Thread: 3.0TDI glow plugs
  1. Question 3.0TDI glow plugs
    Mar 2013
    Reading
    31 Post(s)
    Hi all,
    The old lady () is nearing 10 years of trouble free motoring. The other day I did a scan (just for fun, no "visible" problems) and it came up with this:
    Trouble codes:
    P067100 - Cylinder 1 Glow Plug Circuit
    static
    Date: 2023-01-23 07:58:14
    Mileage: 146684 km
    Priority: 2
    Malfunction frequency counter: 1
    Unlearning counter: 255
    Engine speed: 0.00 1/min
    Normed load value: 0.0 %
    Vehicle speed: 0 km/h
    Coolant temperature: -1 °C
    Intake air temperature: -4 °C
    Ambient air pressure: 1030 mbar
    Voltage terminal 30: 10.860 V
    Dynamic environmental data: 2096281781021016D5FFF416D4FD16D804B21643159012BD0010135C08
    So, it looks like I'll need some new glow plugs.
    Firstly, what is the expected life-span (just out of curiosity) as I'll tick 100k miles around the 10y mark in few months?
    Secondly, what is the brand to go for?
    On a separate note, it seems that I'll also have to finally change the battery. Still on the factory one and really pleased with the fact that it lasted this long.
    /J
  2. Re: 3.0TDI glow plugs
    134 Post(s)
    2007 Post(s)
    Glow plugs are a service item, removing them from this engine is a butt clenching and frightening experience as they crack, grind and screech their way out and sometimes snap which is a bad thing!
  3. Re: 3.0TDI glow plugs
    Mar 2013
    Reading
    31 Post(s)
    Do you recommend a particular brand?
  4. Re: 3.0TDI glow plugs
    Feb 2009
    Ireland
    6 Post(s)
    I would get them from the dealer, they are not expensive. Keep the area clean when replacing.
    I paid EUR 22 for one last time I did it on mine, but that was 2 years ago...
  5. Re: 3.0TDI glow plugs
    Mar 2014
    Aylesbury Bucks
    21 Post(s)
    I'd use a multi meter check to see if the plugs have actually failed, not the wiring. Then make sure they come out first, before buying any. If they won't budge, and are not throwing a check engine light, I'd leave alone!
    I last change some on a friend's van, and 1 plug was stuck. So I warmed up the engine, and whilst still running got the plug to move very slightly, almost certainly winding the plug up like a torsion spring. Very carefully, I worked it back and forward just 1 'click', used plenty of WD40 (engine off to soak), and it loosened up, especially when it had undone about 1/4 turn and the WD40 could penetrate down into the soot, the engine pulsing also helped a lot. Soon it was loose enough to remove, engine off obviously!
  1. Which Glow Plugs for 3.0TDI (BMK)
    By six_or_out in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 09-02-2015, 10:17 PM
  2. 2007 A6 2.0tdi glow plugs?
    By thechrism in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 05-08-2014, 12:06 AM
  3. 2.0tdi Intermittent electrical fault - glow plugs
    By UVB in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 23-10-2012, 10:53 AM
  4. Question When do you change glow plugs in a 2.0TDI ?
    By nowa in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 27-02-2012, 10:48 AM
  5. Replies: 6
    Last Post: 08-02-2011, 03:28 PM
