Thread: 2003 Polo 1.2 engine dying intermittently.
  1. 2003 Polo 1.2 engine dying intermittently.
    Jan 2023
    Tunbridge Wells UK
    I have a problem with my 2003 VW Polo 1.2 6V 9N, when the engine is warm and the car is being driven at low or high speeds the engine occasionally dies intermittently and then comes back in (no lights come on the dash) I’ve had the fault codes scanned and the only one present was the ECU power control relay which I’ve replaced with a genuine VW part, I’ve also cleaned the MAP sensor and changed the crankshaft position sensor, and also fitted a new battery but the problem is still there, I don’t feel confident driving the Polo any distance now in case it breaks down, have any of the forum members any idea what the problem might be?
    Thanks in advance.
  2. Re: 2003 Polo 1.2 engine dying intermittently.
    131 Post(s)
    1976 Post(s)
    That is usually the crank speed sensor, AKA G28, the one you have to take the inlet manifold off to change.
  3. Re: 2003 Polo 1.2 engine dying intermittently.
    Jan 2023
    Tunbridge Wells UK
    Thanks for your reply Crasher, but I have already changed the crank speed/position sensor with a genuine VW part, any other ideas please?
  4. Re: 2003 Polo 1.2 engine dying intermittently.
    131 Post(s)
    1976 Post(s)
    The one under the inlet manifold?
  5. Re: 2003 Polo 1.2 engine dying intermittently.
    Jan 2023
    Tunbridge Wells UK
    Yes mate the one under the inlet manifold that’s a ******* to do.
  6. Re: 2003 Polo 1.2 engine dying intermittently.
    131 Post(s)
    1976 Post(s)
    In that case you have potentially illuminated the most common reason so now it gets more difficult
  1. Question Polo 9N 2003 petrol engine swap
    By calin1980 in forum Polo - Derby - Lupo - Fox
    Last Post: 24-03-2017, 11:08 PM
  2. A3 1.9TDI 2003 weird behaviour with dying battery
    By michaelab in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 12-10-2012, 07:01 PM
  3. Question Will an SDi 2000 Polo engine fit a 2003 SDi Octavia
    By genevive in forum Polo - Derby - Lupo - Fox
    Last Post: 06-12-2009, 08:47 PM
  4. Polo 2003 1.2 Pertol Engine cover
    By cockneycooky in forum Polo - Derby - Lupo - Fox
    Last Post: 20-04-2009, 07:49 PM
  5. EPC and Engine Light Fault 2003 Polo 16v
    By iggy28 in forum Polo - Derby - Lupo - Fox
    Last Post: 06-03-2008, 03:22 PM
