R0 907 379 S    HW: 6R0 907 379 AB
       Component: ABS8.2 front  H03 0001
       Revision: --------
       Coding: 400100DB007600B5022700E200D500000000
       Shop #: WSC 13765 790 00017
       VCID: 4E9952981D4074FD40-801A
    No fault code found.
    Address 08: Auto HVAC (J301)       Labels: 6R0-820-045-9AB.clb
       Part No SW: 5J0 820 045 C    HW: 5J0 820 045 C
       Component: Man AC         02 0101
       Revision: 0003S 02
       VCID: 254BCD342C7657A5D1-8070
    Address 09: Cent. Elect. (J519)       Labels:. 6R0-937-08x-09.clb
       Part No SW: 6R7 937 087 H    HW: 6R7 937 087 H
       Component: PQ25 BCM      H12 0022
       Revision: -1------    Serial number: 1002480801
       Coding: 3C980B3808C92400922000003E0B08C00000400F600000000000
       Shop #: WSC 25085 210 12345
       VCID: 49936184E02E53C515-801C
       Subsystem 1 - Part No SW: 6R0 959 802 M    HW: 6R0 959 802 M  Labels: 6R0-959-802.CLB
       Component: J386__TSG_FT  002 3210
       Serial number: --------------------
       Coding: 030000
       Subsystem 2 - Part No SW: 6R0 959 801 P    HW: 6R0 959 801 P  Labels: 6R0-959-801.CLB
       Component: J387__TSG_BT  002 3211
       Coding: 020000
       Subsystem 3 - Part No: 5J0 951 172
       Component: DWA-Sensor       03   03 1109
       Subsystem 4 - Part No: 5J0 951 172
    1 Fault Found:
    01134 - Alarm Horn (H12)
                004 - No Signal/Communication
    Address 15: Airbags (J234)       Labels:| 5K0-959-655.clb
       Part No SW: 6R0 959 655 K    HW: 6R0 959 655 K
       Component: VW10AirbagT2C H09 0020
       Revision: --------    Serial number: 003GX00HYLJE
       Coding: 003243
       ASAM Dataset: EV_AirbaVW10BPAVW250 A01001
       ROD: EV_AirbaVW10BPAVW250_VW25.rod
       VCID: 4A915E88ED2858DD1C-801E
       Crash sensor for side airbag: driver side:
       Serial number: 3495RRB40610GR76I8GN
       Front Passenger's Side Airbag Crash Sensor:
       Serial number: 3505RRB404V0FJPKE1PL
    Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb-SRI1
       Part No SW: 5J0 920 910 D    HW: 5J0 920 910 D
       Component: KOMBI         H17 0206
       Serial number: 00000000000000
       Coding: 420A00
       ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052
       ROD: EV_Kombi_UDS_VDD_RM09_004_SK25.rod
       VCID: 2855C40053644ACDEA-807C
    Address 19: CAN Gateway (J533)       Labels:. 6N0-909-901-6R.clb
       Part No SW: 6N0 909 901     HW: 6R7 937 087 H
       Component: GW-K-CAN TP20 0022
       Revision: -1------
       Coding: 032300
       VCID: 70E5EC60A334420D72-8024
    Address 25: Immobilizer (J334)       Labels:| 5K0-920-xxx-25.clb
       Part No SW: 5K0 953 234     HW: 5K0 953 234
       Component: IMMO          H17 0206
       Coding: 000000
       Shop #: WSC 00000 000 00000
       ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03006
       ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
       VCID: 6AD1FE088DE8B8DD3C-803E
    Address 2E: Media Player 3 (J650)       Labels:. 5N0-035-342.lbl
       Part No SW: 5N0 035 342 D    HW: 5N0 035 342 D
       Component: SG EXT.PLAYER H13 0150
       Revision: A1001003    Serial number: 7669703433
       Coding: 010000
       VCID: 2855C4005B644ACDEA-807C
    Address 44: Steering Assist        Labels: 6Q0-423-156.clb
       Part No: 6R0 423 156 B
       Component: LenkhilfeTRW        V277
       Coding: 10120
       Shop #: WSC 13765
       VCID: 2F672F1CEA8A1DF52B-807A
    Address 56: Radio (J503)       Labels:. 5M0-035-1xx-56.clb
       Part No SW: 5J0 035 161 C    HW: 5J0 035 161 C
       Component: Radio-SWING   009 0034
       Revision: -----09S    Serial number: SKZ4Z2L1184751
       Coding: 010004000006
       VCID: 2241D6283D58A09DB4-8076
    1 Fault Found:
    00856 - Radio Antenna
                011 - Open Circuit
                 Freeze Frame:
                        Fault Status: 01101011
                        Fault Priority: 5
                        Fault Frequency: 1
                        Reset counter: 208
                        Mileage: 206979 km
                        Time Indication: 0
                        Date: 2017.06.26
                        Time: 14:31:26
    End-------------------------(Elapsed Time: 02:15)--------------------------
  2. Re: Fabia II 1.6 TDi EGT Sensor faults
    135 Post(s)
    2040 Post(s)
    If those codes come back I would start by fitting and calibrating a new GENUINE pressure sensor 059 906 051 C and probably EGT sensors 3 03L 906 088 HE and 4 03L 906 088 HL as if these were transferred from the old DPF, this often upsets them. Aftermarket pressure sensors have caused me a lot of trouble so I won’t use them but good brand EGT sensors such as Pierburg are fine.
