Thread: problem with passat b 6 BKP engine
  1. problem with passat b 6 BKP engine
    Jan 2023
    bulgaria
    Hello, I also have a problem with my DSG- Passat B6 2005. When the car is in position P and I apply gas sharply and release the gas, the car tries to move forward and comes back as if someone is pushing it and "stroking" it. and there is a knocking from the bottom of the engine, clicking, metal to metal: banghead. when it warms up, this knock disappears or is heard very quietly. The oil in the box has not been changed, I have had it for 1 month. It has been serviced oil, filters, belt pump, water hexagon, etc. The speeds it changes them smoothly without a problem or I don't notice. When I stop in position D and release the brake the car doesn't start it stays in one place I have to give it a little gas it does it when it's warm when it's coldit doesn't.plz advice should i change clutch kit with flywheel or just gearbox oil with filter and box adaptation :mrgreen thanks everyone and HAPPY NEW YEAR and GOOD LUCK to ALL :bowdown :bowdown :bowdown
  2. Re: problem with passat b 6 BKP engine
    135 Post(s)
    2038 Post(s)
    That gives the impression of DMF failure and if you are in there and know what to do, then changing the clutch pack is a good idea but beware spending a lot of money on a very early 3C BKP car unless the balancer shaft has been upgraded.
  3. Re: problem with passat b 6 BKP engine
    Jan 2012
    Rustington, West Sussex UK
    10 Post(s)
    88 Post(s)
    @jmiim Apart from what sounds like a bad DMF, you do realise that DSG is a dual clutch electronically controlled manual gearbox essentially that will allow the car to roll back when in drive if you come to a stop on an incline and do not apply gas promptly after releasing the foot brake?
    If you have the auto hold fitted and switched on it will hold the car without rolling back, but I find it annoying as it applies the braking system, so deal with the roll back instead.
    Just in case you were not aware that DSG allows roll back.
    Mad Mitch
  4. Re: problem with passat b 6 BKP engine
    Jan 2023
    bulgaria
    [QUOTE=Crasher;1143983]Това създава впечатление за вреда на DMF и ако сте там и знаете какво да правите, тогава смяната на пакета съединител е добра идея, но внимавайте да харчите много пари за много ранна кола 3C BKP, освен ако балансират вал е подобрен. на всички.
  5. Re: problem with passat b 6 BKP engine
    Jan 2023
    bulgaria
    Hi All Thanks for your replies and help. How do I know if the balance shaft has been repaired? The oil pump hex has been replaced. Will changing the flywheel without the clutch improve the engine performance? Or should the clutch and flywheel assembly be replaced. Sorry for the bad english.not my mother tongue
    Thanks All What is the cost of a flywheel clutch kit?
  6. Re: problem with passat b 6 BKP engine
    135 Post(s)
    2038 Post(s)
    Use Google translate
  7. Re: problem with passat b 6 BKP engine
    Jan 2023
    bulgaria
    Здравейте всички Благодаря за вашите отговори и помощ. Как да разбера дали балансиращият вал е ремонтиран? Шестограмът на маслената помпа е сменен. Смяната на маховика без съединителя ще подобри ли работата на двигателя? Или трябва да се смени съединителя и маховика. Съжалявам за лошия английски. Не е моят майчин език
    Благодаря на всички. Каква е цената на комплект съединител с маховик?
  1. Passat estate 2.0 Tdi B6 BKP Engine "EGR Valve" problem
    By John0 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 20-05-2017, 04:24 PM
  2. Engine management code 17544 (vw passat b5.5 1.8t awt engine)
    By rosco in forum Passat - B5 Forum - 1997 -2005
    Last Post: 17-12-2011, 11:56 AM
  3. Please Help 2002 Passat TDI 130 - N75 Valve / ECU Problem - AVF Engine code
    By mickeybo in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-10-2011, 07:28 PM
  4. Engine problem V5 B5 Passat
    By tombei the mist in forum Chat - Anything with wheels
    Last Post: 02-01-2009, 02:25 PM
  5. 130TDI PD Passat Estate Engine problem
    By FARA in forum Passat - Archive Topics
    Last Post: 01-02-2008, 02:37 PM