  3. Re: Fabia II 1.6 TDi EGT Sensor faults
    Jan 2008
    Cornwall
    Thank you. I will monitor this, as today is an entirely different story.
    I averaged 55mpg into work with mixed rural, A road and dual carriageway use and saw 61.8mpg at one point when cruising, so today, it’s behaving itself and much improved since the leaking exhaust was replaced. Odd how there is such a difference between two days though.
    This is pointing to an intermittent electrical component fault, quite possibly those sensors.
    Could it be that the system has now reconfigured itself with those sensors?
  4. Re: Fabia II 1.6 TDi EGT Sensor faults
    135 Post(s)
    2040 Post(s)
    With computers in cars, anything is possible
  5. Re: Fabia II 1.6 TDi EGT Sensor faults
    Jan 2008
    Cornwall
    Temperature readings for sensors 3 and 4 are consistently max range, so effectively 999C. I have not had a reoccurrence of the DPF differential pressure fault, so I'll look to getting a couple of good quality sensors. Pierburg, you say are fine, I'm also looking at an online site with many brand options, including Hitachi, VEMO and Meyle. large price differentials too.
    Aside from these sensor faults, is there any known usual suspect that could cause fluctuating mpg without throwing a code?
    I've tested the usual suspects, brakes are not binding, fuel filter replaced and air filter checked to be dirty, but not blocked.
  6. Re: Fabia II 1.6 TDi EGT Sensor faults
    Jan 2008
    Cornwall
    Are these the definite positions relating to the part numbers? I've seen one of these numbers listed as being before the DPF. My understanding is that sensor 3 is in the downpipes post DPF and sensor 4 is post cat (the one that looks like a real ****-ache to get to).
  7. Re: Fabia II 1.6 TDi EGT Sensor faults
    135 Post(s)
    2040 Post(s)
    It has three sensors, B1S1 in the exhaust manifold turbo inlet (03L 906 088 KA), B1S3 in the top of the DPF (03L 906 088 HE) and B1S4 after the DPF (03L 906 088 HL). These are the latest superseded part numbers. These don't have a B1S2.
  8. Re: Fabia II 1.6 TDi EGT Sensor faults
    Jan 2008
    Cornwall
    I've just replaced sensor 3, but this was after the DPF and before the flexi joint and cat, sensor 4 seems to be the one after the cat. A rescan showed that sensor 3 now has a realistic temperature at cold, so this was definitely one of the problems. I've just got to see if I can get to sensor 4 on my own, otherwise it'll have to go to the garage and up on a ramp.
    For info, sensor 3 giving a reading of 999C when cold, measured as open circuit.
  9. Re: Fabia II 1.6 TDi EGT Sensor faults
    135 Post(s)
    2040 Post(s)
    Sensor 3 is pre DPF, in the top right under your nose when you look in there
  1. Replies: 0
    Last Post: 09-06-2020, 07:49 PM
  2. Please Help lambda sensor faults
    By vw_craig in forum Golf MK4 - 1999 - 2004
    Last Post: 13-03-2011, 02:37 PM
  3. fabia vrs cam position sensor
    By deutsch in forum Fabia
    Last Post: 03-02-2010, 11:20 PM
  4. Question Fabia abs sensor, no turbo
    By galva in forum Fabia
    Last Post: 07-07-2008, 09:04 PM
  5. Question Skada Fabia ABS sensor
    Last Post: 07-07-2008, 08:52 PM
